55 210 Wagon Progress
Discussion in 'Off Topic Hot Rods & Customs' started by MP&C, Mar 24, 2013.
  1. MP&C
    MP&C
    We picked up the powder coated parts from The Shop at Shorty's, for re***embly we had ordered some replacement slotted oval head screws and square nuts in stainless so we could polish them up a bit for a bit of bling.
    And no job is complete without undergoing the close scrutiny of the quality control inspector...
    Stogy, D-Russ, Cosmo49 and 8 others like this.
  2. lothiandon1940
    lothiandon1940
    Love it, Robert. Great color choice. Very period perfect. Boss Lady has good taste.
    Stogy and MP&C like this.
  3. MP&C
    MP&C
    Thanks Don!
    Steering column one step closer to green paint...
    and blocked to 500 grit...
    Working on removing dings and refining scratches on the windshield trim in prep for polishing. These pieces are less receptive to using the DA due to all the creases, so we've resorted to wet/dry paper up to 2500 and then polish.
    Jared getting the hang of this stainless work....
    And for the other wagon, we went with a powder coat chrome finish to dress up that front dropped axle.
    And this is the second round of three coats of epoxy and blocking. Think this will be the last round, and then on to some silver base and blue kandy..
    Stogy, rod1, TFoch and 3 others like this.
  4. bobss396
    bobss396
    Has the cat laid claim to it yet?
  5. MP&C
    MP&C
    Inspection only at this point. Hasn’t camped out on it.
    Stogy, bobss396 and lothiandon1940 like this.
  6. belair
    belair
    Never fails to amaze. Loved the tail light/gas filler.
  7. bobss396
    bobss396
    Fold up an old towel and lay it on a lower shelf... and give him 10 minutes....
    Stogy likes this.
  8. MP&C
    MP&C
    He'd rather be up higher on the countertop where he doesn't belong.
    More work on the wagons. Jared and I continuing to repair some stainless trim. I was asked about our process, so here's a bit more detailed approach. But understand we are complete novices at this, so take any of this with a grain of salt.
    To start, some light scuffing in line with 1500 grit helps to highlight any rock dings in the windshield trim..
    Once any defects are identified, they are LIGHTLY tapped outward from the back side to bring the defect outward where it can be removed. Then 400 grit is used to remove the defect (and by default some of the adjacent material). So we want the defect to be pronounced outward, but not too much. Better to tap it outward in repeated steps than to go too far and create a stretch. I missed getting a picture before we started on this "rock chip"; this was after a few p***es with 400 on the 3M board (just above arrow).. It was tapped outward about 4 different times until we got it where the defect was sanded out.
    Back side that was tapped....
    https://www.youtube.com/shorts/BdSQMh6MOTU
    After removing all the dings, the surface was sanded working progressively through grits 1200, 1500, 2000, 2500, and then on to 3000 and 5000 trizact discs on the DA. Afterwards it was polished out on the buffer...
    Some parts painted green so we can continue with more ***embly...
    When we had mocked up the wagon frame we just had a 1/2” bolt stuck through the bottom of the pull handle. Now that we’ve got the frame back from chrome powder coating, it’s time for some final details. The bolt for the bottom of the pull handle needs to be an Allen bolt to match our kingpins, and we need one from each side to be symmetrical. A little late to thread any holes in the pivot piece, so we’ll go with docking hardware. A 1/2-13 bolt was turned down for 1/4-20 threads, and the opposite one drilled and tapped.
    An allen wrench in the vise holds the bolt for threading
    Bolt for the opposite side...
    Frame is all done but t******* the axles, now to finish blocking the epoxy on the tub.
    Stogy, TFoch, bobss396 and 3 others like this.
  9. MP&C
    MP&C
    Back to our stainless trim, we need to modify the upper door trim to hold our peep mirrors. We opted for the old school look of the peep mirrors but did not want to use the clamp on paint chippers. The front edge of the trim uses a machine screw through the door and into a nut plate. Our plans are to use a formed hole in the trim and use the hole in the door to attach the mirrors.
