Hot Rods WCFB Dual Quads
Discussion in 'The Hokey Ass Message Board' started by slickmick, Jun 27, 2023.
  1. slickmick
    slickmick
    Are these two carbs considered a match set?
    Deuces likes this.
  2. Blues4U
    Blues4U
    from So Cal
    I don't believe those stamped or cast numbers are useful for identifying the carbs. The carbs originally would've had a br*** tag with a code held down by one of the top cover screws. If the tags are lost it's very difficult to know what you have, as I believe there are probably hundred's of variations of WCFB carb's.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Offenhauser intake manifold for early Oldsmobile.
    Deuces likes this.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    From the shape of the throttle arms and the fact that the carb on the left in the picture was never drilled for a choke plate, they look like Corvette dual quad carbs.
  5. Deuces
    Deuces
    My bad....:(
  6. bchctybob
    bchctybob
    I was wondering the same thing. I think the br*** bowl vent tubes look like Corvette too, and they have the large bases. The OP may have lucked out and got two Corvette dual quad carbs but that doesn't necessarily mean they are a "matched set". But they are a good start.
    51 mercules likes this.
  7. jimmy six
    jimmy six
    Appear real….if complete $$$$.00. Backwards on the manifold. The one without the choke plate hole is the most valuable. Lots of info on Corvette forums. See possible value on E bay…
  8. joseph kirch
    joseph kirch
    appears ok are they for sale
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I had a pair of WCFBs from a late '50s 'vette. I sold them to upgrade to a TR1.
    STOOPID
    SToopid
    stoopid
    427 sleeper likes this.
  10. jimmy six
    jimmy six
    Going to take quite a bit to make them like the high $$$$$ ones but so far what I see are standard choke parts needed.
