Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. saltflats
    saltflats
    from Missouri
    Yes it is. I'll see if I can get a measurement.
    Deuces and lumpy 63 like this.
  2. lumpy 63
    lumpy 63
    yup, unless you run a spacer...
    Deuces likes this.
  3. lumpy 63
    lumpy 63
    Oh wait... your running a 3.08
    Deuces and Johnny Gee like this.
  4. SS327
    SS327
    Hi gears are usually thicker. No need for a ring gear spacer if you use a 3 series carrier.
    Bob Lowry and Deuces like this.
  5. lumpy 63
    lumpy 63
  6. saltflats
    saltflats
    from Missouri
    He said his was 1 3/4 inch. Was a good try.
    Deuces, squirrel and lumpy 63 like this.
  7. Paul
    Paul
    Editor
    did you find the missing ball bearings or pinion tooth?
  8. squirrel
    The pinion tooth was laying in the bottom of the housing...lots of gunk on top of it, been there quite a while.
    Also found the cracks on the rest of the teeth. I've seen this type of crack on several Chevy rears from the 60s.
  9. Paul
    Paul
    Editor
    good you caught it before catastrophic failure
  10. X-cpe
    X-cpe
    I'd have to say your inspection went really well. Beats the hell out of sitting on the side of the road 100 miles from home calling 1-800-TOW-TRUK.
    Thor1, guthriesmith, Deuces and 2 others like this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
  12. rusty valley
    rusty valley
    It seems the "bugs" are being sorted out faster than usual here, good for you Squirrel, its inspirational.
    guthriesmith, X-cpe and Deuces like this.
  13. 51504bat
    51504bat
    In record AZ heat as well.
    X-cpe likes this.
  14. squirrel
    heh...less than 500 miles from home, I call my wife and she hooks up the trailer and come gets me.
    brEad, bchctybob, OahuEli and 18 others like this.
  15. guthriesmith
    guthriesmith
    That's great! Every time I head off on a road trip, I go ahead and hook up my trailer to my 1 ton for my wife in case I need her to come get me. She is willing, but I have been fortunate enough to be able to deal with issues on the road and not needed her to come save me yet...
    bchctybob, OahuEli, Algoma56 and 14 others like this.
  16. Crosley
    Crosley
    from Aridzona
    My wife is often with me when stuff breaks... wait a sec here. Hmmm ?
  17. squirrel
    Once my wife was with me when something broke, I got a friend to fetch our truck and trailer :)
    brEad, bchctybob, Deuces and 6 others like this.
  18. scofflaw
    scofflaw
    from Ohio
  19. squirrel
    looks like the same one that Johhny Gee linked above, and yeah, it would probably work.
    I was thinking about putting together another 3rd member to "go fast"...with posi and 3.70 or so gears.
    Doesn't take too long to change the whole thing
    Sancho, bchctybob, Deuces and 6 others like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Going back over your words does leave it open to wanting two 3rd members.
    Deuces and scotty t like this.
  21. MCjim
    MCjim
    from soCal
  22. I have a buddy who says I have a 1000 mile radius from his house for recovery help, I just have to pay for fuel, and food!
  23. squirrel
    I had bought some long studs to put in the axles and front hubs, just to make sure the shank lug nuts are legal if I go drag racing. I put them in the axles today...pressed out the old ones, set the axle in the mill, drilled the hole out to tap size, then used a transfer punch in the chuck to center the top of the tap and cut the threads by hand.
    AHotRod, enloe, Stock Racer and 30 others like this.
  24. squirrel
    The new gears arrived today, so I installed them, along with new bearings. It went together pretty easily, the first pinion shim I tried gave a decent contact pattern. New wheel bearings are in, too.
    It's quieter...no weird noises from the driveline or wheels. It's starting to rain, no top or wipers yet, so I'll go for a longer test drive in the morning.
  25. Deuces
    Deuces
    Nice wheel...:cool:
  26. guthriesmith
    guthriesmith
    Just curious Jim...when you install those longer screw-in wheel studs, do you Loc***e them in or anything? The last set I installed, I tacked them to keep them from ever backing out, but not sure if that is really necessary.
  27. TrailerTrashToo
    TrailerTrashToo
    You looked good in my rear view mirror.
    enloe, guthriesmith and squirrel like this.
  28. squirrel
    loc***e and 100 ft lbs torque
    enloe, Sancho, Tow Truck Tom and 5 others like this.
  29. Nice technique
    Tow Truck Tom likes this.
  30. squirrel
    thanks, it's the only way I could figure out to make sure they went in straight
