Hot Rods The El Stinko ‘60 El Camino
Discussion in 'The Hokey Ass Message Board' started by lewk, Jan 5, 2021.
  1. Squablow
    Squablow
    I was unaware you could eliminate the harness for that little external brain box thing from these later HEI distributors, that's actually really good info to know, as I have one like that in my '64 Impala project and I was thinking I'd have to replace the whole thing. I learned something valuable today!
  2. lewk
    lewk
    from Mt
    There’s a guy on YouTube that breaks it all down. Basically, you can make the 2 different kinds of 5 pin modules work like the normal 4 pin, but the later 7 pin module distributors don’t have a mechanical advance so they’re a lost cause.
    bchctybob, Squablow and lumpy 63 like this.
  3. Squablow
    Squablow
    I'll have to look at mine and see what it is, it's from 1980 but I'm not sure what they used then. Good info to have for sure.
    lewk likes this.
  4. benchseat4speed
    benchseat4speed
    from Golden, CO
    I take back what I said earlier about wide whites, your Camino would look so *****in done this way. Every now and then you see a car where everything, and I mean everything is right. This car is one of em. Coolest 61 bubbletop ever.
    *side note, I think he has PA6 factory chromes on the front. 14x5 I think, can't remember what the RPO code is for the 14x6's. Anyway, very very hard to find now.
    bchctybob, Stogy, lewk and 1 other person like this.
  5. lewk
    lewk
    from Mt
    @Moriarity Did you change your taillights? They look great, but I thought you had vintage smooth aftermarket.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    I did, these are 61 Pontiac lenses. I had to do a little lathe work to make em fit. The others were vintage Lee plastics lenses and after 25 years of people telling me that they couldn't see my brake lights on a sunny day I finally changed em....
  7. 4 pedals
    4 pedals
    from Nor Cal
    On your distributor, you can start with the weights and springs you have now, or pick up a kit from your local parts store that has a different set. Your springs look pretty heavy, which is going to make full advance slow. I like to have mine all in by 2500 or so, I would guess that your springs will not do that until 4000 or so. Once you're running, if you listen to your engine, it will tell you what it wants.
    Devin
    bchctybob and lewk like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    Coolest ever! Wow Thanks man. As far as the wheels go, I bought these used at a swap meet almost 40 years ago for 50 bucks. They’re all 14x6 with 2.5 inch backspace
  9. lewk
    lewk
    from Mt
    My daily was in a mood, so that took most of my weekend car time. I did run up north Friday evening and picked up two wheels from RMR&C. Thanks Scott! After a little cleanup:
    I’m becoming the rusty chromie king of at least my street. Maybe even this half of the state.
    I’ve now got 3 sets of three and a random deep reverse single. Of course the 5” ones are in the best shape.
    Current plan is to order some wood bleach and do a soak tank. If I can get the rust build up out of the pits, I’ll wipe silver paint into them and then polish it off the main surface. I could run spiders and cover up more of it. That might make them p***able. I’ve got one extra bad wheel to use as a guinea pig. Hopefully it doesn’t make the chrome peel.
  10. Squablow
    Squablow
    I've done that with the paint and actually had pretty fair results. I think it'd be worth the effort.
  11. benchseat4speed
    benchseat4speed
    from Golden, CO
    Oh gotcha. 50 bucks'll work! Yeah, we've all seen any year chevy done 100 different ways. Yours with the chromes, whites, two bar spinners, the color, shaved handles and emblems but all the trim still in place, white insert, white interior, the wheel, the dash, the grille, the ride height, taillights look excellent, I mean everything. It's not overdone, just a bunch of little details. It's a knockout. Should be in a magazine.
    Anyway sorry to jack your thread Lewk. You are the new chrome king wow got a collection in no time! Yeah I've done that on chrome reverse, not proud of it but it works really well. Clean em best you can with 000 steel wool and dish soap, and what rust you can't live with, hi-temp silver and wipe the overspray with brake cleaner. Cheesy but it works really well for a while.
    Agreed on this one. This car has the perfect look already. Real chrome reverse not FN baby moons. Little finish work and she's perfect.
    Okie Pete and lewk like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    Thanks, It was featured in Custom Rodder Magazine over 20 years ago
  13. lewk
    lewk
    from Mt
    I think I read about the paint on here. There’s some old threads about cleaning up rough chrome. People can have strong opinions on steel wool.
    Don’t worry about thread jacking. I like looking at that 61! I’m not doing much other than trying to get my OT Jeep to act right and hoarding wheels at the moment. I did order 2lbs of oxalic acid powder.
    What size tire are you running? I love that car.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    7.50x14 on the front and 7.75x14 Radir checkered flag tread slicks on the back 61slick.jpeg 61slicks.jpeg
  15. SS327
    SS327
    It will be running by June at the rate you’re going! Yay!
  16. lewk
    lewk
    from Mt
    Thanks!
    Halloween at the latest.
    SS327 likes this.
  17. loveoftiki
    loveoftiki
    from Livonia,Mi
    The new ones aren’t much better than silver paint around the centers anyway…
  18. lewk
    lewk
    from Mt
    Thanks. I was thinking about lighter springs at least, but I don’t really have a point of reference yet.
    The 5” wide wheels still have most of their chrome in the middle and it looks ripply and thin.
    bchctybob likes this.
  19. lewk
    lewk
    from Mt
    I got my oxalic acid.
    Chose my worst wheel.
    Soaked it overnight. My mix is 3 hefty tables****s per about 4 gallons of water.
    This is after a quick scrub and rinse.
