Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. wheeldog57
    wheeldog57
    Out with the newer and in with the older, cooler, and almost fits the column bell 20230623_175617.jpg
  2. Nobey
    Nobey
    A Bird wheel, how cool....
    wheeldog57 and Outback like this.
  3. wheeldog57
    wheeldog57
  4. Tim
    Tim
    from KCMO
    So rad
    wheeldog57 likes this.
  5. wheeldog57
    wheeldog57
    Made a deal on a rebuilt 1950 255ci. Looking to slam it in the roadster in the next few weeks. Rebuilt by Phil Miller right down the street from my house.
    Going to be an adventure removing it, it's about 6ft to the left, hahaha 20240214_175752.jpg
  6. Squablow
    Squablow
    Who knows what other treasures you'll uncover once you start the excavation!
  7. wheeldog57
    wheeldog57
    A short block 57 283, v8 60, and a Rambler motor in there as well.
    winduptoy, Outback and Squablow like this.
  8. wheeldog57
    wheeldog57
    Felt kind of sad pulling out the motor I put together myself but. . . . . Got to make way for 255ci 20240308_173921.jpg 20240308_183258.jpg 20240308_203221.jpg 20240227_200059.jpg
  9. V8-m
    V8-m
    from Alaska
    I like the color... looks good !
    J.Ukrop and roadwarrior84 like this.
  10. Jeff34
    Jeff34
    Is it gonna fit with those 8RT pumps on the front, or are you going to switch them out for the shorter pumps and single crank pulley driving everything?
    winduptoy likes this.
  11. wheeldog57
    wheeldog57
    @Jeff34 nah, I don't think it'll fit. Looks like the belt will hit the distributor.
  12. wheeldog57
    wheeldog57
    Interesting. . . . . 7-25-73. 030
  13. Squablow
    Squablow
    .100 over! If that's correct, she's a bit bigger than 255 now. I've heard you can bore some of those blocks out .125 but you've got to check a ****load of them out with some kind of sonic testing or something to make sure the cores were perfectly aligned when it was cast.
    She's damn clean inside though, a sight better than the 255 Merc I brought home a couple years ago which had a very active mouse nest under the intake.
    Spooky, chryslerfan55 and wheeldog57 like this.
  14. wheeldog57
    wheeldog57
    @Squablow definitely clean inside, really looking forward to hearing this
  15. wheeldog57
    wheeldog57
    A couple years ago a fellow 'Snapper asked if I had a distributor hold down for an 8BA. Hes building a 28 RPU. I took it off the motor under the bench never thought about it. . . . Now I need one. So I made it.
    I don't even remember what it's supposed to look like but I bet it's something like this 20240327_193108.jpg 20240327_193509.jpg 20240327_194426.jpg 20240327_200227.jpg
  16. wheeldog57
    wheeldog57
  17. wheeldog57
    wheeldog57
    .100 x 3.75 stroke= who knows?
  18. Jeff34
    Jeff34
    Great work! Love the Merc...
  19. wheeldog57
    wheeldog57
    Offy intake has canted fuel pump mount where my old motor had straight mount.
    After much consideration I cut and welded. MIG was not happy on that alloy!
    20240328_192622.jpg 20240328_192651.jpg 20240328_201910.jpg 20240328_201914.jpg
    Now I have to figure out how to fill the oil, hahaha
  20. wheeldog57
    wheeldog57
    The fuel pump stand broke right off when I was stabilizing the motor on the hoist.
    But it's in
    Jeff34, Outback, brEad and 9 others like this.
  21. Tim
    Tim
    from KCMO
    One step forward two steps back seems to be the name of the game but it sure looks like you’re gaining ground!
    Outback, wheeldog57 and winduptoy like this.
  22. Spooky
    Spooky
    That 4 spoke wheel is killer!!
  23. NoSurf
    NoSurf
    Looking good!
  24. Jeff34
    Jeff34
    Yeah, MIG welding AL can be difficult. I'd TIG it myself, and I'd probably pre-heat the parts before I welded them. I've done that before with good results, especially on thick material.
    brEad and wheeldog57 like this.
  25. Chop50
    Chop50
    Hard work and dedication and you will get there!
    This a shot of my 29 Highboy 1970 after first layers of paint. Body was built of parts acquired from 6 different states. Friends John "Nick" Nericco, **** Royer, Skip Readio, and others lent a hand in locating needed parts.
    Outback, wheeldog57 and CSPIDY like this.
  26. wheeldog57
    wheeldog57
    I want to thank @Ryan for the nice write up about this thread. I am humbled and proud for the recognition. He took the time to read through this and post a synopsis about my roadster. He could have written about a half-million dollar 32 roadster being built at a top shelf shop but no, he picked
    MY roadster, put together from pieces in my 2 car garage mostly by myself and with the help of a few friends.
    This site is where I spend my screen time and to be acknowledged and recognized is an unexpected thrill for me.
    Thank you sir,
    Ron Wheeler
  27. NoSurf
    NoSurf
    Ryan could probably tell you are hoodlum....
  28. Outback, brEad and wheeldog57 like this.
  29. wheeldog57
    wheeldog57
    My new plan may require some TIG welding @Robert J. Palmer. I will reach out sir, thanks for the offer
    Outback likes this.
  30. lamaison
    lamaison
    from Canada
    Where did Ryan post something? Looked at all his HAMB posts I think and can't find anything (?).
    EDIT: Found it - it's on the JALOPY JOURNAL page.
    Outback and wheeldog57 like this.
