Anyone here into large scale (1/8) car models???
Discussion in 'The Antiquated' started by Deuces, Dec 10, 2010.
  1. BIG-JIM
    BIG-JIM
    from CT
    I have a blower edition and a frenzel supercharger setup in the works. I also make lake style headers.
  2. gnichols
    gnichols
    from Tampa, FL
    Gang,
    Anyone ready for another one of my 1/8th train projects? Here are some mock up shots of my latest gizmo, designated A-5, which is based on a 1/20th scale rail truck ch***is that I ran thru my band saw the long ways to get it as slim as possible (just keeping the front truck / crossmember, electric motor, drive shaft and diff / rear wheels). On that I'll add some custom decking that will fit between the Lindberg T bucket's frame to tie the ch***is and T kit together. Sad to say there won't be room under the hood for a scale engine, as I'll have to mount the sound board and the RX board for remote control there, on stand-offs that will place them over the electric motor. A 4-cell, 2200 mah battery pack and some control switches will go in the bed, between the roll bar down tubes. Speaker under the decking. I plan on having one crewman and a lot of lights, tools and junk here and there. Not sure on the paint and weathering. I might go with basic Ford black and some mild weathering, or perhaps a brighter color and a heavier dose of rust n dust. For comic relief, I plan on putting an HO scale loco smoke generator where the radiator's filler neck would be located (the cap hanging loosely on a little chain) so I can have it "overheat" on demand now and then. The bed will have 3 versions: the OEM flat toneau cover, a false load insert with tools and supplies, and an alternate insert with a small tank with extending sprayer arms for weed control. I really want to keep the T's tall top, but it is very spindly and won't hold up to the physical handling model trains get. So, I might try making the top bows out of br*** rod to make a lot stronger. It may pull a small trailer now and then.
  3. rudestude
    rudestude
    You know I looked at the beginnings of the T-Bucket build and thought COOL....but thought that was a odd place to mock it up , on railroad tracks? But hey what ever...then read on and gathered that you were putting together a model T-Bucket for railroad use....ok odd but hey they used them for alot of other things but I had never seen one for the rails, so I went online to see what I could find.....here's a few I spotted.
    Better yet I have been wondering what to do with a 1916 model T touring car that I acquired....and just down the hill maybe quarter mile from my house are railroad tracks.....well I think I got an idea? 16580503311277570971597470555861.jpg 16580503897292902137140031788581.jpg 16580504013995015507576432452151.jpg 16580503514598303851240058986534.jpg 16580504131856189755833853353813.jpg
  4. gnichols
    gnichols
    from Tampa, FL
    Railcars and trucks have been around for a long time and as a model railroader over the years I've gained a special attachment to them, especially the funky versions. Not unlike hot rods, early railcars were shop-built from donor cars and junk RR parts. But I'd caution you about building a real one as there aren't many places to run them. My model is extremely whimsical because of how low it is and that the track gauge is very narrow. 56-1/2" track is standard gauge. 36" is a common narrow gauge. Most of the old railcars are built to either one of those gauges. My model's gauge in scale is only 14" so it is, more or less, a cartoon caricature of a real one.
    Over they years these gizmos were replaced by custom manufactured vehicles, the bigger ones based on commercial trucks that also retain road wheels / tires for motive power and so they can be driven on / off the rails where needed. Smaller crew car speeders, or "pop" cars, are still in use at some places. There are quite a few people who run their restored speeders on track reserved for club operations and you should have no trouble finding a club in your region, or of one of the National organizations for them on the web. I've seen some new builds based on old Ford parts, too, but they aren't as popular as acquiring and rebuilding original pop cars. I went on a weekend excursion with a friend on his speeder a few years ago. It was fun, but they are pretty slow. But the scenery in NE Georgia was wonderful. He normally runs his with a buddy who has a good tow vehicle and trailer and they have to be manhandled on / off the tracks. Some of the early T railcars could also be used on the street for very short distances (perhaps to get out of the way of an oncoming train?), while still using RR wheels, if they had a locking pin ***embly on the tie rod, so the steering could be unlocked for short road work. Many of the early vehicles used for rail cars had engine controls on the steering wheel, so it was usually retained - otherwise you'd have no need for the column or steering wheel while riding the rails.
    Deuces and rudestude like this.
  5. rudestude
    rudestude
    I actually do have other plans for my model-T ,but some ideas did go through my brain.
    We always called the little work cars "Putt Putts" in fact the railroad tracks I mentioned many years ago I would walk the tracks with my grandfather to one of our fishing spots, the tracks run along the Columbia river that separates Oregon and Washington...I'm on the Oregon side....and there was a shed next to the tracks that had one of these old cars parked inside, it was in there for many years untouched then the building started to fall down and it went away.
    My grandfather told me the story of how the old hand pump car that was parked in the shed years before the motorized version replaced it had a part in the birth of my father....what....
    My grandparents never owned a car so when my grandmother was getting ready to give birth to my father my grandfather took her down to the little shed next to the tracks pulled the pump car out onto the tracks ...loaded my grandmother on board and pumped that car to the next town ,about 8miles,where a motor car was waiting and took them across the bridge into Washington and the Hospital ...and my father was born January 27 1940.
