Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. 31Apickup
    31Apickup
    What set up did you use for the cruise control?
  2. mike in tucson
    mike in tucson
    from Tucson
    I thought the Beach Boys were all baritones with my ****py speaker with lots of sand on it.
  3. squirrel
    It's an older Rostra 16-R that I've had in several cars over the years. Pretty easy to install it since I've done it so many times.
  4. ***Area-51***
    ***Area-51***
    from Ohio
    Squirrel using cruise control in a hot rod....didn't see that coming, who would've thought??
  5. squirrel
    I end up driving on long trips, and old cars and hot rods usually put a strain on my gas pedal foot...so I like to add cruise control. I'm hoping to drive this car to Drag Week in September, that's 2000 miles each way. Maybe you can handle it, but I need some help.
    I had cruise in Plan II when I drove it to Drag Week in 2021. It was nice.
    Mr48chev, AHotRod, bchctybob and 20 others like this.
  6. ***Area-51***
    ***Area-51***
    from Ohio
    Jus funnin with ya, it did make me wonder if Plan II had cruise, nothing wrong with cruise I use it all the time
    Deuces likes this.
  7. squirrel
    I drove Plan II to drag week twice without it...that was enough for me!
    AHotRod, bchctybob, Thor1 and 6 others like this.
  8. 57 Fargo
    57 Fargo
    My Fargo is getting cruise before our adventure this fall
    Deuces and TrailerTrashToo like this.
  9. Lloyd's paint & glass
    Damn, no Plan II at drag week this year??
  10. squirrel
    We'll see, it's the back up plan this time
  11. Lloyd's paint & glass
    I was gonna come to Indy, but I'll probably hold off, gotta get everything in line for Lloydfest lol
  12. jimmy six
    jimmy six
    Huh?
  13. lumpy 63
    lumpy 63
    Wait ...What? A couple of pages on reverbs, amps , speakers and cruise controls... And Jim is putting aftermarket four wheel discs on something. I believe an alien abduction has happened here.....
  14. squirrel
    Oh, just wait till I run it at the drag strip, my perspective will flip again! :)
    going to try to take it up to Tucson early September when the track opens up again after the rainy season ends.
    In a positive note, I ordered some slicks today for it
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You sourced another 3rd member then?
  16. squirrel
    Not yet. I'm still thinking about it....
    I did a little computer playing with an old drag race simulator program (it runs in DOS) and optimistically it suggests that 3.70 gears will be about right with the engine that I have set up now. The program predicts mid 12s, which sounds very unlikely to me, I'd be happy to get in the 14s with it.
    The other issues is how fast it's allowed to go, and how fast it really will go. And all those NHRA rules. Looks like a convertible needs a roll bar to go faster than 13.50, and a drive shaft loop to go faster than 14.0.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    When you did the screw in studs I wondered how far you’d go down that rabbit hole.
  18. bobss396
    bobss396
    We used to grab the reverb units from junk GM cars when I was towing, I usually sold them quick, never set one up. It was a quick $5 or $10 bill in my pocket.
    chryslerfan55 and Deuces like this.
  19. bobss396
    bobss396
    Did you need a GW basic disk to boot the computer? I still have one around from my early NC programming days in college around 1986.
  20. squirrel
    I don't have any more computers that will actually read a floppy disk, unfortunately. But I do still have MS DOS 1.10 in the box with the original floppy disk from 1982....one day it'll be worth something.
    Meanwhile, back to old Chevys....
  21. Lloyd's paint & glass
    I used to have the Mr gasket computer dyno, fun times. So will the Corvette spider gears hold up better in the Corvette with slicks better than the other 57 Chevy cars?
    scotty t likes this.
  22. squirrel
    I doubt it. I probably ought to get a stronger 3rd member in there....
    Those axles are rather skinny, as well.
  23. 57 Fargo
    57 Fargo
    While you are upgrading the rear differential it seems like a good time to add a blower.
  24. squirrel
    I fiddled with the p***enger side door, got the panel installed. Aside from being the wrong color, it looks nice, eh?
    The driver side will take some more work, I have to round up some more screws, and fix the screw holes. I used some epoxy mixed with "microspheres" to make some filler to use on the p*** side. It seems to work ok. I probably need to add some type of cloth or mat to the larger holes, the ones that are over 1/4" diameter, before trying to fill them.
    Screw holes in fibergl*** are the bane of Corvette interiors, apparently. Anther fix is to rivet a small metal plate over the hole.
  25. saltflats
    saltflats
    from Missouri
    The last one I did I was lucky enough to just use a paperclip looped through the hole.
    squirrel and 427 sleeper like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    This is what I use, drill to 5/16 insert and the plastic hole holds a screw real well
    50E9BB27-55D9-4225-9B6C-219F68631B62.jpeg 84C3F545-1533-45FF-A7DF-A57AE965C5A5.jpeg 7DA35525-5C53-419B-8100-AB63FE60D4B9.jpeg
  27. squirrel
    I've read about the paperclip trick....I'll probably try it on the sill screw holes. The door panels are a mess, some of the holes are out to 3/8" or so. Most just need a dab of filler.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    I have used cotter pins instead of paper clips, they work good too if the hole is stripped bad....works on stripped sheet metal holes too
    bchctybob, 427 sleeper and squirrel like this.
  29. lumpy 63
    lumpy 63
    I used kitty hair on a few of mine.
    427 sleeper, scotty t and squirrel like this.
  30. I used the metal plates on my 60, years ago
    427 sleeper likes this.
