Customs Oil Filter Relocation Kit & Manual Fuel Pump Recommendations - 1932 Ford Model A
Discussion in 'The Hokey Ass Message Board' started by Douglas R, Jul 3, 2023.
  1. Douglas R
    Douglas R
    OK, I need some help from the pros.
    I just put our rebuild SBF 302 into our 1932 Ford Model A the chassis. It had the following:
    - Performer 289 Intake
    - 1403 Edelbrock Carburetor
    - Manual Fuel Pump
    To accommodate the (new) Vega power steering box, I had to remove the Manual Fuel Pump, and Oil Sending Unit.
    What are the best options for both Oil Filter Relocation Kit and Electric Fuel Pump.
    Many Thanks
  2. gnichols
    gnichols
    from Tampa, FL
    There is a short oil filter available for these motors, but it still might not fit. I've heard them called police or interceptor filters, but don't have any part numbers for you.
  3. wheeltramp brian
    wheeltramp brian
    I've got a similar setup at work that I can get you the part number for in about an hour
  4. gnichols likes this.
  5. wheeltramp brian
    wheeltramp brian
    16883956419452272504378764431032.jpg 16883956634277042971338895060307.jpg here's the super short filter hope this helps
    Beanscoot, Desoto291Hemi and gnichols like this.
  6. dwollam
    dwollam
    So I gotta ask... Is it a '32 or a Model A? Can't be both, two entirely different cars.
    Dave
    sdluck, Desoto291Hemi and Budget36 like this.
  7. wheeltramp brian
    wheeltramp brian
    I don't know about the original posters car but the picture I sent is of a Model A coupe on a 32 frame 1688414887140760833574420044998.jpg
    2Blue2 and Douglas R like this.
  8. Douglas R
    Douglas R
    Thanks. I'll do some research.
  9. Douglas R
    Douglas R
    Model A Body on a 32 Frame
  10. Douglas R
    Douglas R
  11. Douglas R
    Douglas R
    Greatly Appreciate the Help and Assistance!!!
    warhorseracing likes this.
  12. @wheeltramp brian, is there enough clearance to remove the filter or do you have to raise the engine? I suppose you could shorten the threaded insert from the block but the picture leaves that image of having to raise the engine due to the proximity of the frame for future maintenance. If it sits low enough in the frame it could just be an anomaly but you are sure to have a mess on top of the steering box every maintenance cycle.
  13. dwollam
    dwollam
    Ok, that makes more sense! And looks and works well.
    Dave
  14. wheeltramp brian
    wheeltramp brian
    There's plenty of room to take the filter off. In the last picture it's on the last thread and there's still plenty of room 16884970216802421546450365819711.jpg 16884970485186130019673426438376.jpg 16884970722409205835906369873965.jpg
    Beanscoot likes this.