    Sorry to ramble just thought it was a cool story.
    Deuces, down-the-road and gnichols like this.
  6. gnichols
    gnichols
    from Tampa, FL
    An amazing story. I've also heard of speeders being called "pop" cars, for their exhaust note.
  7. Deuces
    Deuces
    Nice clean build....
    gnichols likes this.
  8. headsoff
    headsoff
    from Ely UK
    Here's a couple of my builds.
    Both kits need a fair bit of restoration now. They have travelled to many model and car shows over the years and are showing their age.
    I've also just placed my first order with @BIG-JIM for a five window coupe body and a few other parts. Once that lot gets here I'll have a difficult decision to make, what kind of build will I do?
    These two both push all the right ****ons for me. The trouble is, so do about a hundred others!
    Whatever direction I take, the results will get added here.
    Tony.
  9. Deuces
    Deuces
  10. willys36
    willys36
    I made my Mysterion build presentation at the GSL in May and the video is posted at Mark Gustavson's Model Car Builder's Museum web site soon.
    Here is the video
    https://archive.org/details/gsl-**v...g-you-ever-wanted-to-know-about-the-mysterion
    For Jollies I entered the car in the contest and it won second place, Reproduction category. First place in the category went to Randy Duer's insane 1/12 scale Corvette road racer. Not only did it win the Best in Category, it won Modeler's Choice, Best Detail, Dave Shuklis Best Engineering, and for good measure, Best in Show awards!
    Sancho, 41 coupe, lurker mick and 2 others like this.
  11. BIG-JIM
    BIG-JIM
    from CT
    I haven't been on here for a while but I've been busy working on bringing new hot rod products to market. I now offer a chopped 33 Ford 3-window coupe, Finned aluminum brake backing plates, SCOT blower set-ups for both the ford flathead V8 and the lincoln V12 engine, and much more. Here is my catalog.
    kiwijeff likes this.
  12. BIG-JIM
    BIG-JIM
    from CT
    Here is a fraction of what I've added in the past year. All in 1/8th scale. The best way to get ahold of me is through email cheby33@gmail.com or through Facebook Jim Pelosi
    kiwijeff, slowforty, b-bop and 4 others like this.
  13. big duece
    big duece
    from kansas
    Looks GREAT Jim!
    Deuces likes this.
  14. BIG-JIM
    BIG-JIM
    from CT
    Thank you.
    Deuces likes this.
  15. BIG-JIM
    BIG-JIM
    from CT
  16. s.e.charles
    s.e.charles
  17. BIG-JIM
    BIG-JIM
    from CT
    A few more 1/8th scale resin items that I offer. Spider caps, tiki shifters, skull shifters, German helmet air cleaners in 2 sizes, hood blisters, and even a shrunken head!
    Deuces and big duece like this.
  18. After years away from building, I've been getting my eight 1/8 scale builds finished up. At least that's the plan.
    I'll get some pics sorted.
    Deuces likes this.
  19. A Boner
    A Boner
    Any 1/8 scale model builders ever check out the Vintage Tether Car thread on here? Similar scale, mostly scratch built race car type builds, using wood, aluminum, fibergl***. Aluminum casting are sometimes for sale on sites like EBay. Here is a pic of a neat scratch built track roadster style. If you look hard enough you can find some blueprints too.
  20. slowforty
    slowforty
    I am doing a Ford GT from DeAgostini 1/8 scale.
    Well constructed Kit but not cheap.
    Brake lights operate when you push on the brake pedal.
    Wish my 40 Ford worked as well.
    About halfway through.
    Screws are real small and dexterity is not so good any more.
    Magnifing gl*** and magnetic pick up tool is my new friend.
    Also purchased a 1/6 67 Mustang Bullit Car.
    Also not cheap .
    Hope I live long enough to finish both
    Lepus, Deuces and down-the-road like this.
  21. A Boner
    A Boner
    The “not cheap problem”!
    That’s the neat thing about building tether cars or especially their static model cousins. Can be mostly scratch built from miscellaneous materials. Tires are the hardest/trickiest item to source, and are the best place to start…then the build can be scaled to the tire/wheel size.
    Deuces, down-the-road and 41 GMC K-18 like this.
  22. Deuces
    Deuces
    I think the Bullit pony is a '68.....
  23. A Boner
    A Boner
    Just picked this up. Sort of a model…and sort of 1/8th scale, Doepke Model Toys MG…about 15” long, cast aluminum body and C chanel steel frame. They came as an ***emble it yourself kit. From 1950’s-1960’s. Pretty slick!
  24. A Boner
    A Boner
    IMG_2664.jpeg There are some “kid” neglected Doepke MG’s and Jaguars on EBay that are in need of a restoration that are quite reasonably priced…”most”replacement parts are available, too. Some guys skip some of replacement parts, and build it as a road race version….minus windshield, bumpers and such. Might be a good winter project, that is more readily available than the 1/8 scale plastic models are.
    The Jaguar version is usually valued quite a bit higher, than the MG!
