Technical Show me your inside rear view mirror!
Discussion in 'The Hokey Ass Message Board' started by lostone, Jul 1, 2023.
  1. lostone
    lostone
    from kansas
    Well I'm along ways off from needing one but it never stops me from looking for parts!
    So I need to find a rear view mirror for my 31 tudor, but I'd like to find an oem mirror not necessarily a ford or a 31 model. I just want something with that old oem art deco look.
    Next will be the dome light, again oem/art deco...
    So show me what you gots !
    dana barlow and NoRust like this.
  2. willys36
    willys36
    I used the Phord style on my Willys coupe!
    VANDENPLAS, Desoto291Hemi and lostone like this.
  3. winr
    winr
    from Texas
    1965 F100 original
    7.5" wide
    2.5 vertical
    5" from post to bottom of mirror
  4. NoRust
    NoRust
    For a dome light, I enjoy the styling of a 50's Nash unit.
  5. A 2 B
    A 2 B
    from SW Ontario
    I already had the stock mirror and replaced the broken gl*** with a repro from Mike's. I used a piece of sheet metal with a hole made to fit a time piece. The sheet metal is just sandwiched between the gl*** mirror and the bracket.
    The plan is to use one of my old art deco watches from the era to replace the quartz movement. DSC07546.JPG
    I have a pair of purple "***** lights" from the 50s stashed somewhere. They will be mounted on the upper kick panels instead of a dome light.
  6. denis4x4
    denis4x4
    from Colorado
    This is an original accessory…lots of reproduction mirrors with a clock out there. This one is windup with the Ford logo
    VANDENPLAS, lostone, A 2 B and 2 others like this.
  7. vtx1800
    vtx1800
    I had a 61 Stude Hawk mirror, very rusty chrome...I sandblasted it and painted it black to match the dash and steering column, I am happy with how it turned out.
    VANDENPLAS and lostone like this.
  8. Lloyd's paint & glass
    I didn't have a mirror for my 60 Chevy, so I was at the junkyard, found a basic looking mirror without all the fancy modern stuff on it, took a hammer and screwdriver and knocked it off the gl***, used some mirror adhesive to glue the tab in the correct spot and viola! Rearview mirror complete :D
  9. lostone
    lostone
    from kansas
    Thanks for the pics guys !!
    @willys36 I like the beveled edges !
    @NoRust like the art deco look of that light
    @A 2 B nice job on adding the clock !
    @denis4x4 that is a nice setup there, like it being oem too.
    @vtx1800 I never considered a dash mounted mirror, that opens up a few more possibilities.
    VANDENPLAS likes this.
  10. 302GMC
    302GMC
    from Idaho
    Guide Day-Nite, the amber version. Cadillac & Kaiser used them. HPIM4468.JPG HPIM4470.JPG
    Dman, lostone, VANDENPLAS and 3 others like this.
  11. Budget36
    Budget36
    I’ve a similar one around with a chrome bezel, the bezel is a bout an inch longer at both ends of the gl***, with a slide switch on each side. I think I took out of a 70’s Pontiac.
    lostone likes this.
  12. MCjim
    MCjim
    from soCal
  13. Just Gary
    Just Gary
    From my "good idea" folder:
    steadfast black 32 02.jpg 1926-Ford-Modified-Competition-Coupe-–-The-Peat-Bros-T-48-of-22.jpg 20190218_125439.jpg Famoso-Mob-27.jpg headliner-ring-brothers-recoil_main.jpg helmuth brothers 20.jpg
  14. Bob Lowry
    Bob Lowry
    mirror 3.jpg On my early Covette, it did not come with the day/night mirror. Wanted a correct, retro-style mirror
    that had that feature, so found a '53 Chevy mirror which did, re-threaded the post and installed it just
    like the original one.
    lostone, 302GMC, VANDENPLAS and 2 others like this.
  15. Packrat
    Packrat
  16. dana barlow
    dana barlow
    from Miami Fla.
    I use 2,a small round side one on post and a small one center top of windshield,, I don't care much for bigger mirrors. MarksPicof My rod.jpg
    lostone, 41 GMC K-18, Lil 32 and 3 others like this.
  17. Bandit Billy
    Bandit Billy
    This is a Hagen mirror in my 41 pickup. Small mirror, big field vision. I have matching peep mirrors on the doors.
