Projects ***DONE!!!!*** The Cad Powered 1934 Ford 5 Window Project.
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Jul 2, 2023.
  1. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Awesome abone. Looking forward to it. So, what number model 40 5/w is this? #3?
    Stogy likes this.
  2. rod1
    rod1
    Oh Yeah. Nothing better. Abone said keeper.
    Stogy likes this.
  3. Roothawg
    Roothawg
    Glad to see forward progress on the Caddy.
    Stogy likes this.
  4. swifty
    swifty
    Looking forward to this build, I thoroughly enjoy your builds and the fact that you post them on the HAMB so that I can follow them.
    Do have some questions though.
    1. What is the TKX 5 speed trans and what did it come in?
    2. What happened to the 55 331 Cad block that you got for $100 and where did the 390 come from?
    3. What happened to the 33 5 window with the blown Pontiac, surely that was a keeper?
    Stogy, alanp561 and warhorseracing like this.
  5. AHotRod
    AHotRod
    Summer days drifting away
    To-ah! Oh, the summer nights
    Well-a, well-a, well-a, huh
    Tell me more, tell me more
    Did you get very far?
    Like does he have a car?
    Love the Coupe A-Bone :D
    "A-HotRod"- Glenn
    Stogy and jim snow like this.
  6. MMM1693
    MMM1693
    Great start! I like your plan, and don't stop now!
    Stogy likes this.
  7. One of my favorite builders is back at it with another bad*** straightforward hot rod build.
    BrandonB, Stogy, toptenmoe and 2 others like this.
  8. Rickybop
    Rickybop
  9. flamedabone
    flamedabone
    The TKX is an aftermarket 5 speed made by Tremec so dudes like us can do 80 on the interstate at 2200 rpms. I have the earlier version, the TKO in two other cars and they are fantastic.
    The 100 dollar 331 block is still living in the garage but is relegated to back up plan status. The 390 came from a '62 Coupe DeVille in a local boneyard and is beautiful inside and standard on the bore and crank.
    The blown 33 lives with a buddy of mine locally, so I get to see it at Hot Rod Lunch all the time.
    Thanks, guys for all the kind words, I hope it lives up to the hype...
    See ya, -Abone.
    bchctybob, Stogy, Blues4U and 14 others like this.
  10. flamedabone
    flamedabone
    Here is the car that gave up her 390. She came from Temples Auto Salvage in Batesburg SC. Fantastic yard with thousands of pre 1970 cars.
    -Abone.
  11. lo c dan
    lo c dan
    You build the coolest hot rods. .
    Stogy, seadog, Irish Mike and 2 others like this.
  12. AHotRod
    AHotRod
  13. Gary Addcox
    Gary Addcox
    Something really important is the center section being far enough back so that 5 spd overdrive trans will fit and you will love it when you cruise. 31" rubber connected to a 3.73 9" Ford will jerk you out of the hole yet slide down the interstate at 2,000 r.p.m.s turning 70 m.p.h. Our Deuce roadster highboy is set up with the same stuff and it's super on the highway and very *****y when the light turns green. Good luck, Bud. Don't be concerned about the soreheads on here with their flathead-powered, bar hopping rides ! You have one of Henry's finest body styles to ever see the road.
    bchctybob, Stogy, winduptoy and 4 others like this.
  14. Sinnful
    Sinnful
    I'll be watching this build also, as I'm gathering parts for my '34 5 window also. Sounds like we have the same ideas on some stuff. I have a Winters QC, '56 365 Caddy and will be running a Tremec TKK also
  15. y'sguy
    y'sguy
    from Tulsa, OK
    I still dream of building and owning a car like this. Since it probably will never happen I'll just watch here and live vicariously through what you are doing. Thanks for sharing and looking forward to you progress.
  16. swade41
    swade41
    from Buffalo,NY
    Looks good already
    Stogy likes this.
  17. D Newcomb
    D Newcomb
    Great; those Cads were easy to find in the 50's/60's, then forgotten. Newc
    Stogy likes this.
  18. NealinCA
    NealinCA
    Looking forward to watching this one come together.
    Stogy likes this.
  19. chicken
    chicken
    from Kansas
    Hell yes! Paint is overrated....make it RUN!;)
    Terry
    Jibs, Stogy and Primered Forever like this.
  20. flamedabone
    flamedabone
    Hey, Terry. On a completely unrelated note, you are the reason my Model A runs 10.50s not 11.50s.
    -Abone.
    NoSurf, bchctybob, Stogy and 6 others like this.
  21. Okie Pete
    Okie Pete
  22. toptenmoe
    toptenmoe
    Glad to see you’re still doing your thing!! You think like me. I still have wet dreams about the black car that went to Germany!! My favorite hotrod!!
    Stogy likes this.
  23. ***Area-51***
    ***Area-51***
    from Ohio
    @flamedabone I believe the TKX is available with wide or close ratio....any thoughts on what you will going with? rear end gear? tire size?
    Stogy likes this.
  24. flamedabone
    flamedabone
    I got the "normal" ratio transmission, whichever that one is. Pretty sure it is the same as the TKOs I run in my other cars, but either way I'm sure I will like it. The big deal to me is the tall overdrive so I can do 80 at 2000 rpm without having to change the gears in the quickie when I get to where I'm going. The rear tires are about 30 inches tall and the ge****t will be a 3.48.
    I had this same basic set up in my old '33 with about 700 horse and it was fun as hell. This little engine will make about half of that but should still be a good time. We'll find out...
    -Abone.
    ekimneirbo, bchctybob, Stogy and 11 others like this.
  25. Roothawg
    Roothawg
    Caddy’s rule.
    Jibs, Stogy, winduptoy and 6 others like this.
  26. ***Area-51***
    ***Area-51***
    from Ohio
    Sounds like an awesome combo....I totally get the desire for OD....brings a new experience to these old mill's we like so much... I've had my eye on those TKX trans for awhile
    Stogy likes this.
  27. Speedy Canuck
    Speedy Canuck
    There are some great build threads popping up on the H.A.M.B. lately. Looking forward to following this one as well.
    Stogy, Okie Pete and -Brent- like this.
  28. Rocky
    Rocky
    Classified Editor
    WTF???? A caddy-what? Oh man! You're killin me up in here. I thought we were Pontiac bros all the way. As slim Pickins would say........"I am depressed." I gotta go sit quietly now in the corner and digest this --this....
    bchctybob, Stogy, Blues4U and 5 others like this.
  29. flamedabone
    flamedabone
    We are still brothers, my friend. I still have Pontiacs in all my other junk. See you at MoKan????
    -Abone.
    bchctybob, Stogy, lumpy 63 and 2 others like this.
  30. kustomfordman
    kustomfordman
    I like this! I've recently gotten a bad itch for a 35-36 something 3-5 window coupe. This will scratch the itch for the moment. Looking forward to follow this build.
    Stogy likes this.
