Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. squirrel
    installing the new radiator in Plan II. I'm making some simple saddle brackets for the bottom, and still thinking about how to do the top.
  2. 51504bat
    51504bat
    If it's like the one I bought from Eastwood it does do bubble flares.
  3. swade41
    swade41
    from Buffalo,NY
    I'll have to youtube it to learn how to do them, might be handy for slipping rubber hose over.
    chryslerfan55 and 427 sleeper like this.
  4. 51504bat
    51504bat
    I'll check tomorrow to see if I have any instructions. Can't be too difficult cause I was able to figure it out.
  5. Flatrod17
    Flatrod17
    On swade41 fitting problem, Most radiator's I see like his, that bung is probably a pipe thread. I would be surprised if that had a seat in it for a inverted flare. You may need to get a br*** adaptor, 1/4 pipe to 5/16 inverted flare.
    bchctybob, chryslerfan55, BJR and 4 others like this.
  6. nochop
    nochop
    from norcal
  7. swade41
    swade41
    from Buffalo,NY
    Well, be prepared to be surprised and you guys that liked his comment too, there it is.
    It also revealed the problem, it pulled the threads out, fitting screws in and out without issue but it sure looks like it's missing some threads, after a Google search this seems to be a hit n miss problem with Champion radiators and they will repair at no charge but you have to pay shipping both ways.
    I in no way over tighten the line either just snugged it up, leary of over tightening it because of it being aluminum, to bad the lower bung wasn't like the upper one to not have these issues.
    Anyway there's the seat for the inverted flare
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    dammit, I wonder if you could drill and tap for NPT and put an adapter there? Might be a bad idea because of shavings but maybe you could hook an air compressor line to the top hole with a regulator maybe 15-20 psi to keep the chips out???
  9. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Front brake lines on the 57. These are going to be one piece. I hope. IMG_0921.jpeg
  10. Flatrod17
    Flatrod17
    '28phonebooth likes this.
  11. Flatrod17
    Flatrod17
    Well that is a first for me! Never seen that, but then again, I don't deal with many alum radiators.
    Like Moriarity said maybe you can save it by going to a pipe thread and a adaptor. If you did want to tap for pipe, pack the tap with grease to keep the chips stuck to it along with air blowing out.
  12. 427 sleeper
    427 sleeper
    Damn! It don't even look like the thread's are deep enuff! :eek:
  13. swade41
    swade41
    from Buffalo,NY
    I ordered an external cooler yesterday, I'll just plug these holes to keep whatever fluid is in there in there and not out under the tires.
    I thought about epoxy-ing a fitting in there or having a AN fitting welded in, but decided it's not worth the h***le of not knowing if it's a for sure fix or the h***le of pulling the radiator then buying more AN fittings and lines and figuring out how to attach them under the car.
    I'm ready to wash my hands of this frustration lol
  14. PhilA
    PhilA
    The same rusty MoPar junk I've been doing for the past couple months.
    Still more to do but it's not all Fred Flintstone any more.
  15. swade41
    swade41
    from Buffalo,NY
    Child labor clause, had my son helping pull the intake on the 57 this afternoon
    nothing but a cleaned up used motor, was hoping for more since the heads looked clean when I pulled valve covers, fresh gaskets and paint everywhere
  16. lumpy 63
    lumpy 63
    Just bolt on one of yer extra roots thingys
    Okie Pete, enloe, loudbang and 4 others like this.
  17. squirrel
    I needed a break from working on important stuff, so I'm seeing if I can get an old clock to work. The odds are really slim, of course.
    bchctybob, chevy57dude, BJR and 10 others like this.
  18. B1gDaddy
    B1gDaddy
    from aladambama
    F3FC35C7-131D-4CF4-8539-297C67211FB2.jpeg I’m working on tuning this paint up. Would you believe it’s almost all orig lacquer except the nose and two fender tops. I’ve wet sanded the enamel blend off and am resurfacing w real black lacquer. How’s it look ?
  19. swade41
    swade41
    from Buffalo,NY
    That's the plan if it doesn't knock like a woodpecker or smoke like a freight train.
    For now it'll get the Dominator II that I epoxed that corrosion damage on.
  20. nochop
    nochop
    from norcal
    Fiddling with some cage nuts to get the rear fenders on IMG_6012.jpeg IMG_6016.jpeg IMG_6015.jpeg IMG_6018.jpeg
  21. Well THAT ****s!
    swade41 likes this.
  22. deathrowdave
    deathrowdave
    from NKy
    Radiator bung , drill and retap to NPT as suggested . Install a Sweglock fitting and never look back . If it’s 5/16 tube Sweglock has no fittings for 5/16 . Just retap , seal the new fitting with lock***e and done . Grease the drill bit and tap , grease will hold shavings if you drill slowly , and don’t melt the grease .
    bchctybob and Okie Pete like this.
  23. It looks cross threaded ! JW
  24. lumpy 63
    lumpy 63
    Put some more miles on the M22 today , drove Vette out to the shop and worked on the 56 bel air. Finished plumbing the brakes using the new flaring tool I had em buy, and got em bled. Got the battery cables run from the trunk also:D
  25. nochop
    nochop
    from norcal
  26. Moriarity
    Moriarity
    SUPER MODERATOR
  27. guthriesmith
    guthriesmith
    Looks great from here! I need to do the same to my car again. :( I had to let it sit out in the sun a few weeks and the original paint sure died back again. Anyone know a good way to keep old dead paint shiny? My car doesn’t seem to like to hold its shine too well anymore. I can make it look great by buffing it, but doesn’t take long to die back it seems. And, it is real thin on the hood and tops of fenders similar to what it sounds like that Caddy must have been.
    This was about 4 years ago showing how bad it gets and is again...
  28. 57 Fargo
    57 Fargo
    Unloaded Mamas parts car.
    IMG_5125.jpeg IMG_5127.jpeg IMG_5126.jpeg It’s really, really rusty but has a mint grill, perfect windshield and lots of other good parts. Currently on the road again today to get the project car…
  29. Moriarity
    Moriarity
    SUPER MODERATOR
  30. BJR
    BJR
    Keep us posted in a timely manner, I want to watch this.:D
    '28phonebooth and 427 sleeper like this.
