Projects Northrop F5 Belly Tank Racer
Discussion in 'Traditional Hot Rods' started by Superlite, Feb 1, 2023.
  1. Superlite
    Superlite
    I wasted no time here. At an easy going and relaxed pace, I had the ch***is completely stripped down to its bare frame within 3 hours. I started tear down at 11pm and finished at 2am. I then spent an hour and re-arranged the shop to help facilitate the build process further. I took several leaves off the front spring. I believe I left 5 leaves attached and will go from there. I wanted to get this done quickly because I needed to come up with a list of some things I will need to get my hands on. Here's what I will need next and some of the things i've seen so far that need attention:
    - I need to get 2 large wrenches (larger than what I have on hand) for the removal of the torque tube from the banjo rear end. The two nuts are pretty chewed up.
    - Spring Spreader - I don't feel like using the double C-clamp and chain method on the rear leaf spring so I will be sourcing a spring spreader. I would rather have the tool for future projects. As an aircraft mechanic we practice MRM (Maintenance resource management) regularly. I really don't feel like dealing with flying leaf springs because of a mistake I made and damage my corvette, the bike I built, or injure myself in the process.
    People don't know how to properly install cotter pins, so I will be pulling every cotter pin on the driveline. I'll be re-installing them all up to aviation standards after checking everything for proper torque and tightness.
    I will not be able to use the Model A Ch***is for the lakester's frame. It is roughly 1.5 feet too short in length to properly create the ch***is I need. @26 T Ford RPU was right. It will be better to build my own at this point instead of re-purposing the Model A Ch***is. I have no choice in the matter. I'll have to and that's okay. I'll be able to recouperate some cash as I plan on selling the ch***is. This should make some people happy. Someone else can make good use out of this incredibly well cared for and restored frame.
    The left front wheel center cap is pretty loose so I need to figure out a way to secure that better. I am interested in getting the Mooneyes Aero wheel covers at some point.
    351570519_825187532356165_1311833396557823361_n.jpg 351553973_602323465213246_8163432257259626392_n.jpg 351534252_217027997353811_9121130900840125205_n.jpg 351534236_601745535392053_7699448895232131873_n.jpg 351490752_193257549997113_5924519582149082167_n.jpg 351610289_220744097514696_481849642475437302_n.jpg 342165227_1441249903316665_809647714855658910_n.jpg 351643219_1013327426356774_3381062848298648902_n.jpg 352866113_6191652217557098_5674961038287467051_n.jpg 354058432_557995673201535_8163406461323878118_n.jpg 353870371_556651920014257_8639032108803167730_n.jpg 352810644_778837323897611_7143922408843916078_n.jpg 354011336_1222557151787358_9072693792138514513_n.jpg 354024745_217035654548301_7484022070347404479_n.jpg 352303597_1017914022952898_1799857136109625970_n.jpg 351529609_225566213572569_2091607611856117786_n.jpg 354096334_571453855060130_4814680411462486757_n.jpg 354070130_582407973998129_2769570066233579310_n.jpg 354081788_281562854236820_5733595193990447236_n.jpg 353559231_694526039069878_4334147610503697822_n.jpg
    Toms Dogs, Okie Pete, Deuces and 7 others like this.
  2. Ned Ludd
    Ned Ludd
    I can't quite make it out on the pics: is there a number stamped on the upper face of the left frame rail a bit to the rear of the engine mount? It is sometimes very faint, and would have been the same as the original engine number. If there is no number you might have a Canadian frame.
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Sl;
    I see you have most everything to use for suspension, esp early-style.
    But you asked for ideas, so in case you're still looking/considering; re: post 149 & the acvw components for transaxle &/or suspension comments: what could work out well, would be a "long"-bar torsion-bar instead of leaf or coilovers. Shouldn't take up much room, & I'd run them horizontally inside & alongside the hull-cut-line, & the swinging arms parallel w/the axletubes. Could end up being almost hidden. The reason I was thinking along the acvw-bars line is, because for the front, vw used a stack of small thin leaves, which could be added to, or subtracted from, depending on how the weights go vs the lengths of the torsion-bar "fingers". Vw also used conventionally shaped, but fairly short, round splined torsion bars for the rear, think they came in a few different diameters, but could be turned down as needed - after figuring spring rate(s) needed. Sort of a cheaper & easier-to-obtain-parts instead of circle-track suspensions.
