Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. Ford blue blood
    Ford blue blood
    What a wonderful build thread! You have shown what perseverance, hard work and sticking to the task on hand can result in. No, not an award winning trailer queen but a piece of art that will bring many years of pleasure and a true sense of fulfilment for a job well done. Well done sir!
  2. 33Doll
    33Doll
    Thanks alot!
    If it weren’t for this Forum!
    Hardly anyone would even know!
    Thanks for the encouragement,
    Tips, and a common bond!
    Next goal get the lights installed hooked up, door latches fixed, gauges bolted down
    And….
    Get to Auburn cruise night July 14th!
    Stogy, brEad and Jim Bouchard like this.
  3. dwollam
    dwollam
    I think it looks fine like it is. Great job!
    Dave
    Stogy, Jim Bouchard and 33Doll like this.
  4. guthriesmith
    guthriesmith
    Man, car is turning out great! I really like your at***ude of getting it on the road and not worrying about it being perfect. They don’t stay perfect anyway if we drive them...which is what they are for. :cool:
  5. 33Doll
    33Doll
    AA59C843-22A5-4171-AAD0-77D9EBE24CC8.jpeg Ahhh….gee… fellas!
    Y’all are swell!
    Shucks!
    Stogy, brEad, Outback and 2 others like this.
  6. 33Doll
    33Doll
    5B012C45-B5DA-45D6-8800-5A8C9880F22D.jpeg So I read a while ago on some article about saving these old latches when the rivets loosen up, you can weld them so that’s what I did and it seems to work great now at least in the vice!!
    B72CF9A6-5C8B-459F-9FD9-C395D3F382C1.jpeg 9885F6B6-FD22-4A2A-B4C3-3169AA35763C.jpeg AFC8BBEC-42A1-4B85-A264-C8D114BEA6D0.jpeg 7C9574DA-40B6-4955-B60F-92617FEBBBDB.jpeg
    Stogy, brEad, Woogeroo and 3 others like this.
  7. 33Doll
    33Doll
    70BD4549-160F-4F55-B703-2F27B4C0417C.jpeg 38A4371E-5D30-4E44-924B-87D178DFB693.jpeg 55149B1B-106A-419B-9745-022277427146.jpeg F086CA2F-C3BD-4FBD-B3C4-F6DC4D50A526.jpeg 74A46A8A-8FEC-4EB6-BF9B-630EB2DE23E8.jpeg Multi-tasking…
    In between equipment maintenance.
    Shhhh.
    Put the driver door latch on last night with a new handle, painted and lubed and reworked the latch welded the old rivets to the door latch/striker.
    It worked good, it just seems like those Springs naturally are really stiff, which I guess is good to keep it from opening but I’m going to put on a safety latch anyway. so if anybody needs to fix the slop from the striker to the mechanism, it seems to work out well. If that makes sense?
    I also welded it on the edge too for back up.
    Stogy, dwollam and Jim Bouchard like this.
  8. 33Doll
    33Doll
    70935229-422A-48EA-89A8-FA9528DF1420.jpeg 15E9CA57-23DA-4734-B40A-AE17B7011BBC.jpeg 10A321ED-1B1C-4C66-A721-D6E33C40DBA4.jpeg 295DFB52-19D5-4BB2-AD80-A900E1D6EF17.jpeg Hey, question for you, Sparky types out there??
    My new tail lamps only came with two wires one for the high filament and one for the low filament (just need to figure out which one is which, before I hook it up)
    also came with a 12 V bulb and a 6 V bulb. Obviously I’m running the 12v
    So if I want a “really good” ground, is this a good idea? I just grounded it straight to the bucket, run it through the loom and then ground straight to the frame. My engine is grounded to the frame. My body is grounded to the frame, and the Dash is grounded to the body so it should give me a really good ground I would imagine?
    I’m just making sure that I’m understanding all this lighting wiring.
    Thanks.
    Stogy and brEad like this.
  9. 37 caddy
    37 caddy
    from PEI Canada
    I normally solder the wire to the tube that the bulb fits into,with the new housing the solder should be easy to stick.It is the tube the pigtail fits into that you want a real good ground on.The car looks really good,wish i could get mine to that state. harvey
    Stogy, Outback, brEad and 1 other person like this.
  10. 33Doll
    33Doll
    1387D257-FD2D-4F08-91CF-E5BC8D9F649D.jpeg 70697814-472A-47F7-9716-D6BBE297F858.jpeg 9753735D-E17F-4149-B957-D69C1699A5A2.jpeg D212A2BC-A18C-40BD-A80F-98D10F2B6D7C.jpeg 56926C4B-9B2D-4C02-9396-23950139959C.jpeg
    Thanks!
    I tried it on the battery and it works!
    Also, I learned something about the low element versus high element
    I thought that the articles I read literally meant the high filament was the high beams/turn/brake lights, and the little one was the tail light park lamp
    But when I tested it that shorter one was actually the brighter one and then I realized that is the one with the bigger spring/element that’s the brighter one!
    That’s how you learn right??
    Hard to see in the picture, but the taller one is the less bright one!
    Me thinks I gots it!!!
    Stogy and guthriesmith like this.
  11. 33Doll
    33Doll
    1460ECD9-252A-4767-9D3B-7113A6FCFD38.jpeg 5C0BF143-EC90-4534-9B38-C6FA381BF80D.jpeg 1EF8D09A-B4D2-480D-B86D-9EAD1D127AAC.jpeg Well… I think They are ready to go!
    I Like my new Chopped Powder coated
    Stalks way better than the original Long Chrome ones!
    Stogy, guthriesmith, brEad and 2 others like this.
  12. 33Doll
    33Doll
    We’ll see how far I get today before I melt !
    Bi polar weather here these days!
