REDUCED! 1931 Model A Highboy Roadster, All Gennie Steel, Ford Motor, 5-Speed, Fresh Build
Discussion in 'Cars For Sale' started by missysdad1, Nov 6, 2022.
  1. missysdad1
    missysdad1
    City: Alvarado
    State: TEXAS!
    Price: 35000
    Fresh build but I can't keep em all. Built from a rust-free real steel Henry '31 Model A roadster. First-cl*** construction with excellent detailing throughout. Full build was do***ented in detail so there are no surprises.
    Update: You may be able to finance this car with good credit. Here are some recommendations for cl***ic car lenders from Hagerty: https://www.hagerty.com/finance/cl***ic-car-financing/potential-providers
    Body: Started with a rust-free gennie Ford 1931 roadster body, door skins replaced, below-the-deck-lid panel replaced, damaged wheel well panels repaired. Paint is single-stage urethane in bright Pin Up Red, a standard color from Eastwood so it is both durable and easy to repair/touch-up should it be necessary.
    Frame: American Stamping rails, Model A front crossmember, flat c-channel rear crossmember, Pete & Jake's tubular K-member ***embly.
    Suspension: Front: 4" dropped Super Bell front axle w/ aftermarket spindles and roller kingpins, Pete & Jake's forged 2-stage dropped steering arms, Vega-style steering box w/ SoCal steering damper. Rear: Mustang 8.8 rear axle w/ new Ford Racing 3.73 posi gears, Aldan coil-overs and Mustang-style tubular 4-link.
    Engine: Ford 302 HO with high-performance cam (specs unknown), stock HO heads, aftermarket chrome 3x2 Thunderbird-style intake manifold and progressive throttle linkage, 3 Ford Motorcraft 2100 carburetors with authentic Thunderbird air cleaner, lakes-style headers w/ under-body exhaust pipes and Smithy mufflers and tailpipes which exit below the rear spreader bar.
    Transmission is a Mustang-style Tremek T-5 five speed manual with Steeda Tri-Ax shifter and Hurst short stick ***embly. Clutch is HD Ford with hydraulic slave cylinder.
    Brakes are GM "metric" mid-size discs in the front from Speedway, rear discs are Mustang 8.8 factory discs. The brake master cylinder is a dual unit from a 1960-62 Chevy C-10 pickup which also includes the master for the hydraulic clutch. The brake/clutch pedals are suspended from the firewall on the inside, the gas pedal is adjustable for throw and position to suit the driver.
    The interior is done in black pebble grain vinyl with Austin Healey-style bucket seats and rubber truck mat floor covering. Steering column is a Speedway "Nostalgia" with functional turn signals and horn, topped by an aftermarket 15-inch '40 Ford-style steering wheel. Gauges are matcing Stewart-Warner electric including the tach and pulse speedometer. All the switches are mounted out of sight behind the dash panel so none are visible.
    The fuel tank holds approx 15 gallons and is located in the trunk along with the battery. The fuel tank is sealed so there is no danger of fumes entering the car. The radiator is a Mustang-style unit of br***, not aluminum and cools the car adequately even on hot days. The cooling fan is engine-driven. The wiring is via a skillfully installed Speedway Motors 12-circuit mini-fuse wiring kit.
    I'm open to close offers, but please don't be insulting. Might be interested in an unfinished roadster project car trade-in plus cash. I don't need pen pals, so please respond only if you are seriously interested in buying it. Thanks!
    (More photos to come. Click on each images to make it larger to appreciate the detailing.)
  2. missysdad1
    missysdad1
    First-cl*** workmanship throughout! Still available!
    catdad49 and SteveV like this.
  3. missysdad1
    missysdad1
    If you are tired of looking at poorly built and poorly detailed cars, take a look at this one. It's as nice underneath as it is on top. It's a total quality build that is fairly priced.
    catdad49 likes this.
  4. missysdad1
    missysdad1
    This car feels more like a sports car thanks to the all-business upholstery, aircraft-style belts, short-throw shifter and Cobra-style bucket seats. Still available.
  5. missysdad1
    missysdad1
    Doors close with a satisfying thunk, seat belts are aircraft-style from Juliano's, the deck lid is opened by an old-school electric solenoid (with a manual back-up just in case) and the Pin Up Red paint is unmistakable. It could still be yours...
