Technical 272 Y block distributor
Discussion in 'The Hokey Ass Message Board' started by bathcollector, Jun 21, 2023.
  1. bathcollector
    bathcollector
    Hi guys, the rotor in my y block is a loose fit, moves backwards and forwards roughly 3/8 ". I bought a new one today hoping for a snug fit but it is the same. The shaft has a stepdown at the top, is there a clip or something I am missing ? It also drops a cylinder at times, but not sure this is related. Any ideas ?
    Thanks. Gary
  2. Budget36
    Budget36
    Is the shaft turning as well, or the rotor turning on the shaft?
    bathcollector likes this.
  3. Rocket Scientist Chris
    Make sure you’re getting the correct rotor for your distributor. The ‘57 and up distributors (vacuum/mechanical advance) use a different rotor than the ‘56 and earlier Load-O-Matics. I’m not sure if New Zealand and Australia Y-blocks received the distributor design change in ‘57 as the US Y-blocks. You’ll have to check to see what you have. Let us (or me) know if you need any help IDing your distributor! :)
  4. sunbeam
    sunbeam
  5. bathcollector
    bathcollector
    Just the rotor, shaft seems tight enough but has a step at the top. It's almost like there should be a spring type clip to keep it tight ?
  6. bathcollector
    bathcollector
    Mine is U.S built, has the 12200 style rotor. have just had a look in my Dennis carpenter catalog and it shows a piece between the rotor and shaft, part # 12213 but it is not listed, could be what I need ? I also have a 57 312 and the distributor is quite different to my F100 one, different style rotor.
  7. bathcollector
    bathcollector
  8. bathcollector
    bathcollector
    Ok, probably solved it. There is a clip that is missing the 12213 retainer clip. Will try my old Ford parts guy over here to see if he can supply one. Thanks for the replies guys.
    leon bee, Budget36 and dana barlow like this.