  18. jnaki
    jnaki
    Hello,
    For most hot rods, any blind spots create a problem. The widest inside rear view mirror is selected for a better sight line to the rear. In my first Flathead 1940 Ford Sedan Delivery, the mirror was old and showed some discoloration in/on the surface. But, the view out of the rear window was virtually useless due to it being so high in the door. So, we did not pay much attention to it.
    The little outside mirror was also a view saver as it showed down the right side blind spot in the rear ¼ panel. That blind spot was over looked as we just loved driving the sedan delivery and it was a reliable car for our surf trips all over the So Cal coastline.
    When my wife and I got married and chose a 327 powered 1940 Ford Sedan Delivery as a project car, it needed a lot of detailing work and one of the things was a good clear interior rear view mirror. We did not care about the style, but wanted a wide enough one to cover the whole rear area. The wider unit covered the rear door window area, and the whole right side to the back, as much as we could see. At first, it was ok, but after a couple of years, we quit night driving due to the lack of vision on the outside rear view mirror.
    Jnaki
    So what did we get, a wide view inside mirror. We wanted to keep the stock appearance on the outside, so we had to work with the small circular mirrors. The one thing we did not notice as a problem was the inside mirror surface got cloudy and discoloration began in one corner and started spreading.
    We found out later that it was something creating problems with the silver in the mirror coating. It has been tested and proven that Ammonia infused window cleaner of any brand, like Windex with Ammonia was the direct cause of the leaking silver material inside of every mirror. Some mirrors look good new and stay that way for a while. But, as moisture detailing continues, those old Ammonia Windex sprays were used on all gl*** surfaces.
    The Ammonia compound + moisture/water does something to the silver and the discoloration on any mirror can be attributed to it.
    Note: My wife bought a new inside rear view mirror as a gift for me one year. My rear view mirror was so cloudy and discolored that it was not fun driving around. So, I installed the new spotless mirror. Then several months later, using the Ammonia Windex we all bought and used on gl*** started creating the discoloration, again.
    We switched to Gl*** Plus Window Cleaner. It looks like Windex with the blue color, but the buck stops there. The non ammonia window cleaner gets the mirror or gl*** surface cleaner than the Windex. We changed all of our sprays to Gl*** Plus for all of our hot rod mirrors and family road trip cars. To keep the household mirrors from de-silvering, we use Gl*** Plus, but LESS OF IT, due to the liquid spray.
    With the ever increasing road trips prior to the pandemic, good sightlines was mandatory again for comfortable driving anywhere. The Gl*** Plus liquid helped solve the mystery of the discoloration on/in those interior rear view mirrors.
    Note 2: If you use the same ammonia laced Windex on any gl*** surface only, it cleans well. But, if you use the same ammonia infused blue cleaner on mirrored surfaces, get ready for discolorations that will show up down the line. Whatever mirror you choose, when cleaning it, use less spray, and put it on a clean rag first, to wipe off the surface(s).
    I am still using the gift present, rear view mirror without any discoloration due to ammonia on gl*** surfaces, but less water/moisture from the spray. I spray it on a rag, then clean the mirror. The Gl*** Plus version is a good cleaner. We have a couple of bottles to clean surfaces and mirrors, just use less on the mirrored surfaces. Great commercials on TV, but ammonia infused window cleaners+ water/moisture ruins old mirrors for cars and inside the mirrors of the house. YRMV
    lostone, dana barlow and 41 GMC K-18 like this.
  19. Jim C.
    Jim C.
    Would you post a photo of your installed inside review mirror? Thanks, Jim C.
    lostone likes this.
  20. mr.chevrolet
    mr.chevrolet
  21. DDDenny
  22. 19Fordy
    19Fordy
    Here's an extra OEM 1940 Ford rear view mirror I have for sale.
    lostone likes this.
  23. woodiewagon46
    woodiewagon46
    from New York
    There is a nice selection of both interior and exterior mirrors called "Fatties" from Hagan Street Rods, www.haganauto.com, 888-464-2426.
    lostone likes this.
  24. 51504bat
    51504bat
    Think this from a Model A but not positive. Seems right in my '39 p/u/
    lostone likes this.
