Technical ‘32 B engine oil breather cap leaking
Discussion in 'Traditional Hot Rods' started by DreamerJ, Jun 28, 2023.
  1. DreamerJ
    DreamerJ
    Hi, on my B engine, I have the stock oil filler tube and cap on the engine but while driving, the car likes to eject drops of oil out of the cap. It’s not a lot of oil but was wondering what the solution was for keeping oil from coming out the breather cap?
    I’m tired of a messy firewall and the occasional stink from it cooking off hot parts.
    Thanks, J
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Does it still have the mesh filter in the cap?
  3. rusty valley
    rusty valley
    does the motor have a lot of blowby ?
  4. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Does it have the right filler tube? The proper tube has baffles in it to prevent that issue. If nothing else works, try installing one of the road draft tubes available from Model A - B parts vendors. Check for proper cap, too. The one you show looks like a stock Model A cap.
    51 mercules likes this.
  5. DreamerJ
    DreamerJ
  6. '29 Gizmo
    '29 Gizmo
    from UK
    looks like it needs a gauze filter element in it like the later versions had.
  7. clem
    clem
    I doubt that the cap is stock.
    The bar code almost suggests a reproduction one…….
    Yes, - a gauze of some description would help.
  8. krylon32
    krylon32
    from Nebraska
    Good opinions here. Might also over on the Ford Barn?
  9. Andamo
    Andamo
    You might want to put some stainless steel mesh similar to a Brillo pad inside the cap. We used it as a demisting screen so that the oil vapors would condense on the mesh and turn back into a liquid and drip back down the pipe.
    51 mercules and BJR like this.
  10. The later B model has a longer and bigger diameter I believe the earlier had a longer tube but same diameter as model A
    the one on left is model A and right model B
    If you pack the cap you will probably start leaking out the rear main because of blow by
  11. Andamo
    Andamo
    The stainless steel I am referring to is like co**** steel wool and just provides surface area for the vapors to condense on. You're able to see light through the mesh so I don't see that causing any restriction causing a buildup of pressure in the crankcase.
  12. DreamerJ
    DreamerJ
    Thank you for the replies. I did find some online info about the larger diameter oil filler tube but no one sells it or it’s “out of stock”.
    Anyone on here have an extra they’d like to sell?
    or does anyone have photos of what my cap is supposed to look like with mesh?
    Note: my engine was recently rebuilt and in top top shape.
  13. AZ_Nick
    AZ_Nick
    If the engine is newly rebuilt the rings may not have broken in yet, creating the excessive blow by. Just add a copper scouring pad inside the cap and drive it like you stole it to get those piston rings settled in.
    DreamerJ likes this.
  14. X38
    X38
    For those that don't get into the kitchen much.
    Andamo and rusty valley like this.
  15. Try a wanted ad on Fordbarn.com. The correct one necks down where it goes into the block as shown on the right in post #7.
    Charlie Stephens
  16. dwollam
    dwollam
    Nobody reproduces the B filler tube. I looked long and hard to find some.
    Dave
  17. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    It looks to me like someone cut the tube down. The baffle should not be at the top of the tube. Try Berts in Denver for a used tube. A better cap would be a plus. The cap you show looks like the stock cap for a Model A. Put some steel wool in it but don't pack it tight. I definitely don't like the look of that tube and I think it's a big part of your problem.
  18. DreamerJ
    DreamerJ
    Thank you all very much. I’m going to get some copper wool but need to find the kitchen first….
    Will scour the interwebs for a filler tube too 70969498854__8944A97D-C2C7-45D4-AED2-BFBEE70C74A5.jpeg .
    Thank you!!!! My car thanks you also!
    '28phonebooth likes this.
  19. X38
    X38
    Is that a pun? :)
    Andamo and DreamerJ like this.
  20. brjnelson
    brjnelson
    I thought Bill Stipe Specialty Motor Cams made a filler neck and cap
  21. DreamerJ
    DreamerJ
    IMG_3896.jpeg Well, I metaphorically “stepped in “it” today”. Went to a friends house to rebuild a model a starter and he happens to have a unicorn in one of his many many many parts boxes. Like many of us, he doesn’t throw away anything so lucky me !!!
    '28phonebooth and Andamo like this.