    FWIW.
    Marcus...
  4. Superlite
    Superlite
    No numbers that I can see. The frame is a a bit pitted from age but is solid. It was cleaned up and painted over. If there were any numbers they corroded away but it is impossible to tell.
    Ned Ludd likes this.
  5. Superlite
    Superlite
    Early this morning, the steel for the Lakester's frame arrived. I purchased two 24ft lengths of mild steel rectangular tubing. The dimensions are 3" x 2" x 0.125". I cut them both in half to give me four 12ft lengths.
    355711182_823125819381917_5820238760582227123_n.jpg 355815618_1484363492302677_2375079053793973386_n.jpg 355880854_806919687696654_6964206810186428318_n.jpg 352149618_931323747961748_6949903555363783046_n.jpg 355429983_795362792195483_1744576686773429002_n.jpg 352251134_240066325476443_2289380175716443031_n.jpg
  6. Superlite
    Superlite
    I was out in the garage cloudy and early in the rain to receive the frame. It was raining very hard and didn't feel like going out in the rain so I took the time to tackle the rear leaf spring removal. I decided against purchasing a spring spreader and just used what I had on hand in the garage. I used the original spring shackles and a steel cable and ran the nuts down and backed them off slowly to control the release. After the shackles were ran all the way out, I had the steel cable wrapped around the spring to help control the release further and prevent the springs from flying away in a violent separation until all the pressure was gone. The rest of the spring came out no problem. Glad to have that out of the way. Progress!
    352013199_672911731299674_4578641584864479273_n.jpg 352125284_246787084727291_1875586838841331021_n.jpg 354100079_1044091779912202_1578125369771145548_n.jpg 355563039_1080364310036373_3066232881197528043_n.jpg 355567636_594815629465088_2663280404712327571_n.jpg 355574017_1126453261467401_3097127091977028896_n.jpg 355655432_283301994157210_6318715486400186255_n.jpg 355807611_644926214162506_3969627658353578578_n.jpg 355819587_791939982430034_7011417807735498029_n.jpg 355844332_1328048834487600_6399965941503648445_n.jpg 355851790_266258606083169_6610590325474465486_n.jpg 355911643_3332602653721652_6385555524828602808_n.jpg
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I like the cable idea. Those leaf springs are ******s if not handled with caution.
    caprockfabshop and Superlite like this.
  8. Superlite
    Superlite
    Time for another set of updates. I have been extremely busy with life outside the garage and have had some big life changes. I won't get into details on that front because this isn't the place to vent and quite frankly, i'm sure none of you guys care anyway! Due to these life cir***stances and further time constraints I will be making some changes regarding how I will be putting the lakester together. The largest and most major update being:
    - No rear suspension will be installed, atleast for now. Rear suspension may be addressed at a later date, however I doubt it due to lack of space in the rear end of this super slim tank. This will also affect how often I will drive the lakester in the future after completion. Most lakesters never had rear suspension anyways, so it is further keeping in tradition with the typical post-WW2 lakester of that time frame. I also don't have the time to come up with a rear suspension system and fabricate it, nor do I feel like spending the money on rear suspension at this time. This car has to be ready for a huge car show and get displayed inside a convention center in just over 2 and a half months. The clock is ticking FAST.
    Time to lay out the progress i've made over the course of the past couple of weeks.
    It was time to start getting the driveline laid out and put together and to ***ist with that process I decided to make a large cardboard template to ***ist in taking measurements and placement of the individual parts of the drivetrain. This was a great decision overall. I went to Walmart and picked up a couple of large moving boxes. I simply laid the boxes over the frame, took a sharpie to the bottom of the box next to the tank and drew the shape of the tank. After I had the outside of the tank drawn I flipped the box over and positioned it where it needed to go. The tank shape is identical so it didn't matter that the left side markings were now on the right side and vice-versa after flipping the box over. Space is extremely limited with this tank, so utilizing the cardboard template here would help fabricate the frame-rails with tight clearances to the side of the tank which is exactly what needs to happen. I used my laser level to help me find exact center of the tank once more for my template, and then from there I was able to take measurements from the centerline to the frame rails to help make sure that measurements and positioning would end up even.
