Customs kicking around mounting this packard trim on my pontiac (opinions?)
Discussion in 'The Hokey Ass Message Board' started by Eddiesixem, Jul 18, 2023.
  1. A mid fender behind wheel opening
    14 vote(s)
    43.8%
  2. B upper fender above wheel opening
    8 vote(s)
    25.0%
  3. C no trim, leave it alone
    0 vote(s)
    0.0%
  4. D spear coming off top of wheel well
    10 vote(s)
    31.3%
  1. Eddiesixem
    Eddiesixem
    I picked up some Packard trim, always envisioned this car with it, but am still considering where and if I am going to run it. Whats your opinion? I have a favorite. but would love to hear what others think. MicrosoftTeams-image (5).jpg
    alanp561, Dyno Dave, nochop and 3 others like this.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Number one please. But I’d drop it about four inches.
    Cool custom.
    alanp561 and Eddiesixem like this.
  3. Jim Bouchard
    Jim Bouchard
    Number one looks good and the lowness of it visually makes the car look lower. I’d like to see it on line with the center of the wheel horizontal like it is. That might look more good, might not. I see how you have it pointing at the top of the round center part of the hubcap. Good visually. This in my opinion is the most common placement for the trim.
    tied with number one, I like number four. I like how it comes off the top of the wheel arch. It looks like some thought was put into the placement. I like the trim triangle thing nestled in the wheel arch. In this higher position the trim on the window ledge and body complement each other and visually look like a team, one pointing forward and the other point rearward in harmony, like it was planned out. A east west kind of thing.
    It’s hard for me to decide from a single picture. I would need to walk around the car and look at it at different angles and also park the car across the street and gaze at the trim from my front window.
    Joe Blow, lurker mick and Eddiesixem like this.
  4. Eddiesixem
    Eddiesixem
    i agree, there is some method to this choice of trim, and my kicking around its position. I have taken alot from other angles also, maybe ill post a couple of those for reference also.
    Jim Bouchard likes this.
  5. I like the last one
  6. jnaki
    jnaki
    Hello,
    The first one is the best for overall proportions. As long as the chrome strip is parallel to the body/fender line running from front to back. The surface split between above and below the strip is fine.
    If someone will say the above the body line has more, they are right, but it is the fender/body line that is the dividing line. It is all about the overall prospective when viewing the custom car from the side. What grabs your eye when you first see the lowered custom car?
    Jnaki
    If you plan on doing a continuation of that cool roof artwork design, then do not put the side chrome strip in the middle. It will get too busy with the swirls, if you use the design. Plus, you have to use the chrome strip as a divider and make the swirls stay above or below the line.
    No swirls/scallops, use the mid-level chrome strip. Continued swirls/scallops, do not use the mid level chrome strip. It is all about simplicity and good design, as well as proportions of the custom car. YRMV
    alanp561, 41 GMC K-18 and Eddiesixem like this.
  7. Eddiesixem
    Eddiesixem
    EVENTUALLY, I PLAN ON A SINGLE SOLID COLOR, THE ROOF IS TEMP FOR FUN. THANKS! I APPRECIATE ALL THE RESPONSES! KEEP EM COMING
  8. skooch
    skooch
    Lonely vote for #2, matches the car. They all look good though, I think #4 would need some m***aging of the wheel opening to match the trim.
    Stan Back and Eddiesixem like this.
  9. Just Gary
    Just Gary
    (A) is my first choice.
    (D) would be a distant second choice.
  10. hrm2k
    hrm2k
    First one for me
    Eddiesixem likes this.
  11. X38
    X38
  12. williebill
    williebill
    Number 4, then number 2. Like the profile of your car alot. Looks good.
    Joe Blow and Eddiesixem like this.
  13. Old-Soul
    Old-Soul
    B, except flip them side-to-side so the "fat end" is rearward.
  14. FrozenMerc
    FrozenMerc
    I would like #2, except for the small body line coming from the head light. That said, the trim lengthens the appearance of the car and gives it a lower look in the #2 position.
  15. wvenfield
    wvenfield
  16. krylon32
    krylon32
    from Nebraska
    Mount the trim the way you like it. It's your car.
  17. desotot
    desotot
  18. Joe Blow
    Joe Blow
    #4...similar to Sam Navarro's 52 Chevy.
    Old-Soul, 49ratfink, skooch and 4 others like this.
  19. In_The_Pink
    In_The_Pink
    #2, but would be better with the leading edge centered on the fender crease.
  20. nochop
    nochop
    from norcal
    All of the above
  21. Exactly both look slick !!
  22. Eddiesixem
    Eddiesixem
    MicrosoftTeams-image (12).jpg MicrosoftTeams-image (15).jpg MicrosoftTeams-image (13).jpg MicrosoftTeams-image (16).jpg MicrosoftTeams-image (18).jpg MicrosoftTeams-image (17).jpg
  23. Eddiesixem
    Eddiesixem
    OH, FOR SURE, IM A LITTLE TORN BETWEEN 2, JUST KIND OF CURIOUS OTHERS THOUGHTS, ULTIMATELY ILL GO ONE WAY OR THE OTHER BASED ON THE 2 I LIKE.
    Jim Bouchard and Just Gary like this.
  24. BJR
    BJR
    I like #1, it ends at the center of the forward most part of the rear fender, which just looks correct.
    Eddiesixem and Just Gary like this.
  25. Jim Bouchard
    Jim Bouchard
    Okay, with the new pictures I’ll say number 1 looks good and is in my opinion the “most popular” and “safest” look.
    my official vote is for number 4
    It looks great with the different angles and not everyone will like it which suits me just fine.
  26. ChuckleHead_Al
    ChuckleHead_Al
  27. gotta56forme
    gotta56forme
    from Seattle
    I was going to echo one of the first posters who wanted to see the spear through the center line of the wheel, and I would like to see that. I also just noticed that beauty line on the rear quarter ahead of the tail light, Me thinks I'd like to see the trim at a height that might be sympathetic to that rear quarter accent molded line, also.
    Fretsalot/Scott
  28. proartguy
    proartguy
    from Sparks, NV
    I like #1 for several reasons.
    It balances the lower body m***.
    The spear at the front mimics the belt-line trim and is more related rather than accentuating the wheel opening.
    Since the front fender already has an accent embossed line the trim works
    better mid-body rather than mid fender giving each area its own accent.
