Technical Need Help To Identify Fender Skirts
Discussion in 'The Hokey Ass Message Board' started by bustingear, Jul 11, 2023.
  1. bustingear
    bustingear
    Need Help To Identify Fender Skirts. These appear to be some late 1940's or 1950's Fender Skirts
    They are 34" long tip to tip. They are a bit taller on one end and measure 10 1/4" on the tall side. I have looked for stamps but don't find any. Thanks in advance
  2. Squablow
    Squablow
    Pretty sure these are universal overlay skirts, I've got an identical set. The giveaway are the spring steel rods on the ends instead of something that goes into a slot, these were made to fit whatever didn't have a body line in the way.
    Joe Blow likes this.
  3. Joe Blow
    Joe Blow
    49 - 51 Shoebox....Foxcraft.
    51 mercules likes this.
  4. bustingear
    bustingear
    I thought that but when i looked at shoebox skirts they come down much lower in the front and back?
  5. Joe Blow
    Joe Blow
    Just comparing, they look the same to me.....could be wrong - and the length is a little over 34".
  6. kls50
    kls50
    1949-51 Ford. Foxcraft
  7. bustingear
    bustingear
    Yep 49-51 thanks all
  8. kls50
    kls50
    I also wanted to add that the skirts I posted pics of fit my 1950 Ford. I think squablow is also correct that they may fit other cars. Any other thoughts?
  9. Squablow
    Squablow
    I had a box label from the original packaging of a set of these at one time that listed off all of the cars they would fit (some cars would only fit the lower trim level models, because a molding would get in the way), shoebox Ford was definitely one of them but there were a lot of cars listed. They basically fit anything that the skirts would cover the opening without hitting anything, the box may have even suggesting bending them lengthwise to make them fit tight against the body if need be. I wish I still had that label/list, it'd be helpful now.
    kls50 likes this.