    357560042_973449660587071_4015192797958306209_n.jpg 358095966_582624760695643_3847151923934548088_n.jpg 358712725_501019382206346_7758149299372090757_n.jpg 358525761_616051137295688_4383110906719091180_n.jpg 358496632_1015484386553666_4469510237314062550_n.jpg 358739036_1325252444741914_4847123743184703152_n.jpg 358768653_1339141623705191_1676145592656471526_n.jpg 358788880_167409192912013_8085027837613920382_n.jpg 358789036_190025067086826_8410318454087954095_n.jpg 358776219_574292801447887_3022761267676896135_n.jpg 358763825_689591603036022_6705651291723504693_n.jpg
  9. Superlite
    Superlite
    Making that template was a big positive and really helped keep me on track with the completion of the frame rails. They fit inside the confines of the tank just perfectly. I did fairly well with these and very happy with the outcome. The two rails are almost identical. After taking some measurements I decided to make 5 degree pie cuts in the frame rails. I didn't quite need 5 degrees of bend, but I wanted a little extra wiggle room to be able to bend the frame rails to where I needed them to be. No special tools used here, just a protracter, a scribe to make marks in the frame rails, and a hand held cutting wheel to make the cuts.
    You may notice that the frame rails aren't sitting perfectly even once sitting on the tank. That's because when I chopped the tank in half, I wasn't able to cut two perfect halves. The halves are just a little bit off. In one of the next updates you'll see I was able to get the 2 frame rails sitting pretty even by recessing the flanges of the tank where I needed them to go.
    355951554_301965805508418_4066431459226942720_n.jpg 358031224_248675154577915_5058590505803126938_n.jpg 358454312_176772162051198_3336813299092377511_n.jpg 358757724_283612134335196_7877787743543757416_n.jpg 358551921_1439955760186180_6555532002849041360_n.jpg 358533128_1680136282460046_5993377066527678847_n.jpg 358762232_1462789151139779_2359326551594677211_n.jpg 358681008_818729232978936_2613068110110000104_n.jpg 358154468_152074407840964_772127968382040347_n.jpg 358518198_997742231365781_4376080303047137574_n.jpg 358788289_3421922768026113_5326075679003583384_n.jpg 358907021_245835358216291_945219390286737293_n.jpg 358771071_230339796492493_7451534943898051657_n.jpg 356427908_652560186366465_7161230275605043562_n.jpg 356285215_544848977855441_8229594193465500625_n.jpg 356327919_1490433381699896_5282304279710346455_n.jpg 358762452_1032520557743787_6513552708938493536_n.jpg
    Toms Dogs, Okie Pete, Deuces and 2 others like this.
  10. Superlite
    Superlite
    Starting to look like a lakester!
    This is one of my favorite updates so far! I get my first visual of what it will look like when it is on wheels. Now that the frame rails are shaped, it's time to get the lakester off the lift and start working the driveline into place. I decided to recess the rear end into the rear tail cone a bit to conserve a bit more space up front. It worked out because it's pretty much exactly where I wanted the rear end to go and it is visually appealing at the same time. I think there is a good amount of tank sticking out past the rear end of the tires, and the location where the axle comes out through the tank is in a great position also.
    Now that the rear axle is locked into its location, I was able to take the frame rails and figure out where I needed to recess the flanges of the tank to allow the frame rails to get situated inside the tank. If you recall from last post, the frame rails were sitting uneven because the tank wasn't cut perfectly in half. I will be able to fix this unevenness when I recess these flanges.
