I recently picked up a 54 customline with a 312 and a c4. The ****** has a Y block bellhousing. Can this bell housing be used for an AOD install? Or will I need an adapter to run the AOD. Any info is appreciated.
If it currently has a C4 it probably already has the adapter needed for an AOD, to verify call this place and talk to a Tech https://transmissioncenter.net/shop...d-transmission-on-a-ford-y-block-motor-fo301/
The adapters for a C4 to a YBlock that I have seen have a new bellhousing specifically made for the conversion. Won't work with an AOD.
Here is the straight answer, I asked the Chat Tech to confirm, the only difference is in the flexplate see the notes. https://www.transdepot.net/Ford-Y-Block-to-AOD-Adapter_p_746.html
Step by Step conversion with pictures http://www.y-blocksforever.com/tech/html/c4conv.html Here is one more. http://www.secondchancegarage.com/public/277.cfm
Corporate greed, screw the worker, screw the consumer and pay the share holders. Has little to do with whose in DC.
The Flat-O-Matic kit includes a replacement bellhousing, it does not use a flat adapter as shown above.
Yes, the Gene Benson kit sold as Flat-O-Matic has a custom bell housing, flexplate, crankshaft adapter, and a starter nose with a new bendix. Here are some photos of a C-4 with a 292 installed using one of Gene's kits. Like has been said, a C-4 has a separate bell housing, AOD has a one piece case with bell housing cast on, not removeable.
