Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 57 Fargo
    57 Fargo
    I am sitting reflecting on the fact that my wife bought a car on an online auction….oh how I’ve ruined her…. IMG_5115.png
    ‘64 thunderbird for parts for the project car we are trying to buy…she decided since the kids all have cars I’ve done that she needed one as well. Hopefully I don’t have an allergic reaction to building a ford…:)
  2. 57 Fargo
    57 Fargo
  3. Those make nice customs
    and round trackers
  4. 57 Fargo
    57 Fargo
    Be a very mild custom I’m thinking
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Maybe it needs a mopar grille and headlights!!!
  6. 57 Fargo
    57 Fargo
    I’ll quote Rachel (my wife) after I read your post to her, “no, no it doesn’t”. She wants coral and is all in on lace panels on the roof
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    And panel striping?
  8. 57 Fargo
    57 Fargo
    I can try for that…Would be super cool
  10. 1971BB427
    1971BB427
    from Oregon
    Worked on a stranger's car today at a local cruise in a neighboring town. The guy was pulling away from the curb when something went "bang!" in his steering, and the wheel suddenly got very sloppy!
    I was standing very close when I heard it, so offered to ***ist him if I could. I always carry a tool bag with a good ***ortment of SAE, metric sockets, end wrenches, etc., to make fixes on the road. I had him work the steering wheel back and forth, and it move over a half turn with no response at the wheels! Looked underneath the front axle and when he turned the wheel the steering box came away from the frame!
    It was a cross steer with Vega box, and two of the three bolts had pulled threads from the Vega box! Grade 8 bolts, and the bolts were perfect, but the cast iron box threads weren't. I pulled one bolt, and told him there was an Ace Hardware store 5 blocks up the street where we could get parts to fix it.
    We walked up the street as I explained how we could do a permanent fix, and avoid this happening again, and not have to drill out the threads, or tap to 7/16" to fix it. We bought three Grade 8, 3/8" bolts that were 3/4" longer, plus 3 nylock nuts, and 6 washers. Headed back to his car and one at a time replaced the pulled bolts, plus the one good bolt with the longer bolts, using washers on both sides, and a nylock nut on the extended threads.
    When I got it done he tried the wheel and said it felt better than before the repair! I think his bolts worked loose and then turning the wheel let the box move which pulled the threads out. Should be great now and the locking nuts should eliminate future issues with loosening.
    Now I'm going to modify my steering box the same way tomorrow! Never had one come loose before, but I'm going to make it failsafe before it can fail!
  11. David Gersic
    David Gersic
    from DeKalb, IL
  12. choptop40
    choptop40
    i dont like Nylocks on steering stuff..Id go with the standatd lock washers like the factory does.....Lock***e if you really want to get serious..Just my 2 cents..
  13. Greg Rogers
    Greg Rogers
    Good on you BB427! Things like that make everyone feel good.
    1971BB427 and 427 sleeper like this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    picture it with the front from a 68 charger?
  15. 57 Fargo
    57 Fargo
    with hideaway headlights! Hmmmm, She gave me permission to change the rear lights to round.
    Okie Pete, 427 sleeper and Moriarity like this.
  16. Pontmerc
    Pontmerc
    from Finland
    Nothing really, drink beer and read 64 ford registered owners manual...sure interesting options where avaible... IMG-20230716-WA0007.jpeg
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    how about front and rear from a 63 Chrysler 300.... round tail lites like she wants and the mopar parts might make you like it more....
  18. 57 Fargo
    57 Fargo
    I actually don’t mind the impala lights, I have a ‘61 Chevy parts car with round taillights….hmmmm
    Also as long as @Moriarity doesn't tell anyone, I actually like the car, I just have very few Ford parts and know very little about them.
  19. 1971BB427
    1971BB427
    from Oregon
    He had standard locknuts and it didn't stop this from happening.
  20. nochop
    nochop
    from norcal
    Sheet steel rough in/pre ***embly IMG_5820.jpeg
  21. And just what, may I ask, is wrong with Fords? Hmm?
  22. guthriesmith
    guthriesmith
    Ford’s ****...but so do all the other old cars. :D
  23. You’re just upset because you don’t have one.
  24. lumpy 63
    lumpy 63
    Did I ever mention how much I dislike restorations? Spent most of the morning working on a 53 Pontiac . This thing is all stock with a flathead six and no I didn't build it:) Fired it up for about 30 seconds had no oil pressure... screwed a fitting into the oil galley above the pump and back fed oil into the system to prime the pump and then it had pressure. Then filled the cooling system with water to check for leaks.... had a small seep at one head bolt and when I fired it again it had water coming out of the exhuast:mad: After I shut it off it had a puddle of oil under the rear main. Owner is taking engine back to builder
  25. 57 Fargo
    57 Fargo
    Not a thing, I just have limited knowledge and parts for them.
  26. Dick Stevens
    Dick Stevens
    If you look at @guthriesmith avatar you'll see a 56 Ford, yes he does have a Ford!
  27. lumpy 63
    lumpy 63
    I think he has a little of everything ..... Missing the point of his sarcasm fellers:D
  28. guthriesmith
    guthriesmith
    Yea, that was a little tongue in cheek... Even though I grew up all GM, I actually have a few Ford’s even now. And, I might have been known to be sarcastic at times as well. :oops:
    Chavezk21, Okie Pete, BJR and 6 others like this.
  29. I can’t imagine why. He he.
    guthriesmith likes this.
