Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Dick Stevens
    Dick Stevens
    Guide coat on the primer will help you if you can't see all of them with just primer.
    Lloyd's paint & glass likes this.
  2. squirrel
    Not a problem for me, I gave up painting cars.
  3. mad mikey
    mad mikey
    Got new front runner tires on the drag coupe. No pictures yet. I will get to that later. Going to a show tomorrow, If no storms.
  4. 57 Fargo
    57 Fargo
    Not a problem for me either, I’m just not that picky.
  5. 57 Fargo
    57 Fargo
    Started sanding yesterday, got the drivers side pretty close to finished, touched up a couple dings/spots I missed.
  6. choptop40
    choptop40
    Plum Crazy would be a cool color !!!
    2Blue2 likes this.
  7. 57 Fargo
    57 Fargo
    I love plum crazy but with the red interior white it is
  8. choptop40
    choptop40
    Car is so cool...Keep posting..
    57 Fargo likes this.
  9. squirrel
    The air cleaner on the Corvette is an aftermarket one, modified to sort of fit, and I haven't got round to ordering a new one (they're not cheap, of course). The stud and nut rub the hood, and eventually will eat a hole through it.
    so I measured and looked in my old Wix catalog, and there's an element available that fits some early 60s fords, that is about 3/8" shorter. So I finally got one, and put it in, and cut the stud down a bit, and cut down a wing nut, and got it finished.
  10. chevy57dude
    chevy57dude
    Yep, also, many intake swaps ended up with an air cleaner stud denting hoods from the inside! Laughed at a friend for that when we were teens.
  11. saltflats
    saltflats
    from Missouri
    Getting this nailhead ***embly together.
  12. Kevin Ardinger
    Kevin Ardinger
    I’m working on my fifth beer.
  13. BJR
    BJR
  14. Zax
    Zax
    Stripped and painted this Model B timing cover. Used Bill Hirsch paint. Seems to be good stuff.
    That and tried to clean/organize the garage. I need to make some room to work. If everything works out i'll be doing an engine swap on my '40 Ford soon. IMG_2100.jpg
  15. choptop40
    choptop40
    ..looks like im gonna need a new engine hoist...anyone buy the harbor freight ones...
  16. Zax
    Zax
    I had one for a while about 12 years ago. Did the job, no issues. Sold it when I moved.
  17. I don’t have the Harbor Freight hoist, but that’s exactly what I’d buy if mine took a dump.
  18. choptop40
    choptop40
    Ok ..what can go wrong..the hydraulic cylinder..Should last ..I like them because the fold for easy storage...
  19. 57 Fargo
    57 Fargo
    Got more sanding done on the Barracuda, probably 75% sanded, going to re-prime one quarter. Then spray some door jambs white and should be almost ready to paint
  20. atch
    atch
  21. squirrel
    I've been tinkering with old radios. theHighlander sent me another corvair radio, but it was a bit newer than the one I had....it didn't work either, so I tried using it's output transformer to fix the other radio, no dice. I went to the back up plan, and kind of gutted it, and installed a modern amp inside, so I can connect power, speaker, and plug an mp3 player into it. And the power switch and volume control work, which is something that's important to me. Oh..it only has one speaker and one channel, so it's not really a stereo amp any more. But that's ok.
    Oh...the tuning knob and push****ons still work to move the pointer inside....that's also important. Even if they don't do anything.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Here’s one I did. Byp***ed the radio switch to turn blue tooth amp on and off. I like full time 12v so I added a buzzer in case amp accidentally gets left on. 1F2C7191-8E7C-4B78-9883-CF28CC30D8AD.jpeg 02DD0173-635B-4385-A8D9-8A03341D15A2.jpeg
    Blk cord goes to amp Wht wire taps into door jamb switch.
  23. PhilA
    PhilA
    1933 Ford glovebox radio come back in for repair and conversion to 12V.
    Cheating on this one a little with a 12-6v buck converter which is going to be tucked away inside.
    Going to realign it too, see if I can't improve the reception a little.
    Phil
    40two, Okie Pete, rod1 and 1 other person like this.
  24. PhilA
    PhilA
    There we go.
    Now works on anything from 9 through to 24 volts.
    Radio pops and crackles away, needs a tweak to get it 100% but that keeps the input to the circuitry at 6.00 volts, stable.
    Phil
    40two, Okie Pete, chevy57dude and 3 others like this.
  25. 57 Fargo
    57 Fargo
    re-primed the quarter that required a fair amount of “touching up”. Then put some sealer on the door jambs.
  26. Bandit Billy
    Bandit Billy
    I am glad the ole b'cuda is sitting on tires as well as jack stands. I watched my old t-turd roll right off the stands on a gravel surface in my misspent youth. Anxiously watching for the finished pics.
  27. 57 Fargo
    57 Fargo
    I wouldn’t watch too hard…I’m a total hack compared to most building cars on this forum…
  28. 57 Fargo
    57 Fargo
    door jambs are white, I have some non car related things to look after the next few days but hope to have paint on it next week.
  29. 57 Fargo
    57 Fargo
    I also just noticed I left the window crank and the door handle on the inside of the p***enger door…doh!!!:(
  30. chevyfordman
    chevyfordman
    I decided to replace those plastic teardrop 39 taillights with original style with gl*** lens and stainless retainer ring. I had to cut a bigger hole but I really like the light, very bright and looks like a bulb inside but it's really LED. Speedway brand. IMG_1574.jpeg IMG_1576.jpeg