    As we had used the tail stock of the South Bend before with success, we made some press dies to match the mirror's stepped end and provide a flange in the holes for added strength.
    Trial test of the mirror, yellow rag hung outside the rear window for a more visible reflection
    Stogy, anthony myrick, TFoch and 6 others like this.
  10. bobss396
    bobss396
    Level of detail continues to blow my mind, great work on the trim, I have straightened all of it on my Ford and polished it... but worth it. My peep mirrors clamp on, only digs into the paint on the inside of the door frame.
  11. MP&C
    MP&C
    Thanks Bob!!
    Back on wagon duty, we've been continuing on stainless polishing. We had been doing some of the shorter sections by sanding on top of my 4 wheel shop stool as it has a nice flat top surface.
    Once we got to the longer sections of trim, this became too ***bersome, so some 1/2" MDF was repurposed as a "holding fixture" while we refined the damaged scratches and dings. A Black Diamond longboard was used with 500 grit PSA paper to highlight any low spots, high spots, or other carnage. Then some LIGHT DUTY metal bumping to address the issues and a repeat of the highlighting sanding. Once all the defects were addressed, we then worked progressively through 600, 1200, 1500, 2000, and 2500 w/d paper. Then 3000 and 5000 Trizact, and finally on to the buffer.
    A modification of our "fixture" to hold the curved end of the trim...
    https://youtube.com/shorts/tViITsStf_A?feature=share
    https://youtube.com/shorts/zYWU_zc4q1w?feature=share
    Jared helps out here to help stabilize the skinny trim and keep it from flopping around. Once quick mis-step at this point is about an hour minimum of recovery.
    Nice reflection of the door opener in the ceiling after buffing...
    trim clips added...
    ...and our driver's mirror added...
    Stogy, brEad, TFoch and 1 other person like this.
  12. rockable
    rockable
    Beautiful job, Robert! Don't you think leather gloves are a good idea when buffing? If that wheel catches that stainless, bad things happen quickly.
    Stogy, MP&C and lothiandon1940 like this.
  13. bobss396
    bobss396
    Good extensions on the buffer shaft, I have to make up some for mine, which is a Baldor. Right now the wheels are too close to the motor housing. I wear gloves too, really goes against the spinning-object thing but better than a nasty *** slice on my hand.
    Stogy, lothiandon1940 and MP&C like this.
  14. MP&C
    MP&C
    Thanks for the comments guys. Rock, I like to feel the heat in the stainless to better gauge they all are getting the same amount. Yeah, sketchy **** does happen, but I have better luck with control when I can better feel whats in my hands. Bob, those shafts have not been extended, that is the length they came. Baldor buffer motors..
    Friday night was paint night. We started with a coat of SPI epoxy thinned for sealing, then two coats of Galaxy gray shimrin basecoat, then 4 coats of Cobalt Blue Kandy, and two coats of SPI universal clear.
    First coat of Kandy:
    It was loosely ***embled Saturday morning and carried into the sunlight for pictures. The low morning sun was not enough to wake up the metallic in the basecoat, and this looks jet black.
    A bit later, it’s starting to wake up the blue….
    After wagon ***embly and photo op, we did some more Stainless scratch refinement... Two long pieces left to go. and one on order. Dana had taken one somewhere for straightening, and the results left us with a wrinkle and a crack forming. So that one's replacement is on the way from The Stainless Shoppe.
    Jared putting the eagle eye on the remaining stainless to find any defects...
    Re***embling the steering column after painting...
    some heat shrink was added to the harness to help prevent abrading against the steering shaft. Our steering wheel puller kit did not have the needed parts for compressing the spring for the ts cam/horn ring, so we made a push ring and modified some 5/16 bolts for the cause. Much cheaper than grinding on the snap on parts.
