Technical Rudge-style wires on early Ford spindles
Discussion in 'The Hokey Ass Message Board' started by Ned Ludd, Aug 15, 2022.
  1. patsurf
    patsurf
    didn't the sting ray and xke rear end (diff)pieces interchange some amt?
  2. $um Fun
    $um Fun
    from Nor Cal
    My 34 three window came with spline drive Halibrands which were designed to replace the Rudge wire wheels on Indy/sprint cars in the late 40's. Orson equipment in the UK makes a direct fit Rudge hub for the Ford spindles https://www.orsonequipment.co.uk/
    They are made for the English style Rudge wires and the splines are 1/2" short for the Indy style Rudge wheels. They will still work but you loos 1/2" of spline engagement.
    I had to remake the rear hubs for the Ford axle bells and was lucky to have Roy Creel show me the rear hubs from his Belanger Special Indy Car to get the measurements . I machined them from EN36 and heat treated them.
  3. nobby
    nobby
  4. nobby
    nobby
    AHH,
    Even if you do go for the later 1971 3 series wire wheel
    they have the safety bead
    but still may leak tube-less
    so you need to run a tube
    that means you cant run low profile tyres
    also
    when you look at used wheels
    they are a wire wheel from 50 years ago
    they all look tired with loads of weights and balance issues
    you have a real heavy back splash
    still, looks coolio
    or
    I bet the general layout of a wire wheel hub for a series 3 jag is the same as the later xj6 cars
    so, if they indeed do takle the 11'' by 24mm rotor
    that means it still maybe a option or indeed a solution to something
    maybe
    plus the rear live mk2 420 rear ends are 60 inches wide, but the wire wheels have lots of positive offset - it looks like
    aluminium spline knock off dunlops $$$$$
    not spindle mounts
    lets you run a brake