    My frame rails are 3 x 2 x .125 (1/8" thick). I decided to drop the frame rails 2 inches into the tank and leave 1 inch on top. This will place the rails at the widest point in the tank and help me to fit inside best I can and allow the most room for things like the engine to fit ( I hope lol). The two inch drop lines the frame rails up with the rear end pretty well. 358801844_1352228942304427_700596942725327559_n.jpg 358742336_1331229890764219_1883756238355779593_n.jpg 358765339_1722971798122678_8033900928316085517_n.jpg 358762968_6843737098983312_5769925267208857334_n.jpg 358812727_1202983430385370_4150270167195711718_n.jpg 358808855_189864373782824_297914388987902599_n.jpg 357844825_289002730195851_3992651741341593315_n.jpg 358790065_1420465021831101_3852595677468926536_n.jpg 358101204_1695371364221528_4889711328319255003_n.jpg 358498898_9757749244298854_8795407199701533321_n.jpg 355067730_924119415318394_7757246448305172018_n.jpg 355036679_970843580780173_5082277482971328840_n.jpg 354828671_1676209712804441_2871670240544077702_n.jpg 354473720_614828113762920_1583702681083739173_n.jpg 356530565_651412977027605_6318010140732397248_n.jpg 357989780_1315013616058946_4895943825089911249_n.jpg 358496632_105865055904888_1057008046571038806_n.jpg 358500313_6816759245014988_3522566347759819489_n.jpg 358731212_639925221175354_1361902874996528323_n.jpg 358740436_806313310905292_5565819211103005744_n.jpg 358772126_947418226484243_2114257904482355792_n.jpg 358547034_592710892757275_84325501856976500_n.jpg 358505995_307060331757032_7457192777494194831_n.jpg
  11. Superlite
    Superlite
    Frame rails are recessed. I spent a good deal of time getting this part right because I needed to get the frame rails sitting evenly and level with the other due to the unevenness of my cut when I chopped the tank in half. I managed to get them pretty much exactly where I wanted them to be. I was able to cut and grind down the flanges to give the frame a 2" drop inside the tank leaving 1" on top. I also took the time to cut some length off the front part of the frame rails to allow room for the front end and steering rod.
    Had to move everything over in the shop to get my Tesla in the garage due to the potential for incoming golf ball sized hail so I had to "dismantle" the tank and shove it off to the side where I could fit everything. Of course, no hail. 358811211_294445792977220_3165982135771058167_n.jpg
    358778152_878296227193322_3838472053780501929_n.jpg 358031224_664077902246066_8969090336164987083_n.jpg 358031224_1430837907457612_3495708861279812178_n (1).jpg 358799860_983879452652161_7899635780322715325_n.jpg 358964399_7074922735869307_6331047960906797286_n.jpg
  12. Superlite
    Superlite
    Time to fabricate the rear end mounting brackets.
    I took a decent amount of time and leveled out the tank for a couple of purposes:
    - Fabrication of the rear end mounting brackets
    - Deciding ground clearance.
    I placed all the components inside the tank up to my current progress. I leveled everything to 0 degrees both longitudinally and laterally and i'm coming up with 5 inches of ground clearance with everything in place which is right where I wanted to be. This will help with driving on the street due to the long wheelbase. Everything is straight and true.
    Now that everything is sitting even, it will help me accurately fabricate the rear end mounting brackets. In post #188 I stated that I was no longer going to be pursuing a rear end suspension system. I am running out of time to get this tank rolling on wheels and to get ready to be a display car / feature car inside the convention center for the big car show in the first week of October. I also don't feel like spending the extra money to design and purchase the required items needed to fabricate the rear end suspension system. I am ok with this. I may not drive the car as often on the street, but i'll manage for the purpose of car shows and events. You can also see that with the rear end in place, there is almost NO room for movement. I still need to fabricate a part of the frame to extend behind the differential and exit the rear of the tank for a push bar. Room is severely limited and will be even more limited with the required space needed for the push bar. The push bar will also double as a rear end jacking point in the future.