    Sunday morning we loaded up the wagon for it's maiden voyage, a shakedown run at Eddie's Brunch and Car Show, located at Bailey's Olde Breton Inn. This isn't a real large show (although it grows every year) but it's one of those must attends, and all the proceeds benefit our local Ho****e.
    Some takeaways on the wagon design, the pull handle length that was designed for a small child inside the wagon was too short for a 6' tall fella with a long stride. Felt like yap dogs at my heels [​IMG] . And I think the frame design may need air bags, where it did well on the pavement, there was quite a bit of drag (rolling resistance) with the gr*** up in the frame.
    *Car show pictures borrowed from FB
    Stogy, TFoch, lothiandon1940 and 3 others like this.
  15. MP&C
    MP&C
    Jesse Harris, a metalshaper local to me, did a recent video on using the TIG for performing spot welds. He was kind enough to send me the video so we could share it with others...
    Stogy, D-Russ, rod1 and 4 others like this.
  16. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Have not check in in a while. Workmanship as usual is over the top Robert. The side view mirror detail is awesome. Sadly, though anyone who has become accustomed to driving our late model daily drivers will find them totally useless. I have had similar style mirrors on a number of my hot rods and my 51 Merc and even the Factory mirrors on my 64 Marauder. and my off topic 6os era Mustangs and 77 Vette seem useless now. Lol Keep up the great work. If the Judges had even an inkling into all the one-off fabrication that looks like it is supposed to be there, this would be the next Riddler winner!!!! Have a great day. Larry
    Stogy, bobss396 and MP&C like this.
  17. MP&C
    MP&C
    More installing stainless trim. The screw holes for the beltline trim that wraps into the tailgate opening had been filled when we shaved the lead seams. So we used some tape to protect the paint as we aligned the side trim to the lift gate trim before drilling the holes.
    One piece to go on the left side, awaiting the trip from WI.
    Next, we attempted to install our vent windows in the "reconditioned" frames the owner had bought. Only we noticed they weren't so ready for installation...
    and bent...
    Well, since we're on a roll, lets check the stainless trim that divides the vent and side windows. This had been "reconditioned" and included with the bent and cracked vent frame. Looks like they just polished up the dents and scratches. Not going to meet our standards.
    So we media blasted the original frames, which had no damage, and dropped them off at the Shop at Shorty's for a Cerakote finish.
    Inspecting the stainless trim, we found the originals to be less beat up than the reconditioned stuff, so we opted to straighten out the originals. Here's a comparison of the trim, the two on the left are the reconditioned that had been polished right over the defects. The two on the right are the originals, the left of the two has had any dings/dents pushed from the back in prep for our refinement process. (except the one up top I missed) The right one has gone through our w/d 360, 600, 1200, 1500, 2000, and 2500, all done wet. There are some minor scratches still, so we'll go through this process once more prior to buffing to make sure we have a flawless finish.
    And a helpful hint for those who dabble in polishing stainless. We've all had occasion where the stainless slips off the buffing wheel, bouncing off the buffer shaft, causing another 2-3 hours to correct. We added a rubber grommet to cover the nut and a plastic end cap to cover the threads. Less chance of damage from those mis-steps.
    We did get some more chrome on the front. Look, no bolts!!
    D-Russ, brEad, Bcap55 and 9 others like this.
  18. Stogy
    Stogy
    Wow, better than the factory...top notch work @MP&C...every time I open this Thread it really amazes me of the diversity here at the Hamb...it's looking really sharp...
    TFoch, MP&C and lothiandon1940 like this.
  19. chopolds
    chopolds
    from howell, nj
    I am in awe!
  20. MP&C
    MP&C
    Picked up the vent window frames from The Shop at Shortys, done in a Gunmetal Gray Cerakote finish.
    and we got our final piece of stainless trim from The Stainless Shoppe...
    Packaged very well....
    Friday was our appointment for lettering the blue wagon, rode up to PA to HotRodJen's art studio..
