Hot Rods Unsplit bones with a spacer.
Discussion in 'The Hokey Ass Message Board' started by lothiandon1940, Aug 4, 2015.
  1. lothiandon1940
    lothiandon1940
    I've seen folks put later V-8s in early Fords and instead of splitting the wishbone for clearance they simply use a spacer of sorts at the ball end to gain the needed room. Is there a name for this process or the spacer itself and wouldn't this put some bind in the perch pin to axle connection if no other modifications were made to the wishbone? Would this also change even incrementally the degree of caster of the axle?
  2. AVater
    AVater
    Adding spacers would change caster and may pinch as you noted. I was once told spacers were used back when to make adjustments in "regular" cars and have a couple I picked up in flea markets and kept on hand in case. I do have an unsplit 33 wishbone on my AV8 using a Tardel K member and did not have clearance issues.
    lothiandon1940 likes this.
  3. Hackerbilt
    Hackerbilt
    Like 3 and a half feet from the ball to the axle on a 32. I wonder how much you would have to drop the ball to make the caster change just 1 degree? I bet its a lot more than you might imagine...
    Edit...just did the math...(I think!) and its actually less than I thought it would be. Seems like dropping 3/4" would increase caster 1*...if the wishbone were 42" from ball to axle. I actually expected more than that would be required!
  4. mgtstumpy
    mgtstumpy
    Having never done this myself, to compensate for the slight increase in caster, a similar angled wide but comparable wedge between cross member and spring to spread the load evenly. The wedge could compensate and remove the additional load on the perch and shackles.
    alanp561 and lothiandon1940 like this.
  5. lothiandon1940
    lothiandon1940
    Thanks guys for the responses.
    brady1929 likes this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Don,I fabricated a 1" spacer to drop the wishbones on a 39 standard coupe to clear a FMX transmission back in the 70's.
    I never experienced any adverse effects and think it actually handled better. HRP
    4ever18 and lothiandon1940 like this.
  7. dakotajayne
    dakotajayne
    from 3c1
    I used a 1" spacer on my '40 to clear a C4/302 combination. It did not have an adverse effect on handeling and may have been better with the caster gain. A .733 spacer on a 42" wishbone increases caster 1 degree.
  8. Hackerbilt
    Hackerbilt
    Ok...I rounded it up to .750 or 3/4" because thats a commonly available plate thickness. Sue me! LoL :D
    BJR and lothiandon1940 like this.
  9. lothiandon1940
    lothiandon1940
    Thanks everyone for the responses. 1 degree of additional caster actually sounds pretty significant. Is typical caster of a stock, unaltered Ford axle around 6 degrees? Seems like I've seen people use square tubing as a spacer that may actually move the wishbone an inch and a half or more. Is that safe?
  10. millersgarage
    millersgarage
    Ch***is Engineering Inc used to sell a pre-made spacer. I do not see it in their catalog...
    I had one in my '47, did not notice any difference in the steering.
  11. AVater
    AVater
    I have heard 6 - 9 degrees pretty good--so this being said, you are in the right ballpark even with a change. Not sure about the square tube idea. Seems to me you would want something to seat well into the hole where the present wishbone ball/socket goes and then effectively move the wishbone hole down and reform the socket. Maybe I am not envisioning what you are thinking?
  12. 48 Ragtop
    48 Ragtop
    Get a Ch***is Ingineering [ FREE Catalog ] @ 319-643-2645
  13. It's going to put a little stress on the shackle bushings.
  14. lothiandon1940
    lothiandon1940
    Thanks guys. I'm not looking to do this to a car, just asking as I've seen it done on a few cars over the years that I've looked at considering to purchase. Never really knew if it was safe or effective or if it would be considered "half-*** engineering". Judging from the responses, if done well, it apparently has been done for years without any ill effects. No worse than other measures taken to achieve a particular goal.
  15. lothiandon1940
    lothiandon1940
    Thanks for the responses everyone.
    vtx1800 and brady1929 like this.
  16. BamaMav
    BamaMav
    from Berry, AL
    Don, I used another ball cup and a piece of 3/8” flat bar to make my spacer. Not sure how much it dropped it, but it is 1/2 of the ball thickness if that makes any sense. Both ball cups bolt to the flat bar, which is bolted to the cross member. It drives good.....
    cad-lasalle and lothiandon1940 like this.
  17. Nailhead Jason
    Nailhead Jason
    Don, Have been told by several people that spacing it down helps with higher speed (freeway handling) and helpd take a little strain of the steering box by making the steering wheel return a little easier. I actually have a spacer set up for my 39 and I am going to compare it with and with out and see which way it handles better.
  18. lothiandon1940
    lothiandon1940
    That's interesting, Jason. Please let us know the results of your comparison.
    brady1929 and OLSKOOL57 like this.
  19. scrap metal 48
    scrap metal 48
    I always ran my model A's at 7-9 degrees positive caster and they went down the highway very straight.. They were light and still easy to turn at low speeds....
    40ragtopdown and lothiandon1940 like this.
  20. Ever look at the front wheels on a 60"s rail dragster? They must have run 15-20 degrees to get great straight line control.
  21. BamaMav
    BamaMav
    from Berry, AL
    Reason I did mine was whoever put the SBC in it originally had the transmission pan sitting on the bones! Being it is the late style spring in front, I didn’t have any way to split the bones, so dropping it was my only choice. When I put the SBF and AOD in, I mounted the trans as high as I could without cutting the floor, and gained another 3/4” over what I already had with the spacer. I don’t think the bones will ever hit the trans pan, but if I ever have to change the filter I’m gonna have to either pull motor and trans or drop the bones.
  22. ct1932ford
    ct1932ford
    I'm bringing this one back. I would like to get a bit more caster on my Deuce Coupe with unsplit wishbone and a 4" dropped axle. I happed to see a spacer in a vid of a car foe sale. Said it came from Ch***is Engineering , but have not been able to find it online. I know I could fab one myself, but would like to see a detail of one if available. May not be worth making. Anyone have information on this? Thanks.
    Ned Ludd, alanp561 and lothiandon1940 like this.
  23. krylon32
    krylon32
    from Nebraska
    I think when CE was sold to Heidt"s they discontinued most of the straight axle parts or sold them to other manufacturers. I haven't seen the spacer offered. It may not have worked for you as it was designed for fat fendered cars.
  24. ct1932ford
    ct1932ford
    vtx1800, NoRust, Ned Ludd and 2 others like this.
  25. krylon32
    krylon32
    from Nebraska
    The CE spacer I'm talking about was fabricated steel. The spacer you show should be able to be built by a competent local machine shop. I realize buying is normally cheaper than building.
  26. ct1932ford
    ct1932ford
    It looks like Heinzman Street Rods has something like it. I will check with them after the weekend.
  27. krylon32
    krylon32
    from Nebraska
    Heinzman part number AS2083 is the old CE part for a 41-48 Ford. Probably would no work on a deuce. I'd proceed in making the slick aluminum spacer you show in the above picture.
  28. slug
    slug
    That is a nice looking part. I've seen them made from another cap and some bent flat bar but this is nice. Interested to see what you find out.
  29. lothiandon1940
    lothiandon1940
  30. alchemy
    alchemy
    Personally I’d just use two caps and cut the spacer out of plate steel. As said above, about 3/4” drop will get you one degree.
