Technical Choke pull?
Discussion in 'The Hokey Ass Message Board' started by JorgeFleet48, Jul 27, 2023.
  1. JorgeFleet48
    JorgeFleet48
    Good evening
    Is the knob in the picture the choke? Trying to figure out if the car came with auto or manual choke.
    Thanks in advance
  2. I would guess that is the headlight switch. I recognize that as a Chevrolet, but what year and model?
    JorgeFleet48 likes this.
  3. fastcar1953
    fastcar1953
    Manual . It would be on the right side by ign. switch.
    JorgeFleet48 and Bob Lowry like this.
  4. BJR
    BJR
    Not too hard to figure out, take the air cleaner off and see if a cable goes to the choke. If so follow the cable back to the dash.
  5. vtx1800
    vtx1800
    If I remember correctly the choke and throttle controls were mounted below the center of the dash...I had a 48 and can't remember for sure regarding the throttle cable but I remember early 50's chevy pickups had a throttle cable too, probably for when a power takeoff was used.
  6. Mr48chev
    48 Cars if that is a 48 (it's always best to give info on what vehicle you are asking about as to year, model and engine size) had a manual choke. Screenshot (2030).png
    JorgeFleet48 and 2OLD2FAST like this.
  7. Mr48chev
    By all rights and regulations the knob next to the key should be the choke knob. Screenshot (2032).jpg
    JorgeFleet48 and X38 like this.
  8. If you suspect that you will have to put in a new carb, you probably can make it either way.
  9. JorgeFleet48
    JorgeFleet48
    Thank you all and apologies on the year and model I forgot all about that part.
    48 fleetmaster.
    Thanks again
    Truckdoctor Andy likes this.