    For these mounting brackets I decided to start with some cardboard. It worked out so well for the frame frails that I decided I would use it again as a template for the brackets. I went to Lowes and sourced two 1/4" thick rectangular steel plates. These are hefty! The last two left! I also sourced the required bolts and hardware. On each side I will be using 5 large bolts and nylon locknuts, along with 2 washers ( one under the nut and one under the bolt head) and bolt the frame to these brackets. The shanks of the bolts are 2 1/4" in length to account for the 2 inch thick frame rail, and 1/4" plate thickness. As with your typical lakester, the plates will be welded into the axles and then those plates will be bolted into the frame to allow for removal of the rear end ***embly for servicing. The brackets took a decent amount of time to cut and grind down to where I wanted them to be but they came out great and are identical. They fit the axles perfectly.
    Here's what's next for the immediate future. These steps will hopefully be done by the end of the coming week:
    - Drill 5 holes into each frame rail and each bracket for the mounting hardware. I'll be creating another template for these holes to ensure I get this right.
    - Cut a couple slots into the front end of the tank to get the front end into place.
    -Fabricate the front leaf spring tower and come up with a mounting solution. I'll need to source a couple new U-bolts. It turns out that my 2x3 frame rails are the perfect housing solution for the front leaf spring so I may go that route or I may go another route altogether. I'll probably put together the mounting solution and then build the tower up to where it needs to go afterwards.
    If I can get these tasks done, the lakester should be on wheels by the end of next week! Having a great time with this build so far. It's coming along quick and the lakester will become a car rapidly from here. I work fast.
    On another note, I have a Montana LLC. I contacted them with regard to start the ***ling and registration process for the lakester and sent them a couple of pictures. They will be considering the lakester a kit car for the purpose of registration and I'll be able to get a state-issued VIN number. The car will need to be completed before starting this process and will need to be inspected. I should have no problems getting plates for the car when it's all said and done. Not sure how long this process will take as of right now.
    358778152_878296227193322_3838472053780501929_n.jpg 358501711_291655273428537_2228555247053193524_n.jpg 358326201_1008771893898063_9221898831041273191_n.jpg 358696894_1413142345896501_8933063202215698565_n.jpg 357742923_699499832037318_2111554706598361822_n.jpg 355693824_1442717283171513_6565119507644236860_n.jpg 355175017_2516080705213617_8031017751015899688_n.jpg 358520021_937075350720248_4383347110906562326_n.jpg 358759070_581203767524604_7264958550212211162_n.jpg 358739031_812850393574640_7933567081810083316_n.jpg 358765342_670901521548663_4180706814205513995_n.jpg 358789027_2957241044409201_1576567948827553100_n.jpg 358101204_1035085977865099_965125652640689208_n.jpg 358681027_624656679767331_4020019201642999700_n.jpg 358454310_778135633798682_5295933601005739842_n.jpg 358021335_1229123184456735_4159437718746303716_n.jpg
  13. X38
    X38
    That welder looks like it's struggling. Doesn't look like those welds are really burning in there.
    Gasless?
  14. Superlite
    Superlite
    Yes Gasless MIG. I didn't really take good pictures of the welds but those are just small tac welds currently. I ran some test welds on another piece of frame steel I chopped off while making the frame rails to dial in voltage and amperage numbers. I'm getting plenty of penetration.
    X38, 41 GMC K-18 and 26 T Ford RPU like this.
  15. 26 T Ford RPU
    26 T Ford RPU
    All very impressive, as for the mounting of the front end may i suggest making the spring mount adjustable. If you finalize it now (or soon) it will change as you add components. JW
    Superlite likes this.
  16. Superlite
    Superlite
    Thanks for that. I'll look into an adjustable solution when I get there! It's something I haven't thought to consider.
    26 T Ford RPU likes this.
  17. Harv
    Harv
    from Sydney
    This is a great example of why CAD/CAM is traditional.
    (Cardboard ***isted Drafting/Cardboard ***isted Manufacturing) :D
    Love the way this project is heading. Life sends us all some bumps along the way - glad to see you are still making this dream come to life.
    Cheers,
    Harv
  18. Superlite
    Superlite
    Thanks Harv. Having a great time with the build so far. This kinda stuff comes easy to me and it's therapy with everything going on. It's all falling into place and will be done before we know it.
