Projects 1953 Dodge Meadowbrook Build
Discussion in 'The Hokey Ass Message Board' started by arthurC3, Jul 11, 2023.
  1. arthurC3
    arthurC3
    Just got this Club Coupe out of long term storage. Looking for the Gabriel/Monroe shock absorber numbers. Gyromatic makes it move! Flat six makes it purr.
  2. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    You can see if your local Napa can get you the shock numbers. Maybe try Rock Auto also. If they dont work out, you can take your dimensions and get on Monroes website and search the catalog. The only thing is finding a shock that fits is fine, but the valving may be wrong. Also, the stock shocks on the car were hydraulic not gas charged so there will be a noticeable ride difference there also.
    Share some photos! 218 -6 or upgraded to a 230 ?
  3. manyolcars
    manyolcars
    1953 Dodges never were traditional hotrods. Will it be a traditional custom?
  4. Hillbilly Werewolf
    Hillbilly Werewolf
    Does the shock go from lower to upper A arm?
    Look at a Monroe 5752. That is the front shock for a '50 dodge. They didn't change the suspension much on these cars until the mid 50s, when they moved the upper shock mohnt to the frame (a good upgrade)
    Only trucks and lowly Plymouths got the 217/218(canada). If motor hasn't been swapped, should be a 230. Driver side front of engine block has a number stamped that will tell you what you have ( most likely)
    Were shoebox ford's ever traditional hot rods in your mind?
    Because more than a few teenagers hopped those up and raced them back in the day. The Dodges and Plymouths were just the same, as attested to by many of the old "little mags" and the large supply of aftermarket performance parts made.
    Fords may have been the more popular choice, but the Mopar flathead made more power per cubic inch, and don't crack and over heat.
  5. Stan Back
    Stan Back
    . . . and the 53 Dodge had a hemi that was no slouch. My buddy had one with the Gyromatic (sp?) and it and my stick shift 51 Studebaker V-8 went back and forth. The Dodge dug out first and then I'd catch him while it took a minute or two to upshift.
    blue71c and Hillbilly Werewolf like this.
  6. Los_Control
    Los_Control
    from TX
    @arthurC3 congratz on the meadowbrook. Fun cars. The old flat 6 is a good engine.
    Since I have a truck I'm not familiar with your suspension. I just ordered shocks from Rock Auto for mine. You should be able to get part # or shocks there.
    For more information on your car, https://p15-d24.com/forum/4-p15-d24-forum/
    Is a pretty active forum .... We do not care what you want to do with your car .... drive it & enjoy it.
    blue71c likes this.
  7. In_The_Pink
    In_The_Pink
    Please share a pic or two when you can. Perhaps you've seen this '53 Plymouth Cranbrook out and about? I saw it in Germantown a few weeks ago:
  8. gene-koning
    gene-koning
    Well, almost... We want to hear what you want to do with your car, and we want to that you are driving it and enjoying it.
    If you have to put front shocks on it, moving the top mount off the upper control arm and onto the frame before you buy the new shocks would be a great move.
  9. AndersF
    AndersF
    On my 53 Coronet mid 60:s A-body rear shock absorbers fits right in to the rear axle.
    blue71c likes this.
  10. blue71c
    blue71c
    from Wisconsin
  11. bobss396
    bobss396
    I worked with a guy that had a '52 Plymouth. '68-ish Coronet shocks bolted wight in to it.
