Customs What do I add to make this look better?
Discussion in 'The Hokey Ass Message Board' started by BJR, Jul 2, 2023.
  1. stanlow69
    stanlow69
    Here is a good comparrision shot. WIDE white with wires. Wide whites. Blackwalls with wires and skinny whites. Scan_20221231 (4).png
    Sancho and 41 GMC K-18 like this.
  2. stanlow69
    stanlow69
  3. Hitchhiker
    Hitchhiker
    This is a perfect example of stance and wheels and tires making or breaking a car. It needs a major lowering. Slight tail dragged stance and white walls. Full caps or wires doesn't matter.
    Packrat, BJR, bchctybob and 5 others like this.
  4. Lower the car. Especially the rear.
    Has a hot rod rake.
    Skinny WWs on the wires or big WWs with caps like sombreros.
    Then look at some Watson paint jobs. Think g****vine.
    Lace and flake.
    WC145, BJR, Tman and 2 others like this.
  5. Joe Blow
    Joe Blow
    Roadmaster with a few of the things mentioned here......lighter blue, lowered, wheel covers and white walls.
    WC145, hrm2k, Rocket88NZ and 3 others like this.
  6. A Boner
    A Boner
    Can someone photoshop some whitewalls…narrow- medium- and wide? Most Kustom cars look best with whitewalls.
  7. In_The_Pink
    In_The_Pink
    There is no visible contrast--dark body, dark tires, and plenty of dark shadows in those spoked wheels.
    Wide whites would help immensely IMHO.
    BJR, Just Gary and 41 GMC K-18 like this.
  8. Get that rear low
    Outback, A Boner, Chavezk21 and 10 others like this.
  9. fourspd2quad
    fourspd2quad
    Some tasty flames, white to yellow to orange will draw the eye away from that ocean of blue. Compliment the flames with some wide whites and spinners.....and lower it.
    BJR and 41 GMC K-18 like this.
  10. OZCAST
    OZCAST
    White walls and pin stripes would look killer
  11. That is a lot of blue… It might be a candidate for scallops, or a darker colour below the chrome strip and a laced white top. When I took a short trip on the internet, my eye was drawn to this- different car and stance, but it does cut through the sea of blue. 0FE2D98C-D344-41FB-8819-43E71598E03F.jpeg
  12. 283john
    283john
    I'm in the thin white wall camp. With the wires. And maybe a mild drop in stance.
    Atwater Mike, BJR, Squablow and 3 others like this.
  13. 427 sleeper
    427 sleeper
    I vote for some bias ply Firestone DeLux Champion wide whitewalls, keep the wires, and possibly add the chrome trim in front of the rear wheel opening, below the moulding. Lowering the rear 2-3 inches wouldn't hurt anything either. :cool: JMO
    Whatever you decide, it's still a beautiful car.
    BJR likes this.
  14. Greg Rogers
    Greg Rogers
    Since you asked... I would put on the 3/4" whitewalls. As mentioned, paint some on and see how it looks. If you like then go permanent. That is a beautiful car!!
    BJR, Squablow and bchctybob like this.
  15. alanp561
    alanp561
    Not to put too fine a point on it but the way it is right now, it looks like my grandfather's Buick with nice blue paint and spokes :(. I'm not a fan of wide whites either but adding them and bringing it down closer to the ground would help. In the end, it's your call. :)
  16. Cooder2
    Cooder2
    from tejas
    ^^^this
    Atwater Mike, BJR and loudbang like this.
  17. texasred
    texasred
    from Houston
    lowered, 2 inch whites, and keep the wires if they are Skylark, also you did a great job on that car
    BJR and Just Gary like this.
  18. guthriesmith
    guthriesmith
    I think you would be amazed as others mention on how much changing to whitewalls will tone down the blue whether skinny whitewalls on the wires or wide whites with full caps. The blue just stands out more with the black walls and overpowers the overall look. And, very cool car you built as has also been mentioned multiple times.
    Cooder2, BJR, Dan Hay and 4 others like this.
  19. BJR
    BJR
    I am liking everyones help on this. If someone could photoshop some wide and then narrow whitewalls on my photo it would be very helpful. I don't believe I can drop the back very much without some major suspension mods. Right now I have about 3" of travel before it bottoms out, but I will look into it more. The front has been clipped with cut coils, but I could get dropped spindles. @themoose
    Cooder2, bchctybob, Dan Hay and 5 others like this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    just look at @rockable Buick..... no photoshop needed...
    clem, Outback, WC145 and 19 others like this.
  21. theHIGHLANDER
    theHIGHLANDER
    The wires with wide whites will look like "old man at a Buick meet" as we see all the time. @Pete Eastwood nailed it with that pic. The color is more 60s than earlier, so the narrow white is almost a must. I don't think a full drop is needed, just drag *** a small amount. The sedanette body already gives the illusion, and to see how much do it old school and drop 4 or 5 sandbags in the trunk. I'd bet 1" below level is near perfect. Fix it's tie and give it a carnation, ready for the ball.;)
    ebs121781, Packrat, Cooder2 and 4 others like this.
  22. I'd stripe it similar to this, but all over it, adding red and white stripes, leaving blue stripes.
    Tman likes this.
  23. Panel stripe it (with a very light gray with a blue or green tinge).
  24. BamaMav
    BamaMav
    from Berry, AL
    Your other left! Either the author was dyslexic or he was looking at a negative when he captioned that photo!
    BJR and alanp561 like this.
  25. Spex84
    Spex84
    from Canada
    Here's a quick n' dirty 'shop of the wide whites and caps, added pale gold on the rockers, dropped maybe an inch in front and more in back.
    Am I seeing what looks like tiger stripes/uneven coverage in the paint? If a total repaint is possible (or necessary), a lighter/less saturated/intense color might be better for a car this size, as demonstrated in the various photos others have posted so far.
  26. Stan Back
    Stan Back
    Can you still get Port-A-Walls?
    Moon discs belong on land speed vehicles. And the snap-on ones look phony.
  27. alanp561
    alanp561
    OH, dude! You need to start checking the labels on your medications ;)
  28. stanlow69
    stanlow69
    I`m left handed, so everything is backwards to me.
    Outback and BJR like this.
  29. That is great for Independence Day, but otherwise that is just mean.
    alanp561, RMR&C, Rocket88NZ and 3 others like this.