  19. Toms Dogs
    Toms Dogs
    from NJ
    Keep up the GREAT work ! *This vehicle qualifies for any Future T.R.O.G. events, especially those in WILDWOOD, NJ ! ! :D:D:rolleyes:
  20. Superlite
    Superlite
    Thank you! The only questionable items on the car are the white wall tires, but I don't see why T.R.O.G wouldn't approve the lakester how it will sit. Everything else should be good to go! Wildwood, NJ isn't that far away at all from me. I'll be making every attempt to make it to those events in the future.:D
    Toms Dogs likes this.
  21. Bearing Burner
    Bearing Burner
    from W. MA
    I think you should build some sort of jig to enable you to get the frame rails parallel and the cross members square, We used a 6X6 tube (light pole) with 2X2 tube cross members great taking care that the cross members were square and on center of the spine.The cross members were 2ft apart. This was mounted on rugged saw horses made of 2x6 lumber. the height of the saw horses was such that to work on the ch***is you didn't have to bend over. Took time to build jig but made construction of the ch***is so much easier. Gasless MIG is not the best for strong welds in my opinion. You don't pretty good penetration if there is any chance you could go over on your head at speed. Another thought that at Lorring Me. you can run 1 and 11/2 miles on paved surface. Check out LTA on internet.
  22. alanp561
    alanp561
    Umm, looking at your test welds, your machine is too cold and you're moving too slow. Set up some practice plates the same thickness of your tube walls with the same gaps you've got on your cuts and practice on them before you start welding on your rails. Even with that light gauge steel, you're going to want a sealer p*** before you put a cover on it. You're using inner shield, so spray some anti-spatter around the weld area, it'll make clean up a heck of a lot easier. Speaking from 50+ years and several hundred miles welding inner shield experience.
  23. Superlite
    Superlite
    I bagged around 30 hours of garage time over the course of my weekend, all in 90-95+ degree heat. No air conditioning, no fans, no airflow. I may have sweat through all my clothes, but I managed to get out there and get it done. I have 3 day weekends every week which makes garage time easier to come by. 12 hours Monday, 8 hours Tuesday, and 10 hours on Wednesday. I accomplished a ton and made loads of forward progress.
    I appreciate the welding advice. I'm not a professional welder but I am getting better every time I do. I already know my welds are subpar okay!? Lol, One of the big reasons for building the lakester is to grow as a hobbyist and a mechanic in all aspects of building vehicles, welding included. I have been doing a bit of stick welding with 7018 electrodes but the majority of my time with welders is gasless MIG. Per your recommendation @alanp561 I did pick up some anti-spatter and it does help. The welds may not be the prettiest and I think it's a common fallacy that gasless MIG / flux core wire welding is weaker than other types. I believe it can be just as strong as any other type of welding. You may not have a shielding gas, but flux core uses compounds that produce a protective vapor during welding which accomplishes the same goal.
    I know grinding welds down typically makes them weaker in some but not all cases, however I did decide to grind and smooth down the welds on the frame rails for a couple of reasons:
    1: Now being as I'm not a professional welder and weld infrequently I did weld a few of the seams twice. Since I was closing and bridging gaps in the pie cuts I wanted to ensure that there were no air pockets inside. If I found any, I welded those gaps a second time over.
    2: One 3" side of the frame rail wasn't ever cut during the making of the pie cuts so I deemed the integrity of the frame rails to be enough to allow for these welds to be ground down.
    3: I do plan on making at least 1 trip to the Utah salt flats in the future, and since I'm relatively close to Wildwood, NJ for T.R.O.G events, the car will be on the salty beach. I don't want salt and highly corrosive substances to find places to hide on the frame rails to start the process of corrosion and rusting of the frame.
