Projects a long time coming
Discussion in 'Traditional Hot Rods' started by Austin kays, Jul 23, 2023.
  1. Austin kays
    Austin kays
    Glad to see everyone chiming in! Ive got big plans for this and already put alot of it into action. Once these pesky B Pillars get squared away ill post detailed pics of the chop. Gonna get her way down there. Ive got a couple months togo until the Roc but if I can keep this pace itll happen!
  2. Austin kays
    Austin kays
    I'm also looking for a 34 ford bell crank that's commonly used in juice conversions most I've seen are way high dollar lol if anyone's got one squirrelled away Id buy it from ya. Or shoot me your ideas on making a 40 ford master work with 34 pedals!!
    Okie Pete and Sancho like this.
  3. I got some desoto stuff that @Tim left with me. masters bell, bell cranks etc. if you make it over before you find what you are looking for give it a look. Maybe something there will work for ya or you can trade it for what you need.
    Do you have peddles? I'll make a pile while I am digging.
  4. Tim
    Tim
    from KCMO
    @porkn****** hes got 34 pedals bolted in now.
    the ear on the pedal pushes in the wrong direction so he’s looking for the bell crank option to reverse it. I’ve seen people cut the tab off and weld it back in the correct position and then make a bracket off the frame / cross member to hold a master but I think an option that doesn’t involve cutting the brake pedal is probably a smarter move
    @Austin kays do you have a photo of the bell crank your wanting to find?
  5. Tim
    Tim
    from KCMO
    https://www.jalopyjournal.com/forum/threads/tech-my-take-on-33-34-hydraulic-brake-pedals.437187/
    This seems like an option.
    from what I can make of the photos 34 pedals clutch and brake pivot on a shaft and have rods attached directly to the pedal itself.
    he’s put a longer shaft into the pedals and pinned the brake pedal to the shaft. Then taken the short lever off another pedal, looks like he used a model A pedal instead of another 34 as it’s what he had.
    now the clutch still functions as stock, and then brake rotates the shaft and the new arm pushes the pushrod backwards into a master.
    later ford pedals do the clutch like this I believe. Seems like a straight forward option.
    not sure where he sourced the longer shaft? I need to read it again but model A pedals shouldn’t be hard to find
  6. Austin kays
    Austin kays
    yeah let me dig around on the web
    Okie Pete and winduptoy like this.
  7. BigJoeArt
    BigJoeArt
    As we say GO MAN GO!
    hope to see this thing cruise up for my open house. I'll save you a good spot.
    winduptoy, Tim and Austin kays like this.
  8. Austin kays
    Austin kays
    at this rate ill make it no problem
  9. Tim
    Tim
    from KCMO
    Got it marked on my calendar
    winduptoy and BigJoeArt like this.
  10. Austin kays
    Austin kays
    Think my photos got ****y uploading fellas so here’s another wack at a few of the highlights B0D3BD0D-26B3-4DA9-AE0B-BD40891D7734.jpeg B0D3BD0D-26B3-4DA9-AE0B-BD40891D7734.jpeg 7A4191B6-9830-4701-8E66-C7931F047A16.jpeg B99FDEA8-8C85-417E-960B-C3E38B629B9C.jpeg
  11. Austin kays
    Austin kays
  12. winduptoy
    winduptoy
    Roc on....gonna' be jazzed to see you there in your new dream...
    carry on
  13. Tim
    Tim
    from KCMO
    @winduptoy and now we actually know what we look like so I can say the first not the 70th time I walk by lol
    @Austin kays the photos loaded up better this time!
  14. wheeltramp brian
    wheeltramp brian
    Hats off to you fellas!looking good!
    41 GMC K-18 and Austin kays like this.
  15. pprather
    pprather
    Good work, amazing progress.
  16. winduptoy
    winduptoy
    LOL....and we were civil to each other all 70 of those times....
    @Austin kays ..glad to see that the outdoor work area is of choice....I've got too much stuff or too small a garage too
  17. drdave
    drdave
    This is crazy amazing! So much work, so short a time. I can't even seem to get a starter unstuck in less than 6 weeks. LOL Excited to see your progress and even more excited to see it in Oct.
    Spooky, winduptoy, williebill and 4 others like this.
  18. Following along; you're doing a bang-up job!
  19. Austin kays
    Austin kays
    figure ill trailer it down being it will have almost zero test drive time, But the run at the Roc should be as good of a shake down as any haha
  20. Tim
    Tim
    from KCMO
    With 200-300 fellow hot rodders, nearly no other traffic and scheduled food and coffee stops along the way I’d say that’s a great plan!
    winduptoy and Austin kays like this.
  21. Tim
    Tim
    from KCMO
    Not stock photo made a cool video of last years show loading in.
    makes me think I should get up early, get in and parked and then sit along the road with a drink and watch them rumble in :)
  22. 41 GMC K-18
    41 GMC K-18
    Hey @Austin kays
    I just sent you a PM, so check it out.
    Thanks from Dennis.
    chryslerfan55 and Austin kays like this.
  23. Tim
    Tim
    from KCMO
    For some reason it made me think of @Tuck 34 from a zillion years ago
    found this old video of it. Won’t be long and you’ll be making your own video!
  24. Mo rust
    Mo rust
    I've got a couple of them. The one on the right came with a bunch of 34 Ford stuff and the one on the left I have no idea what it came from.
  25. Austin kays
    Austin kays
    ill send ya a pm
    41 GMC K-18 likes this.
  26. Austin kays
    Austin kays
    thank you Benno. couldnt do it with out my friends. Hotrodding rules!
    Okie Pete, 41 GMC K-18 and Tim like this.
  27. Squablow
    Squablow
    Awesome, I love it! Good to see stuff moving along with such enthusiasm.
    -Brent-, 41 GMC K-18 and Austin kays like this.
  28. Austin kays
    Austin kays
    Thanks! just gonna keep chipping away at it! I watched everyone go to the Roc last year and man it looked like a hoot! Not gonna miss out on the fun this year!
  29. Rickybop
    Rickybop
    Congratulations. :D
  30. JD Miller
    JD Miller
    Cool project,
    ... but that dirt and rock driveway needs a concrete slab ! :eek::D Hurts just looking at the pics, 'cause my new place has the same type rock driveway
    41 GMC K-18 and Outback like this.
