Steering box assistance for 32 roaster ...
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Detroit Steel, Sep 25, 2006.
  1. Detroit Steel
    Detroit Steel
    Hello everyone,
    I was hoping that I might get feedback on how to repair the steering box on a 32 roaster (old hot rod built in the late 70's, early 80's). The steering is sloppy and has some play in the box and perhaps in the 2 U joints. I can't seem to find a manufactures name on the box; however, it is stamped with the following serial number ... 7808990. The box has a adjustment value/screw on the top ... it is in the middle of what appears to be a lid (fasened on by 3 bolts). There is a circular plug in the front of the box (facing the nose of the 32) that seems to screw into the box. Lastly, the box is fastened to the frame by 3 bolts (2 on the bottom, one on the top). The box measure about 6 inches long and about 4.5 inches high (just the box itself). Any repair information would be greatly appreciated.
    Thx
    DS
  2.
  3. 37 BILL
    37 BILL
    from Bristol CT
    Hi ...The box you have is an oe saginaw 140(vega) box...still used widely today....We can reman your box at work...Borgeson...or ther are plenty of aftermarket co's out there making off shore repos...we also have GM boxes at work if you wanted a new one....call me at Borgeson and like I tell everyone...Im there to help not allways sell....BC
    jambottle likes this.