  6. missysdad1
    missysdad1
    Be ready for roadster season next year with this top-shelf fresh built traditional-style '31 Model A on '32 rails with a Ford 302 HO engine / 5-speed. It's quick and fun and not over-the-top fancy. Still could be yours. :)
  7. missysdad1
    missysdad1
    Christmas is upon us and this cool little red roadster still doesn't have a new home. So...keep in mind that Spring comes after Christmas, and Roadster Season comes right after that. So it's not too late!
    VF-1 and catdad49 like this.
  8. missysdad1
    missysdad1
    Merry Christmas! Your Christmas present is still here. Just sayin'. Remind your wife...
    Ulrich Wöckener likes this.
  9. missysdad1
    missysdad1
    All this pre-Spring warm weather just gets ya' itchin' to head out in your roadster, doesn't it. Oh...you don't have a roadster...?
  10. missysdad1
    missysdad1
    Real genuine Ford steel body, pro-built '32 frame and ch***is, Ford smallblock with 5-speed, carefully and meticulously built, finely detailed. What else could you ever want? Still available.
  11. missysdad1
    missysdad1
    Built very much in the theme of traditional roadsters from the '40s and '50s, this car is a blast to drive as well as being truly eye-catching with its lipstick red color and aggressive stance. Recapture what it was like to drive a real hot rod! Still available!
  12. missysdad1
    missysdad1
    Still available!
  13. missysdad1
    missysdad1
    Roadster weather is on the way! Be prepared! Still available!
  14. missysdad1
    missysdad1
    Still available!
  15. missysdad1
    missysdad1
    It's almost roadster weather! Don't wait until it's too late! Still available!
  16. missysdad1
    missysdad1
    Immaculate workmanship throughout, 5-speed Tremec manual transmission, 8.8 Ford rear axle with 3.8 Trac-Loc positraction rear gears, 4-wheel disc brakes, Mustang-style large diameter tube 4-bar rear suspension with coil-over spring/shocks for great ride and handling. Still could be yours!
  17. missysdad1
    missysdad1
    Still available. Soon to be listed on the HAMB Auction Site. Get it now before the price gets bid up! Great car, very good price.
  18. missysdad1
    missysdad1
    Still available!
  19. missysdad1
    missysdad1
    Still available!
  20. missysdad1
    missysdad1
    This car is for the guy who wants something a little bit different in a roadster. Not the cookie-cutter street rod Deuce like everybody else's, but a hot rod that is hard-edged and real. Still available.
  21. missysdad1
    missysdad1
    Roadster weather is here! Don't let it go to waste! This one could be yours!
  22. missysdad1
    missysdad1
    Ooooo! Roadster Weather IS HERE...and you don't have a roadster? Well, here's your chance! Still available!
  23. missysdad1
    missysdad1
    All Henry Ford steel, three deuces and a 5-speed, first-cl*** workmanship, ready to go! Enclosed shipping can be arranged. Life's too short to live it without a roadster. Don't miss it! Still available.
  24. missysdad1
    missysdad1
    Just in time for warm-weather cruising. Sell your old coupe or sedan and enjoy summer with an open-air hot rod! Still available!
  25. missysdad1
    missysdad1
    First-cl***, professional quality construction and detailing throughout. Quick and fun to drive. Ready for roadster-weather cruising. Still available!
  26. missysdad1
    missysdad1
    Still available!
  27. missysdad1
    missysdad1
    This hot rod is a little bit different (!) than your ordinary, every-day, run-of-the-mill "street rod" roadster. No fluffy upholstery, mega-watt stereo or pansy hide-away top, this one is more like a sports car. It has only what it needs to go fast, handle well and stop safely. No fancy stuff or useless bling. It's serious business.
  28. missysdad1
    missysdad1
    Summer cruising season is here! Too bad to miss yet another summer without a roadster. But you don't have to. You can sit yourself behind the wheel of this one and enjoy every minute of it! Still available!
  29. missysdad1
    missysdad1
    The world's reddest SBF-powered Model A still homeless... Enclosed shipping available. Don't spend summer without a roadster this year! PM for more information.
  30. missysdad1
    missysdad1
    Roadster season is HERE! Don't miss out on another great summer without going *******!
