Hot Rods Flathead advice
Discussion in 'The Hokey Ass Message Board' started by hiboy32, Jul 16, 2023.
  1. hiboy32
    hiboy32
    from Omaha, NE
    I am trying to ***emble a list of cam and valve choices to build a badder flathead. I am looking for advice on what works to make more power. I have usually only ran over cammed mostly stock engines. I am hoping to run a large cammed flatty that might make a bit more power. This will be a bored and stroked 8ba
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    All the normal mods will give more power.
    The one must,,, is to be certain that the heads fit as close as possible ( .050 - .048 )
    Best way to measure clearance using little balls of tin foil to cleck clearance.
    Done right, one gets max lower end torque.
  3. hiboy32
    hiboy32
    from Omaha, NE
  4. hiboy32
    hiboy32
    from Omaha, NE
    I was actually only checking for enough clearance in the past. So is the 400jr still the right choice? or can I do better?
  5. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    In my opinion, ANY lift above 370-380 may cause interference with the spark plug and exhaust valve especially if the “hook” on the plug extends too deep in2 the chamber. Try and find a plug that fills or nearly fills all the threads in the head with minimal “hook” extending in2 the chamber. Newer heads are generally better than used heads because used heads MAY have been “cut” to maintain their straightnes(perfectly flat”) and could cause a problem regarding spark plug selection. Yes, the Isky 400 jr is a gr8 cam but could be troublesome because of the .400 lift. Also, be aware there is not 3-4-5 h.p. Difference between the more expensive finned aluminum heads and Henry cast iron. Yes, I prefer the alum heads because of looks and they are lighter than cast iron. If u choose aluminum heads, make sure u go to a boat shop and purchase a sacrificial anode that will minimize the corrosion(electrolosis of aluminum) when placed in the water supply system of your flathead. If not used, your heads will suffer extensive corrosion within five years. The anodes can be cut down and holes drilled in them with a 12-14 gauge wire to retrieve them from the water supply to s****e off the(barnacles) offensive corrosion and return to their place. IMG_2200.jpeg IMG_0272.jpeg IMG_1943.jpeg IMG_1901.jpeg IMG_1759.jpeg IMG_1621.jpeg IMG_1608.jpeg IMG_1609.jpeg IMG_1611.jpeg IMG_1493.jpeg IMG_0848.jpeg IMG_0723.jpeg IMG_0648.jpeg
    Desoto291Hemi likes this.
  6. RodStRace
    RodStRace
    Plenty has been written on various ways to increase power. It's pretty much the engine that built hot rodding. I'd offer a couple of points, even though I've never built one. This will apply to any engine upgrade.
    First, a candle that burns twice as bright lasts half as long is an old saying. Figure out what the intended use is and spend as much time on keeping it alive as hopping it up. Since this isn't a computer-locked whizzbang, get good at tuning. Old ****og engines require and respond to adjustments, both in power and longevity.
    Second, unless you are doing all the engine work, find a good reputable builder and follow their advise for the build rather than come in with a list of demands. They have been doing it longer and have a recipe or two that is known and proven. These will vary, but telling a pro what combo you want and how to do it is going to start the relationship off poorly.
    Just Gary likes this.
  7. hiboy32
    hiboy32
    from Omaha, NE
    my current setup is an older rebuilt 8ba with 400jr and Isky valve springs and a vintage Sharp heads. I am reusing the Sharp heads. This engine will be getting new valves and ported. Is the Chevy valves still good option?
