Technical Difficult to find leak
Discussion in 'The Hokey Ass Message Board' started by Bert Kollar, Jul 11, 2023.
  1. Bert Kollar
    Bert Kollar
    I have a small leak ( need to find ) coming from either rear main seal, hydraulic cutch throw out bearing, or brake master cylinder. All too close together to see. I figured I would find three leak detector fluids and find it easily. Problem is there are only two colors available and they seem to be vaguely close in color. There is a third color but it is water based and useless to me . Any suggestions
  2. alchemy
    alchemy
  3. saltflats
    saltflats
    from Missouri
    Just use the die in one at a time.
    51 mercules, X-cpe, egads and 2 others like this.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    Brake/clutch fluid is water soluble so should be easy to rule out
    427 sleeper and Scumdog like this.
  5. Scumdog
    Scumdog
    And the loss of fluid (or lack of loss) from the master cylinders would show where the problem was.
    egads and 427 sleeper like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, brake fluid has a distinctive taste.... kinda bitter. That is the easiest way to narrow it down
    It won’t kill ya, I’ve done it hundreds of times. Stick your finger in it and touch it to your tongue....
  7. da34guy
    da34guy
    The taste test will tell ya !!!!!!!!
  8. BJR
    BJR
    I had a friend that was addicted to brake fluid......... But he said he could stop anytime.:p:D:p
  9. alchemy
    alchemy
    Warning, don’t taste too much of the brake fluid. It’ll stop you up.
  10. goldmountain
    goldmountain
    Wash it good under there and see where it leaks.
    jaracer likes this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Cheborneck
    Come here
    (What)
    What that
    (I don't know)…
    bobss396 likes this.
  12. 427 sleeper
    427 sleeper
    Had a buddy that did that one time... Got a wicked rash on the inside of his mouth that wouldn't go away... without Penicilin. His finger damn near fell off, too! :eek:
  13. bobss396
    bobss396
    ... good thing we didn't step in it... :eek:
    Johnny Gee likes this.
  14. bobss396
    bobss396
    I gave up on mine for now. I believe it is oil pan related. I put in an extra valve cleaner breather so I'll see if it helps. 2x a year I wash the bottom of the car with Simple Green. Eventually I will have to pull the engine, for now I call the car The Exxon Valdez.
  15. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Are your hydraulic clutch and brake master cylinder levels gradually declining? They shouldn't unless there's a leak in the closed system.
    Whereas it's tougher to tell if your engine is leaking or just burning/consuming a bit of oil when looking at the dipstick.
    Other than the taste taste, brake fluid has a distinct acidic odor compared to petroleum oil.
    1oldtimer likes this.
  16. Jmountainjr
    Jmountainjr
    Used engine oil usually has a hydrocarbon smell, would be darker than clean hydraulic oil, and would be hot if just run. The hydraulic oil stays pretty clean, and depending on location, usually not hot. Brake fluid has a different viscosity and smell than oils and washes off with water. If you only use one dye color, pick one of the two oils to test.
  17. This ^^^
    Also it feels different and dries out your skin.
  18. guthriesmith
    guthriesmith
    This likely only works on traditional fluids? :rolleyes: I hear that fluids since 1965 might kill you... :D
  19. David Gersic
    David Gersic
    from DeKalb, IL
    Brake M/C level declines over time as the fluid compensates for pad and shoe wear.
  20. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    What engine are talking about? It could be leaking at the rear of the intake manifold. Chrysler 360 engines of certain years were notorious for leaking at that point. Lay some white paper on the floor under the bell housing after driving and leave it overnight. The color of the drip will give you a hint as to what leaks. More info needed.
    '28phonebooth likes this.
  21. Pav8427
    Pav8427
    Sounds stupid but works. Hose it off good and spray with Right Guard deoderant.
    The white film left behind makes it easy to trace leakage.
  22. Jethro
    Jethro
    How to taste fuel..
  23. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I heard it kills millions of brain cells though.............
  24. ekimneirbo
    ekimneirbo
    from Brooks Ky
    ^^^^^^^^Just pokin fun at ya MO...:D:D:D:D:D:D:D:D:D
    I gave up my brain cells to alcohol.........it tastes better too.:p
  25. Bert Kollar
    Bert Kollar
    The hydraulic throwout bearing and master seal will leak in the same place
  26. Bert Kollar
    Bert Kollar
    It's all brand new
  27. Bert Kollar
    Bert Kollar
    This is a brand new build
  28. spanners
    spanners
    Who doesn't remember that first time you tried siphoning petrol (gas) and copped a mouthful? I can still taste it 50 years later.
  29. 427 sleeper
    427 sleeper
    It probably tasted better with the lead in it back then! :p
  30. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Good point, I forgot about that! However, it would probably be much more gradual over months of pad wear compared to 24/7 leakage.
