Technical Has anyone ever tried temporary spare tires in place
Discussion in 'Traditional Hot Rods' started by senginc, Jul 1, 2023.
  1. Adriatic Machine
    Adriatic Machine
    When I was a kid I had a pair of these on the front of my Chevelle for months
  2. Beanscoot
    Beanscoot
    They'd be right at home on a Chevette.
  3. I would certainly trust them more than Cokers!
    '28phonebooth likes this.
  4. 34 5W Paul
    34 5W Paul
    from Fresno CA
    There are a few engineers in my family and I'm used to dealing with them. They're not all the same, but they are generally pretty smart and oddly curious.
    I'd say the shallow tread depth is a drawback, at 5/32 it's half of a normal new tire and only a couple thirty seconds from being "too shallow". I have a V8 sedan that isn't exactly light that I've used one on the right front a couple of times. Even though I intended to drive slowly, like the Nissan P/U driver I ended up going way over the speed rating. Gotta think the front end of my sedan was much heavier than the nose of your Shivvy.
    Running these bad boys is to me kind of like using tires past their expiration dates - some do, some never would. I think the engineers have built in much more margin of safety than is disclosed and the lawyers have made serious noise about the times something goes wrong.
    Have you seen the rechargeable battery fires and explosions thread? Make you look at your rechargeable differently.
    clem likes this.
  5. desotot
    desotot
    and the brakes failed :eek:
  6. Mr48chev
    Now i have to go out and look at the 39 year old skinny spare that I have kept around for my 48.
    It came out of one of the 84 Olds 88 sedans that my dad had and I carried it in the bed of the 48 for a long time. It did get me to the gas station a few times but I sure wasn't going to run down the road at highway speeds for a serious number of miles. Last time I checked on a new tire for that wheel I thought that it was priced under the "damn, that is a lot of money" pricing. This time around I plan to mount it behind the seat in the cab with a cover over it. Agreed that they would make real nice rollers for a project, 4 of them wouldn't take a lot of space in those bring your own rollers deals either. upload_2023-7-7_21-46-19.png
  7. hotrodmano
    hotrodmano
    from Norway
    Sure, if you want modern...but then again, you are at the wrong pages ;)...according to me he he.
  8. mrspeedyt
    mrspeedyt
    if the tire looks pretty normal on a stock rim... I think it would be fine at reasonable speeds.
  9. flynbrian48
    flynbrian48
    Having done plenty of pretty sketchy stuff over the years and lived to tell the tale, I can't believe anyone would seriously consider using them. They're designed, engineered, and manufactured for TEMPORARY use. It says so in big, BLOCK LETTERS RIGHT ON THE SIDEWALL. :rolleyes:
    Budget36 likes this.
  10. R A Wrench
    R A Wrench
    from Denver, Co
    After all of these opinions, let me add, have you checked on any motorcycle tires ?
    Beanscoot likes this.
  11. Stan Back
    Stan Back
    They're terrific for use while building/modifying a hot rod or race car. I've wondered thru the years why so many guys buy a whole set of new wheels and tires as one of the first things they've purchased for their new project -- working around them while fabricating and painting and finishing years later doesn't make sense to me.
    51504bat, Tman and Budget36 like this.
  12. GlassThamesDoug
    GlassThamesDoug
    Too fancy for a chevette owner...
  13. Beanscoot
    Beanscoot
    I don't think tires have expiration dates. They have manufacturing dates on them, and then it is a matter of debate and much argument about when to no longer use them on the highway.
    Sorry in advance if this now turns into a tire lifespan thread.
  14. Budget36
    Budget36
    I wonder if @senginc has made a decision yet?
  15. nobby
    nobby
    erm its the ply count
    hold a space saver tyre in one hand and a van tyre in the other
    the van tyre is 3 times heavier.
    oh and its 2014 when the auto manufacturers installed tire pressure monitoring in modern vehicles, now what is most disconcerting is.......
    post 2014 cars come with a can of squeezy cheese as the spare
    so you say to yourself, I am a saine person and I want to fit a full size wheel and tyre in my car
    now, tyre pressure monitor doofers mount onto the valve stem
    they have a unique valve stem to hold the pressure monitor
    the cars ecu is only looking for 4 signals,
    you can set the sensitivity of the warning light coming on or off.
    or, if you have 30 psi in all 4 tyres and you have the pressure sensors set for high or you have told the car you have inflated your tyres to 36 psi
    the light will come on, scroll through the settings in the menu for low, it goes out
    it goes out after a few miles, it is not instant.
    so, yes you can have a full sized spare from a 2013 model in the boot that is the exact same wheel and tyre, but sans sensor
    when you fit it the light will come on.
    end
    oh and in the Europe, now you cannot fit the car tyres to light duty vans, they have to have the C for commercial designation
    the germans wont even let you run a differing offset wheel
    993 porker 16'' 2 bit wheels, they fit the cup 2's from a 996 and its all messy
    talking of them porkers, what about the old pork spare space savers that you inflated - they were folded up on them selves, anyway, you couldn't then put the punctured wheel back under the forward bonnet or hood so had to put it on the back seat, which is nice
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    The OP decided 44 posts back that he was not going to use them.....
    SS327, Desoto291Hemi and TA DAD like this.
