Projects Glass '32 5 Window
Discussion in 'The Hokey Ass Message Board' started by Splitbudaba, Feb 6, 2017.
  1. Splitbudaba
    Splitbudaba
    Got back on the coupe. Fabbed and fit the seat brackets. Four bolts on each bracket bolt to the frame and I want to add 4 more that anchor to the body and floorboards . Heard that's good on a fibergl*** body. Picked up the freshly cut back and side rear window gl***. Time to clean up the openings, prime and set the windows. Have some hickory I plan to make retention blocks for the gl*** and mounts for the garnish trim. PXL_20230606_015049290.MP.jpg
    Tim_with_a_T, brEad, swade41 and 3 others like this.
  2. Splitbudaba
    Splitbudaba
    PXL_20230606_175957379.jpg My wife made me get DOT approved seat belts, so Schroth got the call. No on the submarine belt!!
    swade41, loudbang and big duece like this.
  3. Weedburner 40
    Weedburner 40
    Same seats Pete had in the Cal Kid. Comfortable once you get in them but a ***** to get in and especially out of.
    Splitbudaba and bschwoeble like this.
  4. Splitbudaba
    Splitbudaba
    They are comfortable, plus they came with upholstery, which is pretty thick. That's what makes it hard to get out of. Not the best but will do for awhile. I plan on making my own design bomber seats. These seats give it a drag car feel, which is what I have been going for! And it doesn't bother me if the are referred to as Tupperware seats!
    Just finished moving the seats aft another two inches. I am going to add more holes to the mount brackets to allow some adjustments. I am 6'3" and legroom is nice.
    big duece likes this.
  5. krylon32
    krylon32
    from Nebraska
    Splitbudaba; Good thing your so young otherwise you;d have a hard time getting in and out of the car.
    Splitbudaba likes this.
  6. big duece
    big duece
    from kansas
    Two best modern inventions... indoor plumbing and bench seats!
  7. Splitbudaba
    Splitbudaba
    Since it's fiber gl*** I can make it a roadster in 30 minutes with my Sawsall! Then it won't be!!
    Bandit Billy likes this.
  8. Splitbudaba
    Splitbudaba
    Parking brake handle gets in the way or I would have. The bench seat , not a ****ter! PXL_20230606_015049290.MP.jpg
  9. big duece
    big duece
    from kansas
    I remember (like) those seats too. My dad built a home made dune buggy in the 70s when I was a kid that had similar seats. 20230607_213955.jpg 20230607_214027.jpg
  10. Splitbudaba
    Splitbudaba
    Nice buggy, good memories too!
  11. Splitbudaba
    Splitbudaba
    Worked on the wiring a little tonight. Got the wiper motor working and started on the horn relay. All this stuff is from a 57" Chevy, the only difference is my line lock ****on will blow the horn!! Oh yeah, and we decided to sell our house. We are moving to Montrose,Colo. We lived there in the late 80's and early 90's. Still have some friends there, one of them has a nitrous fed, 462 bbc in his 68" Camaro with a light weight ch***is. Maybe I can tow him back to the pits after each run. That would be cool! PXL_20230705_020423821.MP.jpg
    lucky ink, The 39 guy, brEad and 3 others like this.
  12. Splitbudaba
    Splitbudaba
    Bought repop 32' Ford center hood hinge pieces, 2 sides and one polished center. So I slid in the hinge about 2" into the center strip. Cool it went in easy, but it only opens about 20 degrees. What's the deal, I thought they opened almost straight up. Anybody ever experience this? Help!!
  13. Splitbudaba
    Splitbudaba
    Well, got the steel hood trimmed, primed and temp fastened to the hinges. Wasn't sure if I would like it on or not! But I think I do! PXL_20230718_014544171.jpg PXL_20230718_014553458.jpg
  14. Bandit Billy
    Bandit Billy
  15. big duece
    big duece
    from kansas
    2014-02-01 13.54.20.jpg 2014-02-01 13.54.47.jpg 2014-02-01 13.55.05.jpg 2014-02-01 13.55.18.jpg
    Hood looks awsome! Here are some hood latches I made from scratch that are hidden.
  16. Splitbudaba
    Splitbudaba
  17. Splitbudaba
    Splitbudaba
    Just found a set of black leather V strap hood hold down kit with br*** fittings on ebay. The shape would be the same as the headers. Might look really cool?
  18. big duece
    big duece
    from kansas
  19. RockyMtnWay
    RockyMtnWay
    I’ve run both the limeworks style (with the banjo springs) and the ones made by the fella that sold on here (Eric, I believe his name was) and had only one little problem with them. I seem to get caught in rainstorms all the time and when the leather gets wet, it stretches out a bit. Would just unfasten them as they were drying and they tightened up again, but hood tops would move a bit (at speed) when they were wet (stretched out). They always held, but it can be a bit unnerving watching your hood lift a bit.:confused:
    Just my two cents. :rolleyes:
  20. Splitbudaba
    Splitbudaba
    Thanks for your 2cents. Good to know!
  21. Splitbudaba
    Splitbudaba
  22. big duece
    big duece
    from kansas
    I honestly don't remember the source for hardware dead bolts, but they are stainless. I don't recall buying them online, probably a local thing. I did make sure the hood lacing was in place. The new aftermarket hood lacing was tool "round" and flattened it by running through a slip roller to flatten it.
  23. 383deuce
    383deuce
  24. RockyMtnWay
    RockyMtnWay
    I’ve been considering the ‘dead bolt’ method for a number of years now and big duece has a great example of them on a flanged hood top. If you are using a standard type set of hood tops that have the hinge rod style hinge then something like the following in the pics might be considered. Credit to the fellas that designed/built them and I’ve ‘borrowed’ their pics.
    and I’ve seen those s/s deadbolts on Amazon.
    Hope these help.
    Cheers
  25. Splitbudaba
    Splitbudaba
    Big day today, had the coupe inspected by the Idaho DMV inspector, p***ed with no issues. Here's a pic of the inspector installing the vin tag. Step one complete, now to pay the taxes and get my ***le!
  26. Bandit Billy
    Bandit Billy
    Sort of like a Car Mitzvah. Mazel Tov!
    brEad and Splitbudaba like this.
  27. Splitbudaba
    Splitbudaba
    That's kinda true, it's been almost 13 years since inception!
  28. pprather
    pprather
    Congratulations, that's a big step!
  29. Splitbudaba
    Splitbudaba
    House is on the market! Time to pack and hope for a quick sale. We plan on moving back to Montrose, Colorado. Once there the coupe will get finished. For once money won't be an issue!!
  30. krylon32
    krylon32
    from Nebraska
    Good luck with your sale and move. I hold my breath every time I have one of my builds inspected for a ***le. When I started building hot rods in the 70's all I needed was a ***le application with a VIN number. They never checked the car. Now it's become a project. Fortunately I've always been in the same county and everyone knows me and I've never had a bad ***le to date. These days money is always an issue for me.
    Splitbudaba and brEad like this.