  13. 33Doll
    33Doll
    06ABB5FA-C5A6-4945-977D-87BE3DFA9336.jpeg FB0EFB7C-A6D6-45BF-97C2-6C20AD1DF7B7.jpeg 6ECCB61A-21BB-45CD-8ED6-786EE527ED67.jpeg D4CBBF0C-0F56-4F87-A4D3-9AFA9A4C3961.jpeg 5A90D84F-27B1-43CE-948B-FA952B942C7D.jpeg B8342618-B849-4383-B03B-A9AFEEC3A05A.jpeg 2A27690C-FBD2-4FE6-92E5-EB448059BE19.jpeg Got some stuff done!
    Doors shut like ****er!
    Mirrors on, park lamps, tail lamps.
    Just need to connect all lights up.
    Stogy, JalopyJimbo, brEad and 7 others like this.
  14. 33Doll
    33Doll
    Got the rear lights temporarily hooked up! So I know they work.
    got the Doll Plate on, and these cool “lightning Bug”LED fasteners!
    They make it super easy to have license plate lights. I think later I might drill out the skull eyes and put red LEDs.
    I think that would be kind of cool!
    787B31D4-9C55-4BCA-9E3F-C97D071E4266.jpeg AFD6260E-6DD8-41A2-8BAC-2DC8C9FEA848.jpeg 6EA35C1B-0F35-44FB-A4A5-B27136E5A53C.jpeg
  15. Ford blue blood
    Ford blue blood
    Those red eyes would be too kool!
    Stogy and 33Doll like this.
  16. 33Doll
    33Doll
    3ECE8F9A-6983-4950-80BE-716AF1759870.jpeg Playing with my phone editor!
    So I can do a screensaver on my computer.
    Stogy, Tim, JalopyJimbo and 5 others like this.
  17. Outback
    Outback
    from NE Vic, Oz
    Seeing where you started & where you are at gives appreciation for the journey & hard work.
    Stogy, brEad and 33Doll like this.
  18. brady1929
    brady1929
    Great job. You must be proud.
    Stogy, -Brent- and 33Doll like this.
  19. 33Doll
    33Doll
    5E01CCD2-223D-41D5-A00E-0FA8B31DACE6.jpeg 764D8512-094A-4AA3-97EC-953599185CA4.jpeg Thanks For the Kudos!
    Appreciate it!
    So… I’m trying to keep this thing at least 90%, 95% traditional but with all these LED bulbs nowadays and incandescent bulb being ****py!!
    I broke down and bought some LED Shortys for these front lights!
    Of course they were so bright one was yellow instead of orange or Amber!
    So what I did is, I took some red spray paint, mixed a little lacquer thinner in it and painted the white LED Cap translucent red! Can you tell which one is incandescent, and which one is LED?
    They Both Oran-ge! Now!
    Stogy, Jim Bouchard and guthriesmith like this.
  20. dana barlow
    dana barlow
    from Miami Fla.
    Leds are cute down there,but seems hard to see from a number of angles? Still far better then none. So good safety.
    The only thing in photo that dose look very off,is front rims are very far out side of were they should be= big scrub.* But someone may of talked about that already? I didn't look at all 41 pages.
  21. 33Doll
    33Doll
    The Wheels and drums are supposed to look like that. Its a late 60’s theme
    Munster-Barris era. They are only 4 1/2 inches wide
    I didn’t want the Cowl lamps on there.
    Looked to Resto-Roddish for me.
    But I wanted some turn signals up front so people coming towards me could see Which way I was turning.
    That is a REAL expensive Original Grille. Want to Make Sure There is no excuse for pulling out in front of me!
  22. 33Doll
    33Doll
    98BB58BD-D4A2-48AD-8F83-8A5F0BE7A2A4.jpeg 6A3BEC03-5854-48D3-A306-F754BB7ECA9E.jpeg AE8BCC6A-3211-43C9-B091-EDAF40434CCF.jpeg A1C558CD-CE6F-4588-9656-2CE26A9F742F.jpeg FCE1165A-8B98-4276-815B-90E10074C443.jpeg FB64C394-F331-47F6-97F2-3EDA2527BD48.jpeg E9E10503-5F93-42F2-929E-7F86F70946B7.jpeg Maiden Voyage to Get gas and back
    At night! Everything is working
    Stogy, simplestone, charleyw and 11 others like this.
  23. JalopyJimbo
    JalopyJimbo
    from NE Alabama
    Wooooohooo!!! Congratulations buddy! Its looking great!
  24. guthriesmith
    guthriesmith
    Very cool!
  25. Woogeroo
    Woogeroo
    from USA
    Always nice when the wife and the mistress can get along. :D
  26. 33Doll
    33Doll
    Ohhh… she is pissed at me!!!
    She caught me working on it. When I was trying to “incorporate” it with my yardwork. You don’t want to see a Latina woman get mad!!!
    So I was extra good the rest of the evening!
  27. 33Doll
    33Doll
    Made it to Work! No issues!
    Supposed to be in the 90’s today
    We will see how the old flatty is on the way home!
    Stogy, dumprat, Outback and 8 others like this.
  28. brEad
    brEad
    Looks good out in the wild! Just the right amount of tire poke.
  29. 33Doll
    33Doll
    Well made it home!
    No real issues.
    -Gas cap leaks around corners
    -little grind between 2-3rd
    Probably need to adjust the clutch a bit
    -Ran 150 in the morning 180 in afternoon at 90 outside
    -And 190 on the freeway at 60mph
    For 8 miles Flat Road
    Not sure about 100 + weather yet
    Stogy, brEad, dumprat and 3 others like this.
  30. 33Doll
    33Doll
    Yeah! I think I achieved that look I was going for without it looking ridiculous!
