Hot Rods Chevy Engine
Discussion in 'The Hokey Ass Message Board' started by bgthegreat, Jul 23, 2023.
Tags:
  1. bgthegreat
    bgthegreat
    Trying to identify this Chevy engine for a buddy. I'm a Chrysler guy. Any ideas?
    Thank you.
  2. Deuce Lover
    Deuce Lover
    What is the casting number on the left rear near the head?
  3. bgthegreat
    bgthegreat
    I am going to have to go to Ron's garage and get that.
  4. RICH B
    RICH B
    TJC = '73 350 truck motor on a suffix code list.
    Deuces and Algoma56 like this.
  5. bgthegreat
    bgthegreat
    How about 3970010?
    Deuces likes this.
  6. bgthegreat
    bgthegreat
    Thank you. We thought it was out of a 74 truck.
  7. squirrel
    That casting number was used on most truck 350s from 1969 to 1979.
    The casting date looks like 8 to me, meaning 1978, and the suffix code date on trucks online isn't complete, so I'd guess it's from 78, also due to the shape of the stamped characters. But it doesn't really matter, a 1973 and 1978truck 350 are about the same engine. 4 bolt mains, cast crank and pistons, 1.94/1.50 valves, low compression, Quadrajet, etc.
    The engine was not originally in a 74 truck, they did get swapped around a lot.
  8. A Boner
    A Boner
    What do these #’s tell us? Supposedly from a 76 Chevy truck. Do the numbers tell if it’s a 4 bolt main engine?
    5B327EE8-5DAA-4618-9A58-56BFB348A18F.jpeg DE88D254-5D85-4B5C-9262-3C353AAD3DF1.png
  9. squirrel
    TYZ could be a 1975 Chevy pickup truck engine. The 3970010 casting number usually is a 4 bolt main engine, and 4bbl truck engines that have it are almost all 4 bolt mains. You can be sure by pulling off the oil pan and looking. only the center 3 main caps have 4 bolts, though
  10. My 3970010 truck engine came out of a vette
    True story
  11. A Boner
    A Boner
    Thanks Jim… engine had an old Quadrajet on it.
    Deuces likes this.
  12. MCjim
    MCjim
    from soCal
    My Vette has a van engine in it.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, and my vette has a pickup truck engine in it....
  14. 427 sleeper
    427 sleeper
    Those pick-up truck engine's make some serious power... :p:oops::cool::D
  15. guthriesmith
    guthriesmith
    Lol...mine has one out of a Suburban which is basically a truck too. :D
  16. My vette engine is back in a truck now.
    Gained a good bit of HP from it’s time in a vette.
    I got one of the quickest 61 C40s in the country.
  17. squirrel
    Chevy made millions of those truck engines...and people hold on to trucks for a long time. Not surprising the engines end up everywhere.
  18. Mr48chev
    LOST ANGEL likes this.
  19. bobss396
    bobss396
    My 3970010 block was a 2-bolt main. Decoding the numbers by the p***enger side head revealed that it was from a '74 police car.
    Deuces and 427 sleeper like this.
  20. squirrel
    Seems there were some 010 blocks used in p***enger cars that got 2 bolt mains, but most of the 2 bolt 350s were 014 block castings. I haven't seen a 2 bolt 010 myself, but I've only looked at a few dozen of them in my life.
    Truckdoctor Andy likes this.
  21. guthriesmith
    guthriesmith
    I guess I need to pull the pan on the one I just picked up and see if it is a two or four bolt.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    the one in my corvette is a 010 2 bolt main. I have had the pan off
  23. The extra two bolts on the mains add at least 100hp.
    I had my 4 bolt main bolts oversized. Added at least 150 hp.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    Kinda weird that CKS suffix code is either a 72,73 or 1977 but the casting date is 1975
    B65B097B-B515-419C-8F08-8CAC9287453F.jpeg D6D77996-FA59-440D-B143-F34ACD836F3A.jpeg 9709C9E9-74B7-4C42-B7FB-CAE1BF61A9D9.jpeg
  25. squirrel
    the partial VIN is 1976. ***embled August 11th, I guess it was one of the first 76 engines. Norwalk ***embled X and F body cars, didn't they?
    Moriarity likes this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    So, not a truck engine but a Nova or Camaro engine? the suffix code is confusing then as they say 72, 73 or 77... I guess it is a corvette engine now that it is in a corvette!!!
    chevy57dude and 427 sleeper like this.
  27. squirrel
    The suffix codes...there were lots of them, and the records of what went into what, aren't perfect.
    Truck engine suffixes from the 70s mostly started with T, and the partial VIN started with C. 1 was used for Chevy cars for the VIN.
  28. The actual 4 bolt castings could have been machined for 2 bolt caps. The casting marks designate the original intention. SBC 2 bolt casting and 4 bolt castings are two entirely different animals. The 2 bolt block has heavier webbing and different casting numbers.
    Did they machine 4 bolt blocks for 2 bolt caps? They certainly could have but that would make them prime for failure as a hot rod motor. The reason that a 4 bolt block could get away with lighter webbing is because the 4 bolt caps make up for it. There are ways to cure the problem of lighter webbing and 2 bolt caps but as common as SBC blocks are there is no reason to bother with them.
    Most smog era truck motors were 4 bolt, at least in my experience they are.
    bobss396, Deuces and SS327 like this.
  29. Deuces
    Deuces
    I bought one from a s**** yard once out of a GMC pickup and not only was it a 010 4 bolt block, it also had a steel crank and the beefier X rods....:)
    And yes, it was a 4-bbl carb motor..
    Algoma56 likes this.
  30. bobss396
    bobss396
    Real slick players have the caps modified to take 6 bolts...:cool::cool::cool:
    alanp561 likes this.
