Hot Rods 35 Ford truck rear spring(s)
Discussion in 'The Hokey Ass Message Board' started by silent rick, Jun 28, 2023.
  1. silent rick
    silent rick
    did 35 ford trucks come with a parallel rear leaf spring set up?
    Are these them? Looks like a spring over axle, the pinch bolt has a square head and the nut on the other end is a long one with a grease fitting
  2. Single cross spring on 1/2 ton.
  3. twenty8
    twenty8
    1.5 ton and up have parallel leaf springs.
    silent rick likes this.
  4. krylon32
    krylon32
    from Nebraska
    I've done a couple 35/40 pickup ch***is using Ch***is Engineering bolt on parallel rear spring kits with 8 & 9 inch rear ends. I use the light duty kit.
  5. silent rick
    silent rick
    I knew there were kits available
  6. deathrowdave
    deathrowdave
    from NKy
    I built on news ago used 2wd OT , import springs and hangers , easy as anything worked as designed
  7. On my '38 Ford pickup (same basic frame as your '35, I got the leaf springs and torched the spring hangers off an '80 Isuzu pickup (Chevy Luv was same animal). Hung a Camaro 10 bolt on the Isuzu springs, worked well.
