Technical Advice on Wiring Looms, specifically universal 12v packages
Discussion in 'The Hokey Ass Message Board' started by Clydesdale, Jul 27, 2023.
  1. Clydesdale
    Clydesdale
    Hi all,
    After some recent run ins with the previous owners ‘handywork’ on my ‘51 Styleline.
    I have come to the conclusion it really would benefit from a re-wire. It has been very crudely converted to 12v and it’s a fire waiting to happen.
    A few friends have used a number of the available ‘universal’ wiring loom kits out there, all with a good degree of success. I’d like to keep it 12v as all the hardware is there and in good condition.
    Thought I’d ask if there was a consensus here on a good product?
    Also any tips and tricks for a good install, or tips to give it a more traditional look. As I appreciate these are marketed as quite ‘Street Rod’ friendly.
    Obviously in an ideal world I’d like to make one from scratch but having a young family means I’m tight on funds and time.
    Whilst I’m asking too, thoughts on turn signal switch units? It currently has a cheapie universal one and I’m not that keen on it. Should I try to find a factory unit?
    Thanks in advance fellas
  2. Koz
    Koz
    There are a couple of 12 and 14 circuit ones on Ebay for around $30! I bought a few now for budget projects out of curiosity and to be honest it's just as good as the $189.00 one. I've had no problems with it whatsoever in four different cars. No frills but they have good wire, decent fuse panels and are nicely put together. I can't buy the wire for $30. The ones I have use decent quality copper, not just coated, wire and all leads are clearly marked every six inches or so and properly sized. No idea why they're that cheap.
    I will say that Painless uses a better quality insulation on their wire at the $400 plus price point but nothing I would have reservations on. All depends on what you want.
  3. 51504bat
    51504bat
    Rebel Wiring. USA made, great tech support, AND an Alliance vendor as well. I've used 2 and would buy one again but at 72 doubt I have another major project in me. JMO
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Kwik Wire. I’ve used it on two vehicles.
    irishsteve and bobss396 like this.
  5. deucemac
    deucemac
    Another idea is what I used. I used s centec fuse panel and a removed wiring harness from a stolen recovery Lincoln Town car. I was working I a Lincoln-Mercury dealership and a guy walked by with a huge ball of wiring, headed for the dumpster. I stopped him and asked about the wiring. Seems the car was stolen and the thieves removed all the electronic and electrical components but cutting the wires just behind the connectors. The insurance company popped for a new, complete car harness and the mechanic was told to toss the old one. Well, I was wiring my roadster at the time and grabbed the harness. I used all the Ford wires correct for each circuit and correct color coding. Next guy who get my car after I croak can easily diagnose any problem using a Ford Factory manual. T was cheap, reliable, and correct for Ford. You might check with insurance companies or GM dealers and see if something is available cheap. But, even if you don't do that, most aftermarket wiring harnesses default to GM color coding and wire gauging.
    vtx1800 likes this.
  6. Clydesdale
    Clydesdale
    Thanks chaps, that's definitely a help!
    Il look into the Rebel Wire kit.
  7. 325w
    325w
    Rebel will be fine
    caprockfabshop and 51504bat like this.
  8. RMR&C
    RMR&C
    from NW Montana
    I have used both the Rebel and the American Auto wire 12? circuit. Both were good quality but I prefer the AAW fuse box design better
    shivasdad and gimpyshotrods like this.
  9. theHIGHLANDER
    theHIGHLANDER
    Rebel. Done. Problems? Call em, they talk to you like they're your pal. Wired my whole car for less than $200 including stuff not from them. Turn signal switch, hard to beat the tried and true Signal Stat still available at NAPA. There's a part# in my build thread. I made changes that added addl work like maintain the column twist light switch vs an unceremoniously added push/pull. Wasn't hard, and as to how to keep it somewhat "true" just cover some sections in the lacquered loom available from restoration supply shops. Not cheap but not out of most budgets. There's some of that visible in my build thread too.
  10. Mike Lawless
    Mike Lawless
    I used a EZWire kit for my '65 f100. Reasonable price, and the quality was good. Converted to a one wire alternator while installing the kit. Pretty easy to do and I'll be danged...everything worked the first time! The hardest part to figure out was sorting g the Ford turn signal switch wiring. A conversion diagram was supplied, but instead of using the GM style connector, I used an 8 pin Deutch connector. Even that worked the first time!
    bobss396 and alanp561 like this.
