Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. shart1079
    shart1079
    Drove from St. Louis to Minneapolis for Back to the 50s. Long drive with no AC and 3 females…
  2. Grandadeo
    Grandadeo
    swade41 likes this.
  3. choptop40
    choptop40
    Liking the V8 Vair. Bucket List .. he he
    hrm2k and lothiandon1940 like this.
  4. Pontmerc
    Pontmerc
    from Finland
    Cosmetic restoration.paint cleaner and valve covers, redoing all wiring.
    Now it should p*** historical vehicle inspection.
    Here it not have to be 100% original but it should look like it.so no worries about trifive radiator.
  5. Pontmerc
    Pontmerc
    from Finland
  6. Pontmerc
    Pontmerc
    from Finland
    IMG-20230625-WA0003.jpeg Just cruising, but what the heck.share this picture from my front yard.full size american fords all the way.
  7. guthriesmith
    guthriesmith
    I’m just hoping I have something to add to this thread soon. The key word missing in most of what I have been working on is “your”. I think I have worked on everything but my junk for quite a while now.
    hrm2k, TrailerTrashToo and Grandadeo like this.
  8. guthriesmith
    guthriesmith
    Well, spoke too soon I guess. Decided to get the GMC at least pushed in the shop so I can get started.
  9. swade41
    swade41
    from Buffalo,NY
    Trying to figure out this lower radiator hose, cutting up hoses and sticking them together, got the shape now I just have to make it for real.
    20230624_202829.jpg 20230624_205245.jpg 20230624_205233.jpg 20230624_205223.jpg Screenshot_20230625_162827_Chrome.jpg
  10. 67drake
    67drake
    from Muscoda WI
  11. choptop40
    choptop40
    Didnt buy parts i dont need...caring for a relative and sitting around is tempting to buy ****,,,Not gonna happen...
  12. lake_harley
    lake_harley
    After a few mild test p***es a few weeks ago I blew my FED apart to clean sandblast and paint everything. There's just a few niggling things remaining to take care of but otherwise it's ready to go to the track again.
    From an ***ortment of tubing on the floor to what you see here took about 20 months.
    Lynn
    IMG_20230701_145912539.jpg IMG_20230701_145925516.jpg IMG_20230701_145943281.jpg
  13. rob-redm
    rob-redm
    finally got my heap out of the garage...and to caffeine and gasoline at Griots Garage Saturday ( All American Theme for July) GRIOT 36.jpg only three pre-1940 cars there.. mostly muscle cars and late model Vipers, Corvette, Cadillac, New Challengers , Chargers
  14. swade41
    swade41
    from Buffalo,NY
    Holding water for 3 days, started making battery cables and the wire from alternator back to cutoff switch, after that transmission lines, gettin close to making some noise
  15. alumslot
    alumslot
    I would think it would make some VERY good noise.
    swade41 likes this.
  16. nunattax
    nunattax
    started a bracket for my firewall to mount a breather catch can.little tech tip dont rush into placement . upload_2023-7-8_17-58-47.jpeg a cool breeze killed the shine on the back of the bracket.will mount it on the firewall unsure how high up to place it any comments on where it will work best high or lower.its all black on a black firewall with black hoses on a black engine with black aluminum finned covers should blend in
    j hansen likes this.
  17. charleyw
    charleyw
    Uncrated the new roadster motor. I've had it since March but have resisted the urge because I wasn't ready for it. I got over that! Old motor I had for it had been setting for quite a while, I got paranoid about it.
    I am impressed with BluePrint engines' crating, it was very well done.
    DenverFlash, bchctybob, 40two and 2 others like this.
  18. junkyardjeff
    junkyardjeff
    Fixed the temp gauge in the Sunliner,my dumb *** did not tighten the wires when I installed the NOS gauge.
    swade41 and j hansen like this.
  19. T. Turtle
    T. Turtle
    Totally boring but necessary, I changed to E10-compatible fuel hoses (thanks EU:mad:), bled the brakes and then struggled with the blinker switch for fu$/ing hours until I got the thing to work as it should (does "Chinesium" explains it?). Need to sort out some bad insulation on the wiring loom done by someone else, go for a test drive and then at last get the car inspected. Was all supposed to happen last month. Don't you love it when life happens.
    On a positive note I washed my rear light lenses. There are advantages to being old and ugly with no woman to bother you about such things.
  20. alanp561
    alanp561
    Mine would have gone in the dishwasher.:D
  21. T. Turtle
    T. Turtle
    Am too cheap to have a dishwasher :eek:
  22. High test 63
    High test 63
    Damn that chevy looks good!
  23. swade41
    swade41
    from Buffalo,NY
    I think you're right !
  24. nochop
    nochop
    from norcal
  25. 51504bat
    51504bat
    Single?
  26. TigerFan
    TigerFan
    from Athens, GA
    I cut out the steel for the front floor section for my roadster, rolled beads into it, and tacked together the cover for the rear crossmember. IMG_8427.jpeg
  27. gene-koning
    gene-koning
    Drove my truck 137 miles today. It was a great day to go for a ride! Didn't take a single picture!
    osage orange likes this.
  28. 57 HEAP
    57 HEAP
    Took a ride along the Blue Ridge Parkway in Carroll County and stopped at the Sidna Allen house for photos.
  29. choptop40
    choptop40
    Removed everything that was stored on top , inside , around the Desoto.. Getting ready to set SBC 350 engine back 6 inches minimum.. DEA5ACCB-7331-4C7A-B328-144081D6CCBD.jpeg
  30. T. Turtle
    T. Turtle
    Well I lied, because the blinker mechanism required yet another 3 hours before I finally go it to properly work by carefully heating it and arching it so that it puts enough pressure on the change-over contacts. Came back today with dealer plates I borrowed off a friend and took the car for a test drive and adjusting the brakes which I did at this place where the local farmers keep all manner of veggies (they usually lock it up because - surprisingly - people use it for drifting and stuff, but not this time). I think I got it to the stage where once the brakes are properly warmed up the car stops in a straight-ish line so hopefully I'll p*** the inspection next Thursday. I know this is a trad forum but there's a good reason why discs are better... Next year.
    Upon returning to base I discovered a screw securing one of the exhaust hangers to the ch***is rails departed us (inspection fail here in Austria) so found one willing to replace it.
    Other than the above everything else did what it's supposed to do, I have good oil pressure and the engine stays below 200°f, the McLeod 5sp does not seem to get hot or make really bad noises so maybe I'll get to enjoy the car this year before the big freeze.
