History Two H.A.M.B. Era Contraptions
Discussion in 'Traditional Hot Rods' started by Chris430, Aug 2, 2023.
  1. Chris430
    Chris430
    I go to a local yard to buy project metal. Today I found an 3 bolt main Ford 4 cylinder and what looks like an addon heater box. The internals are all there on the engine, don't know how the block broke. You guys recognize the make and years of the parts. I bought the heater box for some reason.
  2. Joe Blow
    Joe Blow
    Late 40's Kaiser Frazer air conditioner.
    ZjMEg_k4NopiO89GJ4Piks2D.jpeg 8Yw_l3GsHHqDJpFGBKw4ogKO.jpeg s-l1600.jpg s-l1600 (5).jpg
  3. Looks like a Model A engine.......or what's left of one.
    Deuces, 41 GMC K-18 and Joe Blow like this.
  4. rusty valley
    rusty valley
    I'm gonna say its a T engine. No hole for the oil filler tube, well...there is a dark spot in the photo in about the right place, but the crank looks T also
    PINEAPPLE and Tow Truck Tom like this.
  5. Chris430
    Chris430
    Ahh, that explains why the "heater core" tubing looked so thick. The motor up top, did that syphon refrigerated air to the heater box for dehumidified defroster?
    They said the owner p***ed away and his son was cleaning out his garage. There is a variety of car engines in that pile. At .30 cents a pound it is easy to get distracted from your original reson for the trip.
  6. Chris430
    Chris430
    Either one of you guys have a use for the guts out of it?
  7. 62rebel
    62rebel
    Mind you, the term "air conditioner" in those days seldom meant "refrigerated", just "heated". There's no cooling going on in that unit.
    Automotive Stud likes this.
  8. BJR
    BJR
    It's just a hot water heater with a blower on top to circulate the hot air through the heater core.
  9. BamaMav
    BamaMav
    from Berry, AL
    Looks like a heater / defroster unit. If the core doesn’t leak would make a nice addition to any car or truck that didn’t have heat.
  10. the oil soup
    the oil soup
    from Tucson,AZ
    If the water is hot, why do you need to heat it?
  11. woodiewagon46
    woodiewagon46
    from New York
    No, it's not Model A, the casting is different.
  12. sunbeam
    sunbeam
    Model T ser number falls in June of 1925.
    warbird1, Hotrodmyk and Deuces like this.
  13. Chris430
    Chris430
    It has two motors. One pull fan after the core and the small one up top.
  14. BJR
    BJR
    Good question. If you want to ponder stuff like that, ponder this. If someone is talking behind your back, they are in front of you. You have two arms, and two arm pits, you have two legs, but only one leg pit.
  15. BJR
    BJR
    The one on top is usually for the defrosters, but I don't see where it pulls the hot air from.
  16. Chris430
    Chris430
    The bigger fan pulls air straight from the the hole in the back. It appears that there would be some kind of louver under the hood to close off outside air and just pull air from the inside. Maybe the owner of a working unit will respond.
    EDIT: Yeah it makes sense like you said. My 65 F-100 and 250 work similar. Got to flip a lever to cut off the under dash heat and reroute it to the defroster.
  17. Chris430
    Chris430
    Measured the back. Thick compared to other heater cores I've dealt with as far back as a 1962 year model. No bevel on the end or burs inside like a tube cutter would have left. If it was refrigerated air conditioning I would think this area was prone to leak or blow apart. A heater hose over this end aught to stay put with a low pressure cooling system.
  18. Joe Blow
    Joe Blow
    It was a heater/defroster. Kaiser-Frazer called it "Air Conditioning" because by strict definition, it did condition the interior air (heated).
  19. Squablow
    Squablow
    Impressive ID job on that heater. I pride myself on **** like that but I wouldn't have gotten that one. Would be a good add-on to any early car that needs a heater, it's a nice, self contained unit.
    I don't think the guts of that T engine have any real value. The small bits are already stripped off and I don't know if I'd trust a babbited rod or a crank out of that block with a giant window in the side like that. Nice thought to try and save it but I don't think there's anything good there, not a big market for T engine bits anyway. Heater was worth saving, though.
    chryslerfan55 and Joe Blow like this.
  20. Joe Blow
    Joe Blow
    Thanks man.
    Squablow likes this.
  21. Chris430
    Chris430
    My old 65 Ford goes out in what ever weather, what ever this unit blew out my thought was to put it in the camper shell for the dogs if we have to travel on 100+ degree days. It can get too hot in this ugly aluminum box. May be better off rigging it with a small window unit.
    We've had zero degrees a couple of times last year. Might as well rig up some heat in the back. Dogs lives are short, if we are capable might as well treat them decent.
    Budget36, Squablow and chryslerfan55 like this.
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Don't try running it on 12 volts. I ruined one that way.
    Chris430 and chryslerfan55 like this.
  23. Chris430
    Chris430
    Thank you, didn't think of that.
  24. gene-koning
    gene-koning
    If it has a double blower, it should move a lot of air under that bed cover. Add water hoses with a shut off valve and you get heat in the winter, and a fan moving the hot air around in the summer. I think both would probably be helpful for the dogs.
    Those 6 volt motors can probably be swapped out with 12 volt motors. NAPA used to have a selection of cheap, small, 12 volt fan motors, don't know if they still do or not. Match up the shaft size, the rpms, and the outer size if you have a space problem.
  25. I have two of those little blower gizmo,s. They fit on just about every vintage heater. The little blower is usually up behind the dash and out of sight.
