Projects To a T- Trevor's T-on-A RPU
Discussion in 'Traditional Hot Rods' started by trevorsworth, May 7, 2022.
  1. RMONTY
    RMONTY
    I heard tell that someone has a louver press over there somewhere around Denton....
    trevorsworth likes this.
  2. trevorsworth
    trevorsworth
    Well, that was fun.
    I couldn't wait anymore; had to drive the car. We swapped the Model A radiator back on & I went for a quick jaunt then we adjusted the pedals and shifter to a more drivable position... then the car was so fun to drive I didn't want to work on it anymore, I just drove the **** out of it until I broke it.
    I got carried away & hit a deep rut at about 40. Without the strut rods to keep the top of the radiator located, it flipped forward and pulled the upper hose off. Worse still I think it busted the bottom tank on the Model A radiator. ****s, because this was a good original rad...
    After limping it back I noticed the wheel bearings I installed... 2 years ago? had a lot of play, so I'll have to redo that. And salt in the wound: the clutch has started chattering real bad when I push the pedal. Not sure what that means just yet but I'm sure the fix will involve removing the motor.
    But yeah, I like the car. The experience is more like flying a biplane than driving a car. It's scary and exhilarating and addictive. I'm back in love.
  3. alanp561
    alanp561
    Very cool:cool:! The running, driving part anyway. The radiator falling, not so much, but at least it didn't fall backwards into the fan :eek::eek:. Did Robin get on you about that? Keep at it, it's going to come out alright.
  4. trevorsworth
    trevorsworth
    I know, I know, nothing traditional about an aluminum radiator. But once I paint it black nobody will know!
    This is a T-bucket radiator, the Mustang rad was posing too many challenges.
    Got to add some reinforcements to the brackets I made & that should be good to go.
    OFT, rjgideon, Thor1 and 2 others like this.
  5. alanp561
    alanp561
    Trevor, I hope you realize that yellow tape isn't going to hold that too long. ;)
    Outback, RMONTY and trevorsworth like this.
  6. trevorsworth
    trevorsworth
    Should be good for one trip around the block at least!
    Outback, RMONTY and alanp561 like this.
  7. RMONTY
    RMONTY
    I had to take the key and steering wheel away from him to keep him from driving it in spite of the radiator hoses not being hooked up!
    alanp561, brEad, OFT and 4 others like this.
  8. L79_Acadian
    L79_Acadian
    from canada
    26 sedan,cut down into a pickup cab, sitting on a A frame. Plan on using a 32 grill shell, cut down. Flathead powered, Transmission, Lincoln rearaxle.
    Stogy, trevorsworth and RMONTY like this.
  9. trevorsworth
    trevorsworth
    I forgot to mention in my last post I didn't break the transmission. It turns out there is a grease zerk on the throwout bearing and it just wanted some grease. Smooth as ****er now with fresh oil in the transmission.
    I was making some parts calls at work today and just for grins I asked the O'Reilly commercial guy how far back their computer went on model year. He checked and came back with 1896! So I asked him to look up my 1928 Model A and to both of our surprise they have a lot of parts in the system for the ch***is. I was able to get new inner and outer wheel bearings and races for the front for $105, delivered to the shop same day.
    brEad, OFT, Thor1 and 2 others like this.
  10. RodStRace
    RodStRace
    Trev, help others with part numbers when you get a chance.
  11. trevorsworth
    trevorsworth
    Sure.
    Inner bearing: 15118
    Outer bearing: 09074
    Inner race: 15250X
    Outer race: 09196
    Dedsoto, alanp561, Thor1 and 2 others like this.
  12. 2Blue2
    2Blue2
    amazing
    Fun to see it out and about.
    Outback and trevorsworth like this.
  13. trevorsworth
    trevorsworth
    Won't be touching my car much til after Lead Ain't Dead but I went to visit a friend and he gave me this...
    Homemade dual carb intake with what I think are two early 50s Carter YFs. They will both need to be rebuilt but what a cool piece of garage hot rodding!
    Any good resources for YFs? How can I ID them for sure to make sure I'm getting the right rebuild parts?
    Squablow, Fjant, Thor1 and 1 other person like this.
  14. RMONTY
    RMONTY
    Check with @carbking .....maybe he can help out?