    I’ve got to come home at lunch so I’ll check it again then.
  20. Squablow
    Squablow
    Already better, certainly isn't hurting it any.
  21. SS327
    SS327
    Might want to add a little more to the mix?
  22. lewk
    lewk
    from Mt
    I left it in a day and a half and here are the results.
    That’s long enough for a wheel I’m not going to use. I mainly wanted to watch what it did to the chrome. Nothing peeled that wasn’t already peeling.
    Next wheel:
    I souped up the soup a little. After 20 hours:
    I’ll soak it a little more and then try the silver paint thing. I want the pits cleaner.
  23. bchctybob
    bchctybob
    That worked well.... Great, now I'm going to have to do the old rusty chrome wheels that were on my Stude pickup when I got it. LOL. Gotta save old parts if you can.
    I bought some citric acid powder a while back, is Oxalic better?
    benchseat4speed and lewk like this.
  24. lewk
    lewk
    from Mt
    I’ve never tried citric acid. I had some green stuff I thought was citric but it turned out to be a sulfuric/phosphoric mix. That stuff will eat metal. I’ve also had some good luck with vinegar, but did pinhole some stuff too. People on various forums use oxalic on chrome, so I thought I’d try it. I’m. $30 in with the tub and the powder.
    bchctybob and benchseat4speed like this.
  25. bchctybob
    bchctybob
    Sounds good, I'll try it. Thanks.
    lewk likes this.
  26. Squablow
    Squablow
    Best results I've had using paint in the pit areas was with a metallic silver paint pen. It's not a perfect match but it's much easier to hit a tiny spot and fill it in with that rather than trying to use a brush or a spray can and having to clean the excess off. Although if there's a better way, I'd be very interested to hear about it.
  27. lewk
    lewk
    from Mt
    A paint pen is a good idea. I already hit some spots with a spray can. I’m waiting a day and I was going to hit it with some polishing compound and see how it goes.
    Done with oxalic:
    A little Rustoleum bright metallic aluminum:
    The lighting is different between the pics.
    I’m really eager to polish and see how this works out.
  28. lewk
    lewk
    from Mt
    I’ve been pecking away at a lot of little stuff. I got my poly locks for the rockers. I got some Chinese bling.
    I’ve dipped a million chrome wheels in oxalic acid. I finally installed the p***enger side front shock relocation mount. I rebuilt and installed the ebrake and glove box light switches. The reproduction glove box had the light pocket stapled on wrong.
    So I fixed it.
    I put the glove box door in.
    The bed subfloor has stampings that locate the gas tank. It isn’t reproduced and I need it. Pattern:
    And I made some stuff.
    I harvested some metal from the BeAir roof
    And cobbled this together
    First try bead rolling. If this was visible, I’d try for straighter lines. This goes under the car above the gas tank.
    And ***embled:
    There are a couple little brackets that still need to go on in this pic. I forgot to take a pic after they were done. Here are panels stuck in place but not trimmed. The front panel is sedan from the Bel Air. The ribs are different, but it’ll be just fine.
    I still need to make this one. I have a plan…
    I’ve had the gas tank tipped up with the filler neck pointing down. Terrible sludge ac***ulated in the rubber filler neck hose.
    Next up, I’m going to trim those panes, fix a cowl gusset, set the valves, and fool with the PS pump. I might put oil and a distributor in it too. I’ve got a radiator from the 59. I might mess with it before I have to turn off the garden hoses for the winter. I need to do some stuff to my daily before winter too.
  29. lewk
    lewk
    from Mt
    I’m finally back on the El Stinko. My wife’s Toyota’s rear hatch devoured its spoiler. That cost me some car time and money with backordered parts and cleaning my mess up enough to do paint. Then I decided to do a little deferred maintenance on my daily Jeep before winter. That spiraled into a header and full exhaust, slip yoke eliminator and new driveshaft plus lots of little stuff. I stopped myself before I re-geared and put lockers in it…
    I trimmed that sedan floor it fit. The radius on the turn down is different, but I’ll make it work. It’s all hidden anyway.
    I started making my rearmost section. It’ll take a few sections to get what I have in mind made. My beads are getting straighter, but still need improvement.
    After the Jeep, I had exhaust on the brain. I’ve never fabricated an exhaust before. I was going to buy a bunch of 2.5” 304 bends and do it the hard way, but a discounted open box kit turned up on the auction site. It was missing the clamps and one turn down. This ends before the rear tires, but there’s a rear kit available. This will save a ton of mess around. Unfortunately it’s 409 instead of 304, but it’ll still be great.
    This exhaust is set up for headers. I need to work out the missing section. I’ve got some bends in the mail that should have been here 5 days ago.
    I’m going to run gl***packs. I need to order em. Stainless ones are $$$. I’m not an exhaust guy and finding the right pieces to mate up to my 2.5” rams horn in stainless has been a pain. There are a few guys on the auction site selling aluminumized stubs, but not stainless. I’ve gotten this far.
    I still need a donut and a flange. I know I could try bugging the local exhaust shop, but my buddy’s buddy got in a fight with them over them using aluminumized connections on his high dollar stainless kit on a 56 210. I’m not interested in repeating his experience.
    I dug around and found an air cleaner. It’s ugly but it’ll do for now.
    I still need to go through the carb, PS pump, put the distributor in it, and more. Something has been dis***embling squirrels and birds under the car. I’m looking forward to laying in that mess as I do the exhaust.
    brEad, ffr1222k, SS327 and 9 others like this.
  30. RMR&C
    RMR&C
    from NW Montana
    Good to see you back on it!
    lewk likes this.