    We opted for a script that deviated from the stock "decals", why hand paint something to match a factory decal? Let's go with looks fast while standing still...
    and re***embled for the trip home..
    brEad, bobss396, Stogy and 4 others like this.
  21. lothiandon1940
    lothiandon1940
    Hot Rod Jen is the Real Deal.:)
    brEad, Stogy and MP&C like this.
  22. MP&C
    MP&C
    More progress on the wagon, the green one, working on the parts so we can ***emble and install the vent windows. For our gl*** installation, we did things twice as the 1/16 rubber did not give a snug enough fit. So here is our second round using 3/32 thick rubber. One inch wide strips were cut out of the sheet and lubricated with an Ivory/water mix.
    The rubber was wrapped around the gl*** and it was pressed down inside the frame by hand. Then a "slight" squeeze of the frame to ensure it wasn't sprung open from the installation process.
    These got moved to the attic for a good heat baking (drying the soapy solution) and we'll trim the rubber flush with the chrome vent frame in a couple of days.
    Next, onto prepping the stainless trim for the vent windows for buffing, refining the scratches. Detail work like this is more difficult with parts flopping around in your hand, so some MDF was found the correct size (width) to hold the wide portion of the trim, and another piece of MDF was shaved to fit the narrow piece of trim. We should have these done this weekend.
    https://youtube.com/shorts/aXjasXvwN10?si=ag3weASGnXwPDeuK
    https://youtube.com/shorts/KaRW2OMmoUc?si=FeaHI9eAk13uNpS6
    Next, we picked up our battery, but the lifting handle bosses on the ends of the battery interfered with our OEM hold down.
    Not to be dissuaded, the belt file made short work of a shave.
    Luckily the mount hides our sanding marks. Much better down where it belongs...
    Like it's made to go there...
    brEad, loudbang, bobss396 and 3 others like this.
  23. patsurf
    patsurf
  24. MP&C
    MP&C
    Stogy and lothiandon1940 like this.
  25. MP&C
    MP&C
    Well in our typical back up and punt fashion, the original battery hold downs that we had already powder coated did not fit the battery, too short. So we ordered some round stock in stainless to fabricate some new ones.
    A threaded standoff was modified to provide an angled surface for using as a hammer form to get the bottom "hooks" consistent...
    All polished up...
    Installed, and no polish job is complete without addressing the ends of the rods..
    ***embling our vent windows, the excess rubber is trimmed using a No. 11 scalpel blade for a nice and tidy fit
    All the bits ***embled
    And more stainless we missed, the parting bands for the front arm rests, complete with a form-fitted sanding/polishing fixture
    fauj, brEad, safetythird and 5 others like this.
  26. belair
    belair
    Keep at it. When I read you were debuting the wagon, I thought I had missed a lot of pics. Wrong wagon. Lol
    MP&C likes this.
  27. MP&C
    MP&C
    Trying to ***emble the tailgate so we can put it on, but our latch actuator is absolutely worn out in the square hole, the handle just about rotates inside of it. They don't make repop's (that I'm aware of) and someone just offered a rebuilding service at over $300. So I reached out to my go to used parts outlet and a good used one is on the way, mailed the same day.. Reference photo:
    So while we're waiting on parts to load up the rest of the bits on the tailgate, lets chase the threaded holes....
    The console just got dropped off, we had some material in the corners that was pulling due to all the stretching that had taken place. In order to keep things more permanent, I came up with some 19 gauge stainless "trim lock". A hemmed edge helps keep from cutting into the upholstery. It gets clipped in place, shoved into the corner snugly, and through drilled for installing solid rivets.
    In order to match our dash insert, the console insert will also be oriented horizontally (lines left to right)
    We also got some of the stainless and chrome added to the front end. What an alignment pita that grill and surround is.. Still have some tweaks to do..
  28. lothiandon1940
    lothiandon1940
  29. chopolds
    chopolds
    from howell, nj
  30. bobss396
    bobss396
    Can we get a side shot of the car, other views? It has to be truly a work of art.
    brEad likes this.
