Technical SBC running super rich
Discussion in 'The Hokey Ass Message Board' started by JGT, Jul 20, 2023.
  1. JGT
    JGT
    I have a freshly built SBC 350 with a single 600 cfm Edelbrock carburetor sitting on a tunnel ram intake. It has a comp cams RV grind with the timing gear set at '0'. The idle mixture is dialed in. The MSD electronic distributor has a vacuum advance with initial timing set at 8 deg. advanced. The electric choke works properly ( it's all the way open when warmed up).
    Problem....the motor runs super super rich and lugs a bit going uphill. It has a wee bit of hesitation taking off from a stop light. I can probably adjust the accelerator pump linkage to address the hesitation but I need to figure out why it's running super super rich.
    Suggestions anyone?
    My avatar is the hotrod I'm refering to.
  2. squirrel
    How did you determine that it's running rich?
    And did you set the float levels on the carb before installing it?
    What RPM going uphill, is it lugging at?
  3. '49 Ford Coupe
    '49 Ford Coupe
    How do you know it is running rich?
    Bandit Billy likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    lumpy 63 likes this.
  5. 6sally6
    6sally6
    How radical is your cam (duration LSA)?
    With Eddy carbs part of the tuning process involves metering rods and jet changes.
    (NOT just stick it on and adjust the mixture screws).
    ...............Especially with a single carb on a tunnel ram with an RV grind cam.!?!!...........
    Ya need an Edelbrock tuning kit with different springs/metering rods/and jets( Summit has 'em & Advance etc)
    ALSO.... tuning the ignition curve is a must. (MORE initial advance and a quicker advance curve....)
    It isn't hard.....it just takes patience.
    Go on line to how to tune my Edelbrock Carb.
    Step by Step EZ to follow.
    6sally6
  6. Lloyd's paint & glass
    Has to be the power valve?
    '28phonebooth likes this.
  7. sunbeam
    sunbeam
    The covers that are over the metering rod pistons loosen the screw a pivot the covers enough to see the piston then snug the screw start the engine and the pistons should be pulled all the way down at idle.
    SuperKONR and mad mikey like this.
  8. JGT
    JGT
    It*****s gas like a banshee and the exhaust pipes have loads of black soot.
    VANDENPLAS likes this.
  9. JGT
    JGT
    Sounds like I need to back up a little bit. I need to make sure the metering rods a fully closed at idle and check the float level. Thanks for the reminder.
    mad mikey likes this.
  10. swade41
    swade41
    from Buffalo,NY
    Also make sure your fuel pressure is 4.5-5.5 they do not like anything higher than that.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I’ve never opened an Edelbrock but have have to think the orifice at the needle and seat is larger because of the single inlet. If my hunch is true??? that would explain why Edelbrock carb needs lower pressure to seat valve correctly.
  12. Happydaze
    Happydaze
    Hunchbusted!
    Edelbrocks have one inlet but the two bowls are fed from two separate valves. There's an internal transfer tube that runs across the carb directly behind the inlet port.
    Chris
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    Float buoyancy. Float arm leverage both determine how much pressure the needle valve will hold .
    427 sleeper likes this.
  14. Lloyd's paint & glass
    Oh*****, I didn't see that it's an edelbrock. Yeah, might have to change the springs on the metering rods to a lighter spring. At idle, loosen the small screws with the torx or a 1/4" socket, swing it open and see if the metering rods are*****ed down. If they aren't, or if they're bouncing, fuel is dumping in through the jets.
  15. mad mikey
    mad mikey
    Download Edelbrocks tuning guide. Study it . Make tuning adjustments, and check plugs. Tuning is process. A AFR gauge will help you . These carbs are very tunable and work very well with fuel metering. Float level and fuel PSI must be adjusted spot on.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No wonder to why these carbs are so w i d e. 4556C929-F28C-4F7E-AD8A-AD965CC9CA53.png
    mad mikey, 427 sleeper and Tim like this.
  17. gimpyshotrods
    gimpyshotrods
    Large runner huge plenum manifold, with a small cam, with attempted operation on the street.
    This is a recipe for poor fuel atomization.
    Raw fuel won't fire off like a properly atomized mixture.
    mad mikey, Just Gary, X38 and 12 others like this.
  18. bobss396
    bobss396
    I'm a Holley guy, never liked anything else outside of Q-Jets. How do the plugs look? Surprised this hasn't come up yet or I missed it.
  19. mad mikey
    mad mikey
    Yea , I told him to check the plugs. Waiting patiently to hear back.;):rolleyes:
  20. JGT
    JGT
    Plugs looked a little dark. I found the float level right on (7/16 w/ gasket installed). Fuel pressure is set at 3.5 psi. The metering rods, springs, and jets had been enlarged so I changed them back to factory original. Wiped out the chrome exhaust tips with solvent so I can keep a visual on soot buildup. I should have it back on the road this weekend so I'll run a tank of gas through it and check the plugs (E3) again.
    swade41 likes this.
  21. sdluck
    sdluck
    My SBC inital timing is set @ 15 BTDC , total 35 10.5 91 pump gas'
  22. mad mikey
    mad mikey
    E3 plugs are a joke gimmick. Put NGK plugs in it with the proper heat rang.
  23. JGT
    JGT
    Seems to have worked. Plugs look better, no sooting in the exhaust tips. I'll leave it alone for a bit and see how it goes.
    swade41 likes this.
