Technical SBC 350 Pulley setup for alternator only
Discussion in 'The Hokey Ass Message Board' started by tschmitt, Aug 4, 2023.
  1. tschmitt
    tschmitt
    from IL
    Hey everyone, looking for a little guidance on this. I have a 1992 SBC 350 TBI that I am changing the intake and going with a carb. My question is does anyone have a setup they have used to go with just a alternator? The 34 Dodge Sedan I am building has manual brakes and manual steering so I only need a alternator. The current water pump on this year 350 has a reverse flow water pump due to the serpentine setup so I would need to change that as well. My plans are to change to a vbelt by changing the pulleys.
    Anyone know of what I might be able to use to cheaply change this to a vbelt, alternator only system? Thanks in advance for any advice or recommendations.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Reverse the rat rod thing as well. Then I’ll have an answer.
    Desoto291Hemi likes this.
  3. tschmitt
    tschmitt
    from IL
    Not sure I follow this lol but it's a 1934 Dodge 4 door that has been cut down to a 2 door from what we can gather. Was built in 1967 and has changed hands several times. Fun little toy though.
  4. DDDenny
    Not here you're not!
  5. tschmitt
    tschmitt
    from IL
    Lol my mistake, edited the initial post. Working on a 1934 Dodge Sedan.
    5window likes this.
  6. swade41
    swade41
    from Buffalo,NY
    People are ****s sometimes, instead of just helping.
    All you need is something like this or hit your local junkyard if they have cars in the 70's and down.
    https://www.ebay.com/itm/4042918765...gBJ8mOPS5m&var=&widget_ver=artemi***edia=COPY
    You need to determine what works best for you, either short waterpump or long, they have different pulleys, location of the alternator and fan to radiator clearance usually dictates which pump you're going to need. A short pump puts the alternator behind the leading edge of the block so it sticks out further from the engine and takes a longer belt, long pump you can put the alternator in front of the engine block and have a little tighter engine bay.
  7. I would run a "long" water pump (came factory on a LOT of vehicles ... it is the most common one) then find the factory style alternator bracket (pictured below) then buy water pump and crank pulleys to match. This puts the alternator on the p***enger side. I initially ran a "short" water pump and an aftermarket alternator bracket and pulleys. The aftermarket bracket put the alternator on the drivers side, basically above the valve cover and I ended up with trouble due to very limited belt contact on the water pump pulley (poor design of the aftermarket bracket that put the alternator so high up). In order to solve the belt contact issue, I ended up buying double-row pulleys for the crank and water pump and then ran two belts on the engine. First belt: crank/water pump/alt. Second belt: crank and water pump only (you need to find the perfect length belt because there is no adjusting a belt that only runs off crank and water pump). In the end I removed the short pump, bracketry and pulleys and went with factory "long pump" brackets and pulleys. I was much happier with the long pump. It appears that all the needed brackets and pulleys are available from the aftermarket if you aren't able to find factory stuff.
    Bob Lowry and Truckdoctor Andy like this.
  8. Order a water pump for a 78 Camaro (305 or 350) and you'll get a long pump that spins in the correct direction IF you are wanting and have room for the long pump.
    Moedog07 and Truckdoctor Andy like this.
  9. tschmitt
    tschmitt
    from IL
    Thank you so much! That was exactly the advice I was needing. I should've also mentioned I will be running a electrical fan as well. Thank you again!
    swade41 likes this.
  10. tschmitt
    tschmitt
    from IL
    Thank you very much for the advice. I will be heading to the junkyard this Sunday and maybe I will get lucky! Thank you again!
    Just Gary likes this.
  11. tschmitt
    tschmitt
    from IL
    So with the "long pump" pulley setup did you still have to run two belts or did you just run one? I noticed I can buy a single groove water pump pulley or a two groove one for the long pump style.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You can run one belt. There are single groove deep lower pulley’s that the factory used on non power steering vehicles.
  13. Budget36
    Budget36
    You just need one belt. Dual belts require a matched set.
    Be crank pulley, water pump and alternator.
    Truckdoctor Andy likes this.
  14. swade41
    swade41
    from Buffalo,NY
    Can you change the serpentine pulley on the alternator over to a V groove ???
    2OLD2FAST likes this.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    Should be able to ,they mount the same AFAIK ..
  16. tschmitt
    tschmitt
    from IL
    Thank you all again for your help and advice, it was greatly appreciated. First time working with a SBC so it's been fun learning the ins and outs. Thanks again and hopefully this thread might help out the next fella who needs this advice.
    swade41 likes this.
  17. manyolcars
    manyolcars
    Hes not talking about dual matching belts. Hes talking two separate belts of different lengths for different accessories.
  18. Budget36
    Budget36
    Okay, then you know more about what he’s doing than I do:)
    Edit: let me explain. With only one adjustable accessory, the only possible way to run two belts would be to have dual belt pulleys on the water pump, crank and alternator pulley. This would require a matched set of belts.
  19. Mr48chev
    Dang it's hard to jack a photo of a small block with a plain old stock style alternator bracket on it when you are hunting one
    The number of grooves in the pulley don't matter but it would look better if you just had single groove pulleys rather than naked grooves. The bracket on this engine is chrome but it is pretty much the same one that is on 90% of small blocks with long water pumps. Get the long bolt and spacer that goes behind the alterna SBC on pallet.jpg tor with it. Pulley is just take one off and put the other on. Any mid 70's chevy with a small block and long pump should have what you need if it is still on the engine.
    Budget36 likes this.
  20. Country Joe
    Country Joe
    Here is my set up with long water pump.
  21. cheepsk8
    cheepsk8
    from west ky
    If you choose a short water pump, here are the part #s for the water pump pully and crank pulley. The crank pulley will be a double groove, but it will work fine. Order an alternator bracket for a 67-68 camaro and then you are all set. IMG_20230805_072206.jpg 20230130_124736.jpg
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Reading this I realize what a disadvantage guys are at today , no never ending supply of good , clean factory setups in the junkyards , that is with what junkyards are left !
  23. DDDenny
  24. 1971BB427
    1971BB427
    from Oregon
    I have a 1990 SBC 350 in my '39 and went with Dart SHP aluminum heads, an Edelbrock intake, and Quick Fuel carb. I use a standard flow short water pump to ensure good clearance, but a long would have worked, as I ended up putting a 1" aluminum spacer under the fan once it was all done. I used a standard length water pump pulley, and a single lower pulley. For the alternator I got an adjustable chrome bracket from Summit that mounts over the #1 header tube, and can be moved forward or rearward to align with my pulleys. It was only about $12, and I've used these alternator brackets on numerous builds.
    Seems like they've really gone up recently!
    https://www.summitracing.com/parts/spe-42283/make/chevrolet
    https://www.summitracing.com/parts/sum-g4050/make/chevrolet
  25. Oneball
    Oneball
    I’d run a setup like this i
    Not necessarily, you run one belt round alternator, water pump and crank pulley and the second belt round water pump and crank pulley only.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    How do you adjust belt tension for water pump/crank pulley ?
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
  28. Oneball
    Oneball
    You put the correct sized belt over both pulleys before you bolt the pulley to the water pump. It was the standard set up on base Corvettes in 1968/9.
  29. DDDenny
    Like this!
  30. jimmy six
    jimmy six
    And all dirt track racers.
    Moedog07 and Oneball like this.