  15. trevorsworth
    trevorsworth
    I have stripped & ID'd the carbs, they are both Carter YF 964S from a Chevy 216 stovebolt. They are exact twins and both are in good core shape. In all honesty they both would probably have run as is but one has a slightly sticky throttle and I want to get it soaking in some evaporust so it doesn't wear out the throttle shaft bushing & and will just go ahead and rebuild them while I'm at it.
    RMONTY, brEad, Outback and 2 others like this.
  16. trevorsworth
    trevorsworth
    Got the twins fully broken down & ordered kits. I am gonna need to come up with some kind of fuel pump to run these. It will pretty much have to be mounted to the firewall so needs to look cool... maybe an older Walbro/Dupree bellows style... there are rebuild kits available for them.
    This will almost certainly be way too much fuel for my engine. :cool:
    Squablow, OFT, RMONTY and 3 others like this.
  17. MojoRacing
    MojoRacing
    Trevor, If you're still running a 6v system I had an old 6v Bendix pump laying around. I can try to dig it up if you're interested.
    alanp561 and RMONTY like this.
  18. trevorsworth
    trevorsworth
    I’m on 12v. I wonder how viable it would be to run a fuel pump off a voltage reducer.
    RMONTY likes this.
  19. RMONTY
    RMONTY
    Resistor of the correct resistance maybe? Is that what you mean by voltage reducer?
  20. trevorsworth
    trevorsworth
    I guess that they are just fancy resistors but you can buy "voltage reducers" intended for gauges, fan motors etc. from a variety of sources.
    RMONTY likes this.
  21. MojoRacing
    MojoRacing
    I thought it was a Bendix pump, turns out it a Dupree model 6v-802 4-6 psi. I hooked it up to my 6v charger and it pumped a bit but its crusty inside with old fuel. Needs a good cleaning and a kit. I found new bellows and gaskets for $18. Think about and let me know.
    P.S. I should have mentioned, it's yours for free.
    brEad, Lone Star Mopar, Thor1 and 2 others like this.
  22. trevorsworth
    trevorsworth
    I can't find anyone saying not to run a fuel pump off a reducer, so I'll rebuild it and see what happens. At least let me cover the shipping?
    Outback and Thor1 like this.
  23. MojoRacing
    MojoRacing
    Is your address still the same? Nah dont worry about the shipping. It shouldn't be much at all and it makes me happy to help a young man such as yourself. I had a lot of the old guys help me with parts when I stated building my first hot rod and I want to keep that alive!!
    Outback, brEad, alanp561 and 3 others like this.
  24. RMONTY
    RMONTY
    Trevor has been a valuable ***et for my build. He does all the young guy stuff, crawling up under the car, helps with the too heavy stuff, and comes up with some damn good suggestions! He is definitely a hot rodder and a great friend!
    Outback, brEad, MojoRacing and 4 others like this.
  25. MojoRacing
    MojoRacing
    That's awesome!! I love seeing the younger guys getting into hot rodding! Getting their hands dirty and building cars out of a pile of parts. keeping the hobby alive!
    J.Ukrop, Thor1 and trevorsworth like this.
  26. trevorsworth
    trevorsworth
    My address is the same. I really appreciate it... I've said this before but I would be lost without the generosity of other guys in this hobby whether sharing parts or decades of knowledge. I try to pay it forward as much as I can.
    Outback, brEad and krazee like this.
  27. trevorsworth
    trevorsworth
    Carbs are done. My eyes just about popped out of my head when I pulled those air horns out of the evaporust and they were hard chromed!!! These are gonna look so *****in on the car.
    Stogy, J.Ukrop, rjgideon and 10 others like this.
  28. trevorsworth
    trevorsworth
    No progress to report but I did want to share this fantastic little 327-powered coupe I saw at Lead Ain't Dead.
  29. RodStRace
    RodStRace
    Wow, hope he has a "fuse" between that engine and rear axle. Otherwise
    Thor1 and Stogy like this.
  30. trevorsworth
    trevorsworth
    Lol. I really wanted to catch him, "how does that banjo cope with a 327?" was the number one question on my mind. But it's a great build...
    Thor1 and RodStRace like this.
