Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. lumpy 63
    lumpy 63
    What master Jim ?
  2. squirrel
    Making purists cringe is a way of life
    I haven't figured out the master cylinder yet...might try the stocker, might try the Mopar dual, or see what else is available.
    the brakes I'm getting have a drum parking brake inside the rear hat.
  3. SS327
    SS327
    So you’re putting corvette brakes on a corvette? Use a corvette master cylinder.
  4. squirrel
    They're not Corvette brakes, they're aftermarket. The 60s-70s Corvette disc brake master cylinder isn't quite so easy to adapt to the early cars, as you'd hope. It has a three bolt pattern, and is recessed into the firewall a ways.
    bchctybob, Thor1, 41 GMC K-18 and 6 others like this.
  5. 65pacecar
    65pacecar
    from KY, AZ
    MoPar master cylinders are pretty easy to adapt to any build and if you go power disc their boosters aren’t huge either. Some people put Hemi’s in their Vettes so a Master Cylinder should be acceptable.
    Algoma56 and scotty t like this.
  6. squirrel
    The booster would have to extend out a ways, and I'd rather not run one if I can avoid it. The late 60s dual Mopar MC will adapt by t******* the flange and drilling three holes in it.
    Tman, Algoma56, Thor1 and 5 others like this.
  7. RodStRace
    RodStRace
    Sounds like you have it all scienced out. Hope the calculations for bore size and stoke make a booster unnecessary. Of course we expect pictures and a review after install, like you always have.
    bchctybob, Algoma56 and 41 GMC K-18 like this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Nice, never cared for that cork screw set up of adjusting park brake.
    RodStRace, 427 sleeper and scotty t like this.
  9. Dan Hay
    Dan Hay
    My coupe has C3 disc brakes on the front and they are two piece and they leak (at the seam) and squeak. So I hope you went with aftermarket brakes.
    I’m about to jettison them in favor of something more modern.
    41 GMC K-18 and 427 sleeper like this.
  10. squirrel
    I didn't want the weight of OEM brakes from the 60s-70s....
    bchctybob, Thor1, Sancho and 3 others like this.
  11. Probably based on the Ford Explorer rear discs, that's the design Ford used. Those calipers with the built-in parking brake are a PITA to work on. That's why I got rid of the 9" Versailles disc rear axle I had... more trouble than they were worth.
    bchctybob and Truckdoctor Andy like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Another factor, 62 has king pins at the spindle so how does one adapt C2 and up braking to the front?
  13. squirrel
    There are quite a few varieties of kits for brakes for these things, they include brackets to mount the caliper to the spindle.
  14. I’ve got the modified MOPAR unit on the 57. It’s pretty simple to mod one
    Algoma56, lumpy 63 and 65pacecar like this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    True. But why stop there on a C1 if you get what I’m aiming toward by using later Vette braking components.
  16. justpassinthru
    justpassinthru
    Jim, did you look at what Master Power Brakes has to offer?
    I use their stuff regularly.
    No bling, nice quality stuff that actually fits.
    mpbrakes.com
    Bill
    bchctybob likes this.
  17. chicken
    chicken
    from Kansas
    There ya go. Your car and your fun!
  18. Here’s why it’s hard to use a common master cyl on these cars. The mopar cyl has a larger 4 bolt flange with room to adapt to the vette pattern F4088F7B-CCDA-4F4D-9A47-149A87C35FEF.jpeg D96CC649-C4B3-4EAF-BE83-C2DAD1418EBF.jpeg
  19. justpassinthru
    justpassinthru
    That's a nice looking install.
    Did you engineer the mounting and modifying
    of the master, or is it store bought?
    Bill
  20. Thanks, i bought an auto parts store master and had a machinist buddy cut it up with plans from the corvette forum. It’s a fairly popular swap
  21. 65pacecar
    65pacecar
    from KY, AZ
    Understood and agree it would look better without it. May Check out the Mopar 1973 Dart (A Body) Master for Manual Disc Brakes. I've used it on several projects with great luck.
    Algoma56 and 427 sleeper like this.
  22. lumpy 63
    lumpy 63
    Thats whats on my Vette, Scotty sent me the drawings I did it on my lunch break at work.
  23. squirrel
    What bore size MC did you use?
    Deuces likes this.
  24. I believe it’s 1” bore
    65pacecar and lumpy 63 like this.
  25. V7
    V7
    Following this great thread as I just purchased a ‘61 Vette , 2 top , 4 speed , 2-4 bbl car that hadn’t been driven in 30 years . Looking to end up with a good driver , originality is secondary . Thanks Jim , for do***enting your build .
    warbird1, bchctybob, Algoma56 and 9 others like this.
  26. 65pacecar
    65pacecar
    from KY, AZ
    Nice buy, do you have pics to share or another build thread started? There is a 62 near me that probably hasn’t moved in 40 plus years, I would love to get them to sell it to me or trade it for my OT Vette so they would have a driver and I would have a fun project.
  27. V7
    V7
    I don’t want to hijack this thread but when I get over to where the car is stored then I will take some pics and post them .
    Deuces and 65pacecar like this.
  28. ClayMart
    ClayMart
    Sounds like something that should be printed on a HAMB T-shirt . . . :eek:
    :p
  29. OahuEli
    OahuEli
    from Hawaii
    Can't agree more; my avatar, with the big block, 4 speed and 3:73 geared 9" but original brakes was a blast to drive up to 100 mph+, but trying to stop quickly and straight was definately a "Skid Marks in the Skivvies" moment. Scared the hell out of myself more than once. Wilwoods will definitely extend the life of the Fruit of the Looms. :D
  30. bobss396
    bobss396
    My car is full of one-off parts I made along the way. The benefits of having a machine shop on site are staggering.
