Technical ***June 2023 Season Change Almost Here***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 2, 2023.
  1. My Battery ground cable is directly connected to the block with a bolt connecting the bellhousing to the block!
    trikejunkie and Airborne34 like this.
  2. V4F
    V4F
    from middle ca.
    i have it grounded 3 ways to sunday !
  3. It started out as a simple brake job. I found that the bearing race on the right rear axle was gnarly bad.!
    The REAL problem is that the races on which the caged roller bearings run are rather permanently swaged onto the axle casing., Without a lathe to cut down the damaged race and put on a repair sleeve; through a friend i got a whole good axle case!
    Jet96, Outback, Crazydaddyo and 2 others like this.
  4. John
    Good to hear it is not terminal
    There are parts around just put the word out
    J
    Old Dawg likes this.
  5. Starting to come together
    Or at least the parts so far seem to work
  6. 4BangerDean
    4BangerDean
    I would really appreciate at that. I do have a dual detent shifter to go along with the later gear set. I’m thinking it’ll be quite an improvement. The only early Ford transmissions I’ve driven are the B box and Model A.
  7. Outback
    Outback
    from NE Vic
    For the ignorant, what's happening here?
    Y-block head on a B?? From what I can gather??
  8. Jet96
    Jet96
    from WY
    @Outback -yessir that's it. Rich Fox had one that actually ran. Pretty well too.
    fur biscuit and Outback like this.
  9. Outback
    Outback
    from NE Vic
    Doesn't look like there is an adapter plate, how close are they?
  10. I looked at it today and it was not a B block
    I seem to recall a dodge but not sure
    J
    Outback likes this.
  11. Fabber McGee
    Fabber McGee
    A quick internet search turned up this picture that I had seen before, but no text.
  12. Rich was a Dodge fan. Had all manner of cool ideas and engines. Anyone know what happened to his A?
  13. Jet96
    Jet96
    from WY
    I totally spaced out he used Dodge and Plymouth blocks...
    Old Dawg and fur biscuit like this.
  14. V4F
    V4F
    from middle ca.
    WOW !!!
  15. Rich’s roadster went on to New Zealand
    It has been upgraded to current SCTA specifications and should be coming back to complete again
    The motor will be another Dodge with a nascar head graphed on
    Stan Back, Old Dawg, Outback and 2 others like this.
  16. Very cool! Sounds like an excellent rebirth.
  17. Saw this on the MTFCA forums, ordered a copy. Lots of fun to see what was going on over on the Continent. Think it is available off Amazon, well worth supporting a solid effort.
    Jet96 and Outback like this.
  18. Hot damn! How thick is that plate for the front timing cover?
    4BangerDean likes this.
  19. It is two pcs 5/8” and 1-1/4”
    After all locations are done I will pocket out some of it to lighten
    There is still much to do before it lights
    J
    4BangerDean and Jet96 like this.
  20. Kevin Pharis
    Kevin Pharis
    from Califunny
    Who is on the road to Lincoln…? Was p***ed by a black enclosed trailer with FAST sticker on the back yesterday in eastern Nevada
  21. Brierley was heading into Flagstaff yesterday afternoon
    Wish I was going with them
    J
    Crazydaddyo likes this.
  22. V4F
    V4F
    from middle ca.
    me too john
  23. Dan from Oakland
    Dan from Oakland
    Kevin- we need pictures!!
    Outback likes this.
  24. 29 Speedster
    29 Speedster
    from Colorado
    Speedster Trials were in our plans, but my Son is in a cancer battle changed plans. If any of you p*** by Windsor, Colorado (on I-25, 50 miles south of Cheyenne), you’re welcome to stop by.
    Outback likes this.
  25. 29,
    sorry to hear about your Son, hang in there
    one of my buddies is having open heart today
    J
    Outback, Jet96 and 29 Speedster like this.
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    Finally made it to Lincoln!!!:cool:
  27. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Bitter sweet for me, will be my last banger check in for a while... Car is sold and a bucket list car is coming Flatty v8 this time sadly. Will my sold car be my last banger?..NO. But the next banger will be OHV Cragar etc... The ole banger was a blast on 66 at the Prewar Pileup...
  28. Jet96
    Jet96
    from WY
    29 Speedster likes this.
  29. Outback
    Outback
    from NE Vic
    We all buy & sell for different reasons, don't forget us, infact this thread is for Wanna-bee's & has-been's also :p hahaha :D So make sure you are not a stranger here! ;)
    Old Dawg and stubbsrodandcustom like this.
  30. Bearing Burner
    Bearing Burner
    from W. MA
    Does anyone know what insert bearings Rich Fox used i his Plymouth 4 engine?
