Technical ***JULY 2023 BANGER MEET THREAD - Happy 4th Cylinder***
Discussion in 'Traditional Hot Rods' started by Retson the Racer, Jul 3, 2023.
  1. I'm not sure the status of Stipe Machine, but Terry Burtz has a .340 cam that works for A/B. https://burtzblock.com/products/camshaft
  2. Never had fuel supply dilemmas before in the previous ten years but I was testing a new pump - suppose I should have swapped the old system back over on the Saturday night. Lesson learnt...
    I tried to get a Stipe cam for the Burtz build as I was happy with the one I've run the past few years but I couldn't get one so I went with a Burtz cam. It works well. Well enough that I've bought another!
  3. Recently I started a YouTube series do***enting the history behind banger speed parts.
    For the first episode, I cover Ed Winfield and the many banger parts that he made. This next episode will feature Harry Hosterman, and the various heads he created.
    Check it out!
    skip65, trikejunkie, Old Dawg and 7 others like this.
  4. Kevin Pharis
    Kevin Pharis
    from Califunny
    Ahh shucks…!:p Thanks for the shout out, and thanks for giving some air time to the little known Winfield O/H too. The Speedway Museum has 2 of these heads (out of maybe 3-5 made), one set up with dual SR’s and the other with a SOHC setup on it! The correct carbs unfortunately are condemned to mythology and that one pic… except that I worked on some reproductions a while back. I fixed some incomplete machine work and ***embled, but never got to test run em. Little known fact; they used mostly Stromberg 97 internal br*** components. Not sure what ever happened to em tho …?
    Old Dawg, Outback, Jiminy and 3 others like this.
  5. V4F
    V4F
    from middle ca.
    has anyone put a turbo on a banger ?
    kb9jlo likes this.
  6. kb9jlo
    kb9jlo
    from Central IL
    I saw a picture once. Can't remember where now. Maybe VFF?
    I did find this:
    Sweden maybe? Beautiful engine.
    marioD and Old Dawg like this.
  7. hotrodA
    hotrodA
  8. Stan Back
    Stan Back
    60 years ago, my brother showed me an "A" head that converted the motor into being an air compressor -- two running, the other two pumping. Is my memory bad or was I just drinking too much?
    Outback and 51 mercules like this.
  9. 282doorUK
    282doorUK
    Original T racers racing.
    GuyW, Old Dawg, BeaverMatt and 4 others like this.
  10. No not drinking too much, maybe not enough....
    That was a common conversion for portable air compressors.
    J
  11. Fabber McGee
    Fabber McGee
  12. Hitchhiker
    Hitchhiker
    Alright. My engine has some miles on it now, seems pretty happy...but. it pushes a lot of water out.. I can't keep water in it at higher rpms. Doesn't seem to have a blown headgasket. It only does it at higher rpm or when I rev it quickly.
    Is this why guys put the smaller 3.5 inch pulley on the crank? To slow the pump? What else can I do? Would a pressurized radiator work?
    How will the smaller pulley effect my generator? Will it charge enough? Can I turn it up so it still produces a charge at lower rpm?
    Thanks
    Old Dawg likes this.
  13. Stan Back
    Stan Back
  14. 62pan
    62pan
    Hitchhiker, I also had that issue so I put an expansion tank on. Used a good sealing cap so it can siphon back as the motor cools. That worked well but later I went with the smaller pulley Yapp sells and that cured it altogether. Expansion tank is still hooked up but is always dry.
  15. Mainedrifter2
    Mainedrifter2
    After months of waiting, my new Banger arrived from the other coast.
    I started stripping the old engine today. A21FD21B-397C-46B8-9412-5AB0AAF19352.jpeg
    Old Dawg and Outback like this.
  16. Hitchhiker
    Hitchhiker
    That's what is left of my 2 piece crank pulley sleeve. Gonna pull the pan tomorrow see what else is messed up. It really chewed up the front main seal. 20230722_152228.jpg
  17. Hitchhiker
    Hitchhiker
    I have one of the smaller pulleys. I may try that. Thanks. I'm in there working on it right now anyways.
    Outback likes this.
  18. Outback
    Outback
    from NE Vic
    GuyW likes this.
  19. Outback
    Outback
    from NE Vic
  20. V4F
    V4F
    from middle ca.
    after braking 3 i went to a billet steel front pulley ........... no mo trouble
  21. Fabber McGee
    Fabber McGee
    Apparently, a lot of engines have been converted to compressors. First time I heard of it, the outfit one of my buddies worked for rented a compressor for a few days that was a 302 Ford engine running on half and squeezing with half.
    Outback likes this.
  22. trikejunkie
    trikejunkie
    from Scotland
    Here is a wee film we made today of my coupe up in the woods 4 Banger power obviously .....
  23. Hitchhiker
    Hitchhiker
    3.5 inch crank pulley seems to be doing its job. Just took a spin and no water loss! I'll call that a win!
  24. Outback
    Outback
    from NE Vic
    Have we August yet?
    Midnight Rider likes this.
  25. Jiminy
    Jiminy