  24. Superlite
    Superlite
    On Monday, my focus was getting the rear end on wheels. In order to do that, I needed to finish fabricating the rear end mounting brackets and drill holes through the frame rails. Drilling through 1/4" thick steel plate is no joke. I went through around $60 worth of drill bits even with oiling the bits and the steel itself to help keep temps down and the bits lubricated. Got the job done though! They came out really good in my opinion for using a hand held battery drill. The holes themselves are 5/8". Rear end mounting hardware is all Grade 8. The washers were slightly large for the space I had to work with, so I did grind down one side for the bolts that were side-by-side. These essentially became lock-washers and are unable to spin if the bolts ever loosen up. For running the bolts through the rails, they will run from outboard to inboard side. This will be a safety in the event a bolt decides to loosen up. The wall of the tank itself will prevent them from backing out all the way. For tac-welding the brackets to the axles, I first ran all the bolts through the brackets and attached them to the rails. This was to ensure the rails and brackets were true to eachother. I then ****ed the brackets up to the axles and tac-welded them in place.
    361138471_288421403728323_7239728393579229412_n.jpg 361141479_295763489513246_694718561205449667_n.jpg 361134019_3514581198870099_4924207587619796156_n.jpg 358533130_1308425383120715_4884131636420585123_n.jpg 361134074_233249422918602_1224347674671819244_n.jpg 361144837_1018755269487575_8059356360701432814_n.jpg 361125952_825683212168953_6689186671739848_n.jpg 361136425_600676212250346_4286150729484948436_n.jpg 361090000_273391345288687_1516789963214901270_n.jpg 360058871_1307948423169770_4693974848780000288_n.jpg 356206306_974001877267828_1459152165419930545_n.jpg 356248189_234789426099803_6394967317199897373_n.jpg 356205232_784496493412588_1002051813555422198_n.jpg 361126627_942790643449585_6706344046087633297_n.jpg
  25. Superlite
    Superlite
    Now that the rear end is on wheels, the next step of the build is to get the front end on wheels. Tuesday's job was to find the front end its home. I only have one chance to do this right so I used a laser level throughout this process along with some careful measurements with calipers down to the thousandths of an inch to ensure the location is squared and true both longitudinally and laterally. The saying measure twice, cut once really came into play here, except I probably measured closer to 20 times. Can't be crooked here. I removed the steering linkage that runs from wheel to wheel to ***ist with locating the main support of the front end for those first cuts through the tank, and then I flipped that linkage from the rear of the front end ***embly to the front. This saved a lot of room inside the tank and allowed for an easier time to fabricate the front mount for the leaf spring. The steering pivot point is no longer on the left wheel and is now on the right side due to flipping the linkage from the rear of the ***embly to the front. I was a little bit worried that when I made the cuts for the steering linkage, there would be reduced strength for the cone of the tank but it doesn't really feel any weaker. Still feels strong. At this point I only have the basic cut for the linkage. I'll still need to open it up wider to allow for turning. You'll see at this point that the tank is obviously resting on the front end and isn't being truly supported which is why the cuts look a bit off. The cuts should be even when I actually get the car sitting on its front wheels after fabricating the mount for the leaf spring. The slots, especially for the main structure of the front end has a pretty tight clearance. After the leaf spring is supported on its mount, I'll possibly be further clearancing the two slots to allow for proper spacing and to prevent rubbing of the tank on the front end ***embly. The need to do this will also be determined by the final resting place of the tank after mounting the tank with the radius rods. This is the first time seeing the tank on 4 wheels! Had to get some pictures with it. The vision is coming to fruition!
    361141550_607124864822043_5028774702640993292_n.jpg 360154614_842423510562164_8358524043242576289_n.jpg 360869798_1003510024162648_2034486446389234286_n.jpg 361109036_258644813538274_411081536649661080_n.jpg 361121754_1915841998815586_1777557541411410160_n.jpg 360103701_258621493556543_310834158106291075_n.jpg 360170381_996422381801801_1965870289240075321_n.jpg 361132298_815688453467533_6961205258989511643_n.jpg 361161768_662695812557650_6306934762206544489_n.jpg 361141468_6635770403128176_7194540674212739381_n.jpg 360183676_1331253384148515_6018736431947832992_n.jpg 361082503_245456411597824_3256433283073128338_n.jpg 360213845_763608548825404_3983319055691572530_n.jpg 360212945_961445065122946_2981840726165651113_n.jpg 360161611_614035564163831_6506304865379991950_n.jpg 360093778_607991634770289_8562667313036396704_n.jpg 361112752_294995356301086_7569857021496459328_n.jpg 361137051_1017773899220722_3544759213373477957_n.jpg 361155664_1069944867314183_8668569026928326927_n.jpg 361085716_167079243041652_4211728893022239535_n.jpg 361152302_178861735035643_6507119181693607349_n.jpg 361160596_229998866624612_2190808460195016154_n.jpg 361140656_220097044325462_2274343598173052223_n.jpg
    Toms Dogs, Okie Pete and 41 GMC K-18 like this.