  11. vtx1800
    vtx1800
    I've used three Rebel kits, happy with all three. That said...if you are really down on money and long on time @deucemac suggestion is pretty good. The first time I wired the 38 Chevy I used the wiring out of a 57 Chevy including the fuse panel, that was 50 years ago:)
  12. I'm at the same decision point (replacing wire my way) with my car. I've read nothing but good comments and good service from Rebel. I will be purchasing my Rebel kit this Winter. And as someone mentioned they are a HAMB vendor so you can get a discounted price. Good luck and happy motoring.
  13. David Gersic
    David Gersic
    from DeKalb, IL
    There are a couple of really good wiring threads here. You should read them before continuing. Whether to home brew or buy a kit, the advice in them is good.
    For a more traditional look, get some lacing tape and use that to bundle your wires instead of the more common and non traditional zip ties.
    manyolcars and alanp561 like this.
  14. Another vote for Rebel kits. Simple, good quality and easy to customize. I've used two 9-3 kits.
    It depends really on what you want and what skill level you have.
    I also bought wire from Rhode Island wire (cloth covered) to build the harness for my A. I think after the smoke clears I'll have more money into building my own, only because of the specific wire I wanted to use.
    I also won a cheapo harness from a poker run and I'll try that on another car.
    gimpyshotrods and 51504bat like this.
  15. jaracer
    jaracer
    I used a Painless kit on my Model A. I'm currently finishing up an American Autowire kit on a 66 Olds 442. If I have to do another I'll use a Painless.
    lumpy 63 likes this.
  16. panhead_pete
    panhead_pete
    I bought a Speedway kit with the micro fuses. Yet to fit it but looks to be good enough quality.
  17. X38
    X38
    Good god man, don't say that when talking about electrical stuff! :eek::D
  18. Check out Coach Controls. A bit pricier but very nice quality and gives a bit less 90s era GM wiring vibes.
    Clydesdale and Bandit Billy like this.
  19. Rice n Beans Garage
    Rice n Beans Garage
    Rebel on this end!!
  20. Bandit Billy
    Bandit Billy
    It is probably the most expensive option on the market...and the one I have used in my last two builds on the HAMB. This is the one in my 41 PU. I mounted it in the seat riser, if you're lost. All of the relays, flashers and circuits needed to build anything you can imagine...and then some.
    2Blue2, Toms Dogs, R A Wrench and 5 others like this.
  21. alanp561
    alanp561
    I called Rebel because they are a HAMB vendor and only 20 miles down the road from me. Since my Model A is very basic and it's 6 volts, I got their 8-circuit kit with heavier wiring. When I start on my '46 Mercury, I'll go back for a kit with more circuits. Super nice people to deal with.
    R A Wrench and 51504bat like this.
  22. Sky Six
    Sky Six
    from Arizona
    On my '48 Stylemaster, I just got a kit from Speedway. Worked fine.
    mrspeedyt and alanp561 like this.
  23. nobby
    nobby
    buy 1/2 inch copex that is already split use 1'' bits for setting out
    when you are finished place in the long lengths and pull up tight
    get a short length of fatter copex
    get some bullet connectors for the headlights
    buy a gm style floor dip switch if you havn't got one on the column
    fit a relay on the starter circuit
    if you have a high demand ooga horn - fit a realy, especially if you have split the steering columns earth / ground route, you do not want high ampres running over the br*** horn contact
    something about an aftermarket ignition switch and the accessorie tang, and dont use it
    oh and IF you want to try and keep it factory and use the steering column flat plug BEFORE you start DO NOT TRY as they use the middle version of connector, designed for gm applications where the hi-lo dip switch is on the floor, hazard and turn in the column bell / switch, the connection spades are specific to that year of column, and the juice IS NOT wot]rth the squeeze, simply fit a modern molex type connector.
  24. RICH B
    RICH B
    ^^^Not to be harsh; but that black plastic split loom does not have any place on a hot rod.
  25. That built in light is clutch! Love it.
    Bandit Billy likes this.
  26. Does if the owner wants it!
    Ben
  27. s55mercury66
    s55mercury66
    from SW Wyoming
    Nylon zip ties have been around since 1958
  28. gimpyshotrods
    gimpyshotrods
  29. Bandit Billy
    Bandit Billy
    ^^^^Damn that stuff is hard to use when you have arthritis. My hands hurt just looking at it.
    Toms Dogs likes this.
