Projects Show me your B17 air/fuel tanks
Discussion in 'Traditional Hot Rods' started by jeff.l.hecht, May 25, 2023.
  1. jeff.l.hecht
    jeff.l.hecht
    So I finally picked up a B17 bomber air tank I want to use for a fuel tank on my Model A coupe. Anyone else doing this? Post a picture of how you did it.
  2. scoob_daddy
    scoob_daddy
    from Georgia
    I'm looking for one. The Cornfield LSR utilized one, it's pretty slick.
  3. JimSibley
    JimSibley
    I have one in my 34 ford.
    jet996, -Brent-, Okie Pete and 5 others like this.
  4. deathrowdave
    deathrowdave
    from NKy
    I just had a guy ask me “ WTH ,is it ?” He doesn’t know what it is , but it’s not for sale .
  5. rusty valley
    rusty valley
    I have one for an air tank, but some dumb ***, we won't mention any names here, backed into it with the bobcat and put a dent in it. Doh !
  6. jeff.l.hecht
    jeff.l.hecht
    Nice, I knew folks must be doing it but I've never seen one. If I figured right it should hold just over ten gallons, enough for cruisinge around.
  7. JimSibley
    JimSibley
    They are made of stainless steel, very easy to weld to.
    -Brent- likes this.
  8. dmar836
    dmar836
    Stainless steel?
    lemondana and chryslerfan55 like this.
  9. manyolcars
    manyolcars
    These were beverage tanks that were repurposed as oxygen tanks for the airplanes in WWII. Yes they are stainless. I see one or two at every swapmeet.
    Speed Gems and Deuces like this.
  10. alchemy
    alchemy
    Really? The US Govt cheaped out on oxygen tanks in their aircraft?
  11. lostn51
    lostn51
    from Tennessee
    Not sure if it’s a B17 or not but this was my grandfather’s and has been p***ed down to me. My Uncle was in the military and flew planes so I imagine that is where it came from?!? It makes a heck of an air tank to fill up tires!!! IMG_0854.jpeg
  12. No the govt probably paid premium price the seller cheaped out. Out there someplace there was someone sitting behind a desk with a jar of knob polish saying, "Hrrrrrmmmmmmmm the fed needs an air tank. Hrrrmmmmmmmmmmmmm."
    I actually saw one on Fb market place about a month ago. The guy said he inherited some stuff from his grandpa. LOL
    Deuces, chryslerfan55 and dana barlow like this.
  13. trevorsworth
    trevorsworth
    I have one that was converted to a gas tank at one time with a Studebaker fuel cap. Pretty sweet.
  14. dmar836
    dmar836
    I have several but as part of an off topic collection.
  15. Okie Pete
    Okie Pete
    I have a stainless steel one also .
  16. chevy57dude
    chevy57dude
    With respect to the OP, he's looking for installed tanks. Never did anything with this one. We all like pictures, however. 20230618_051836.jpg 20230618_051901.jpg 20230618_051827.jpg
    I knew I had one somewhere, just had to dig it out! Guy gave it to me cuz he didn’t know what it was…..
    Okie Pete, chevy57dude and Deuces like this.
  18. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Due to the low capacity, if you intend on street driving Id suggest something else. Nothing ****s worse than being on a road trip filling up ever 40 miles....
    panhead_pete likes this.
  19. justabeater37
    justabeater37
  20. continentaljohn
    continentaljohn
    I have a few of them and one that was made into a air compressor back in the 1950s by a company.
    jeff.l.hecht likes this.
  21. jeff.l.hecht
    jeff.l.hecht
    If I did the math right it should take about 11 gallons, isn't that about what a stock model A tank holds? Still yes your right it won't get me too far.
  22. roll of the dices
    roll of the dices
    This is what I used for a '36 truck. Since capacity is an issue had 2 units cut and welded together.
    Cut it right where the round part of the tank starts and was careful to continue all the the ribs.
    Only sandblasted one half as the other half had al the markings and stampings from when it was built and during service.
    This is what they look like inside
    I added a baffle on each side to keep splashing down. Fuel bung for line was added to the bottom of the tank.
    I wanted to keep the tank as "stock" looking as possible so I used a motorcycle pop up fuel cap. I think a vented cap was used.
    I wanted to make it easy to read the fuel level and not carry the typical wooden stick so I sourced a stationery liquid tank gauge. I think this was 10"-12" tall....
    Mounted to the bed using a based similar to that on the b-17/b-24
    Had spray can made to match the yellow and painted the blasted half to match the other.
    You can see it on the back of the bed. Used metal straps bolted to the bases that were cover edwith WWII parachute straps so the metal won't show...Picture taken before it was sold/shipped.
  23. G-son
    G-son
    from Sweden
    You don't need to know what something is to like it. ;)
    Deuces and patsurf like this.
  24. Okie Pete
    Okie Pete
    IMG_2648.jpeg Dices , very nice work it looks great . semi trucks run a manifold that draws fuel equally from each tank . As long as it sits on a centered position between the tanks and the fuel lines are close in length it works very well . I put one on my 66 KW . One tank is smaller than the other and I was concerned that it would get drawn down before the larger tank . It doesn’t both tanks seen to draw down the same . One manifold is for return fuel
    Deuces, deathrowdave, rod1 and 5 others like this.
  25. OLLIN
    OLLIN
    I'm running twin oxygen tanks in my roadster. I still haven't finished running all the lines, but here's how it's looking so far. They are like exactly 8 gallons each if you add up the cubic inches and convert it into gallons... Also, I remade stencil of the markings on the tank in photoshop and had a lady who makes custom coffee mugs made me a stencil. If anyone wants the file, pm me oxygen-tanks.jpg
    Jibs, jet996, Hot Rod Ron and 10 others like this.
  26. OLLIN
    OLLIN
    That came out amazing man!
    Deuces and jeff.l.hecht like this.
  27. These Oxygen tanks were in B17, B29, B50, C97,and maybe C124's. The oxygen was good for curing hangovers.
    Deuces, Toms Dogs, Roothawg and 4 others like this.
  28. OLLIN
    OLLIN
    Actually, since I'm here at my computer now. Here is the stencil file I made if anyone wants it. Royalty free! ;)
    Deuces, rod1, RMcCulley and 7 others like this.
  29. Atwater Mike
    Atwater Mike
    Thanks, @OLLIN! ...A breath of fresh air... Royalty free, yet!
    Deuces, Okie Pete and OLLIN like this.
  30. D Reed
    D Reed
    I have one if you’re still interested