  26. Superlite
    Superlite
    I didn't make as much progress as I had planned, but Wednesday's job was to start working on the front support structure for the leaf spring. I spent a few hours working on a mounting solution, but it ended in failure and I wasn't happy with the result so I s****ped it. Trial and error is par for the course for building a whole car from scratch with no directions. :eek: The leaf spring does fit inside the 2" side of the 2"x3" frame rail, but it's a tight squeeze and requires a slight bend in the 3" walls to allow it to fit. Wasn't happy with that outcome but I have a better solution I'll be working on next weekend. I finished welding the frame rail pie cuts, and welded the rear end mounting brackets to the axles. I also squared the front of the frame rails to allow for a flush mount of the cross brace / front leaf spring mount. In post #203 I detailed my Wednesday welding adventures in further detail. Here's the few pictures I managed to take to close out my 30 hour garage marathon over the weekend. Overall, I made some m***ive progress on the belly tank and couldn't be happier! Starting to look like a car! :D
    360156940_2623788261104762_660695743183988082_n.jpg 361062209_3593437487555976_8668056707774551714_n.jpg 361159444_1427502421421405_3151624874682102701_n.jpg 361151012_6711736598848332_8794312783061284631_n.jpg
  27. mohr hp
    mohr hp
    from Georgia
    I appreciate what you are doing here, I once was in a very similar situation as you are. You have a lot of determination and and a great work ethic that I hope will carry you through this whole deal. Having said, that I gotta say something about that rear end attachment. I know you put a lot into it, but this arrangement is going to have issues in time. Rectangular tubing is not rigid enough to use through bolts to attach an axle. It will compress over time and the attach plates will be loose and work around and start to come apart. It will hold for a while, maybe long enough for you to go back after its done, to incorporate a suspension of sorts (needed!). You could fix it by enlarging the holes in the tubing (more drilling!), then welding in some through strut tubes to support the bolt clamp loads. As far as $50 for drill bits, I ***ume you're getting bits from Home Depot. Might want to step up to quality bits sourced on line, and maybe you're killing them with too much bit speed. try drilling at a slower speed with more pressure, and the oil is a good thing. Keep plugging, it is a journey!
  28. Superlite
    Superlite
    You see, this is exactly why I have started a build blog. It is really helping me fill in the blanks, and providing further insight beyond my own thought processes. Instead of drilling larger holes, I'll probably source some 3/4" diameter steel tubing to place inside the frame rail where the 5/8" diameter bolts can slide through. I'll weld from the inside. Excellent Idea! I haven't even thought of potential for compression and loosening over time which I can definitely see happening. This will be a quick and easy improvement.
    26 T Ford RPU and 41 GMC K-18 like this.
  29. alanp561
    alanp561
    In regard to moving the tie rod from the backside of the front axle to the front, may I suggest that you look at Wikipedia's description of "Ackerman steering geometry"? There is a very comprehensive explanation, with diagrams, of how it works. I admire your enthusiasm for this project but there are some basics that you can't ignore.
    Superlite and Just Gary like this.
  30. Something to ponder. When you do a lot of welding on one side of the rear axle housings, they will "pull in" from the welds shrinking and the outer bearing surfaces will most likely be out of alignment.
    You will likely have to heat/shrink the other sides of the bells to get them back into alignment. You may need to cut the ends back off the housings, put an alignment bar through the middle (that picks up the bearings surfaces of the carrier in the middle) and then re-align the ends and get things square again - before welding the ends back on. You'll probably be surprised on how much the bells will pull/bend towards the welds.
