Projects 29 Roadster
Discussion in 'Traditional Hot Rods' started by imtb, Jul 16, 2023.
  1. imtb
    imtb
    from St. louis
    Picked up this non running 29 A roadster. found some 35 wires and ordered new tires. Got it running with fake stromberg. Cast iron header and new exhaust. Going for vintage speed. Planning on lower back 2”.
  2. MojoRacing
    MojoRacing
    Nice! That's a good looking car!!
    Stogy likes this.
  3. ironandsteele
    ironandsteele
    Cool Roadster.
    ironandsteele.com​
  4. Rickybop
    Rickybop
    It's hard to imagine such a nice looking car being sold in non-running condition.
    Looks great.
    Good for you.
    Stogy and lothiandon1940 like this.
  5. mvee33
    mvee33
    A black standard 29, very nice, congratulations.
    Stogy likes this.
  6. Squablow
    Squablow
    Great looking car, I like what you've done and I like the plan.
    Stogy likes this.
  7. brady1929
    brady1929
    Nice roadster.
  8. 51 mercules
    51 mercules
    Nice roadster!
    Stogy likes this.
  9. imtb
    imtb
    from St. louis
    46AA8DE1-E613-454F-9DD3-A3E42C2E7323.jpeg E493AE99-2E1E-4968-9F87-B5034E72C2DE.jpeg Thanks for the nice comments. The body is in really good shape and pretty complete car. I got the taillight working. I have one headlight working so fixing that. Changed all fluids, ****** was nasty black syrup. Brakes need to be gone through.
    Dirty Dug, Rolleiflex, Stogy and 29 others like this.
  10. panhead_pete
    panhead_pete
    Wow nice one!
  11. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
  12. CSPIDY
    CSPIDY
    A true vintage hotrod
    I like
  13. Outback
    Outback
    from NE Vic, Oz
    A good looking rooster!
    Stogy likes this.
  14. imtb
    imtb
    from St. louis
    8FE69483-FD3B-473E-A961-81BFF27502B2.jpeg DD3027DA-B8BC-4FFF-8A1D-E3DE93E28B50.jpeg Converted to 12volt and FSI electronic ignition. I was up until midnight but all went well I need to re index oil pump to change plug wire routing. she fires right. Also put modern shocks on front. Stil need todo rears. Need hun puller. Getting things sorted out. Made a grocery run and made it home!
  15. cederholm
    cederholm
    Very nice! I dig.
    Stogy likes this.
  16. Zax
    Zax
    Is that intake and exhaust manifold the ones sold by Red’s Headers? Looks like they fit well together.
    Stogy likes this.
  17. Fogger
    Fogger
    That is a beautiful '29, congratulations. You could correct the shock angle by moving the axle clamp to the front side and redoing the top mount to the front. The shock angle would be vastly improved and the shock would function better. But all in all that is a great A Model.
    Stogy likes this.
  18. imtb
    imtb
    from St. louis
    Fogger, you mean turning bottom mount around and the top stud put toward the front. If so, I will give it a try hopefully would clear the leaf spring.
    I have been working on the breaks and getting things sorted out.
    Stogy likes this.
  19. Petejoe
    Petejoe
    from Zoar, Ohio
    That car is fabulous. I love it with the fenders. Just beautiful.
  20. High test 63
    High test 63
    Nice little roadster! Really sweet looking! I hope you're having as much fun as it looks.
    Stogy likes this.
  21. Fogger
    Fogger
    Yes, place the clamp for the lower shock mount on the front of the axle between the spring perch and the kingpin. Then move the top mount forward on the frame in a position to clear the spring and axle. An angle of 20 degrees will work very well for the shock. Again a beautiful '29 you'll have a great time driving it.
  22. jimmy six
    jimmy six
    Let’s see….32 rails, pinched for the body; rear coil overs on a 9”; 32 grille shell; 3” dropped front axle; disc brakes all around; blown SBC; 200R4 transmission; Duke Hallock windshield; red paint; then you’ll have the same as every one else.:rolleyes:
    Stogy, 34 5W Paul, winduptoy and 5 others like this.
  23. Jeff34
    Jeff34
    @imtb Fantastic looking car! Mine looked somewhat like it, but not nearly as nice (and it had gl*** fenders...sad) You will certainly enjoy that ride!
    It may be tight with the brake rod if he moves the bottom of the shock out toward the kingpin. May have to move the top of the shock outward as well to clear it.
    Stogy likes this.
  24. VF-1
    VF-1
    Beautiful! Who doesn’t love a 29’ Roadster, with a Banger! I’m all in!!
    Stogy likes this.
  25. imtb
    imtb
    from St. louis
    Thanks for all the response. I am not a fan of the Hal lock windshields, I wouldn’t mind having a 2” chop.
    Got a few more things done. Brake rods with all new pins and brake rods adjusted. Brakes still not that great. Battery is now held in place. Removed stone guard. Picked up this T5 for a swap.
    220A0432-DA86-4D1C-A736-CD5F3F27CBBD.jpeg E374F2B0-5FF2-4B5A-A927-B19554DE70E4.jpeg EFFF8345-9CDD-4B0E-B065-71E24BDA3BDB.png
    hfh, VF-1, Stogy and 12 others like this.
  26. banjorear
    banjorear
    Very, very cool roadster. If you swap the A with a T rear spring with a reversed main, you'll get 2"+ without doing anything else. Would make your car just about perfect.
  27. lothiandon1940
    lothiandon1940
    What a beautiful little Roadster! Enjoy.
    Stogy likes this.
  28. Langan
    Langan
    from Eagle ID.
    Perfect 29 love them with fenders. 5 speed will make it a great driver.
    Stogy and osage orange like this.
  29. Atwater Mike
    Atwater Mike
    Jeez, just a few 'adjustments'... Black Beauty here.
    Stogy likes this.
  30. Gary Addcox
    Gary Addcox
    That A will be more fun than you should have ! LOL
