Projects Back From The Dead Hotrod 1940 Chevy
Discussion in 'Traditional Hot Rods' started by Dyce, Aug 6, 2023.
  1. Dyce
    Dyce
    Originally built back in 1987 this was my first hot rod. It had a 377 with 2 quadrajet carburetors, fenderwell headers, and 4:10 gears. It had a camaro front end at that time. I was 19 and it was a blast!
    Unfortunately in 1990 someone pulled out in front of my wife and I and it got wreck. I parked it and put the engine in a couple of other cars. 33 years went by
    This is the frame I'm using.
  2. Dyce
    Dyce
    This time I'm going with a straight axle. Since it originally had a straight axle I am using the springs. To save weight and make parts easier I got a 4" dropped axle from speedway. I'm using forged spindles and the metric caliper disc brake kit. 20230806_122853.jpg
    I'm also going to use the original pedals. I gutted the original master cylinder and will build a new rod once I get the body on. I'm using a muncie 4 speed this time too and the clutch pedal looks like it's going to work great as well.
    I haven't decide yet what I'm going to do with the rear suspension yet. I'm using a ford bronco rear end (4.86 gears) and these wheels and tires. I plan on t******* the fenders to fit.
    Its going to have about 400 hp, 4 speed and 4.86 gears do it will have to be stout. I would like to use the original springs and ladder bars with sliders. The sliders I've seen don't look like they would last long on a street car. My other option would be coils. I have a pair of Chevette coils that I may be able to use. Or original leafs with traction bars above the axle? This is where I'm at now anyway.
  3. SS327
    SS327
    Cool, I’m paying attention.
    Dyce likes this.
  4. Bob Lowry
    Bob Lowry
    Keep us posted...I built a '40 Chevy coupe in my teens in Phx. AZ...in the 60's...amazing that
    60 yrs later people still have good hot rodding taste....cool build....
  5. Rocky
    Rocky
    Classified Editor
    Cool! 40 chevys are fun! I've had a few. Easy cars to work on and light enough to be pretty fast.
    My last 40 I built a 327/6 speed.
  6. vtx1800
    vtx1800
    When I built my 38 Chevy (in the 70's) ******* bars were one of the ways to control wheel hop, I just welded square tube to the shock/spring plates and used rubber bumpers (hey...it was a long time ago and I forgot where I found them...used), they have functioned quite well although I suspect it would ride better with out them. This early 70's 38 x_0001.jpg picture is the only picture I have that shows them...my daughter in the picture is a little older now.
  7. lumpy 63
    lumpy 63
    I really like where you are going with this but with 4.86 gears maybe a tremec is in order?
    Dan Hay and Dyce like this.
  8. Tim
    Tim
    from KCMO
    Dyce likes this.
  9. Deuces
    Deuces
    I like the '68 Z/28....
  10. Dyce
    Dyce
    I love that coupe!! Was it a big job making the one piece front? I'm thinking about doing that to the sedan. I'm worried it would get heavy and hard to open.
    DrJekyllMrHyde likes this.
  11. Dyce
    Dyce
    Your 38 sits nice!! I used stock springs and 4 inch lowering blocks the first time. With 4.10 gears the pinion jumped and the driveshaft would hit the floor. I built ******* bars on top of the springs. The did keep the springs from winding up, but I never could get it to launch without burning the tires off.
    vtx1800 likes this.
  12. Dyce
    Dyce
    It's a close ratio and the tires are 285/65r15. Almost 31 inches tall. I know I'll be busy shifting.
    lumpy 63 likes this.
  13. Bob Lowry
    Bob Lowry
    Dueces...it was my friend's. Brand new in '68..have more pics but not Hamb-friendly.
    Fun, fun times.
    Deuces, lumpy 63 and Dyce like this.
  14. Dyce
    Dyce
    Bob do you have any more details on the flip front setup? I'm wondering if it was heavy to open, and how, or if, the fenders cleared the firewall.
  15. Unless you lift it a ton you will have to trim the rears to fit. I am running 235x75s. The biggest offense is front to back. This is stock ride height in the rear. I did not have to cut the radius above the tire. In this pic I still needed to trim the front and back a little bit.
    Neat car by the way. Glad to see you resurrecting it.
    I did not catch what year ch***is you are using? It should have knee action suspension from the factory if I am not mistaken.
    This is just a question not a critique.
  16. Dan Hay
    Dan Hay
    Good to see a Chevy build around here! I'm working on my 38 coupe but it's too off topic to post here.
    Dyce and Bob Lowry like this.
  17. I just don't tell the stuff that won't fly. I got mine as a stalled project some of the underpinnings are not kosher. I don't post that info on the message board and anyone who knows me knows that they are free to ask (in private).
    It is all Chevy though. No baby horses where harmed in the construction. :D
    427 sleeper, Dyce, Dan Hay and 2 others like this.
  18. rusty1
    rusty1
    last year fo real knee-action was 38,...39-up had coilspring/A frame susp.
  19. Thanks I knew I was close. LOL
    Still makes me wonder what ch***is he is using that was an axle ch***is.
    One of the things I like about the GM was the hat ch***is. Less work to make one handle more then stock torque.
  20. rusty1
    rusty1
    40 Chevs came independent front susp. or with a beam axle,...last year for the beam axle option
    427 sleeper and Dyce like this.
  21. Atwater Mike
    Atwater Mike
    Friends of mine had late '30s to '40 Chevys, there was always arguments about what had axles, and what had knee action! Larry Perreira had a '40 Chev tudor, that one had coils and a-arms.
    But Tony Martinez had 3 Chevys ('38 & '39) and one had an axle.
    I didn't care, (I had Fords) but always wondered.
    @rustyl, OPTION!!! (Didn't know that!) Thank you! I'm a slooow typist...
  22. Rocky
    Rocky
    Classified Editor
    The cheaper 40 chevs had a beam axle stock. I've had both.
    427 sleeper, LOST ANGEL and lumpy 63 like this.
  23. Bob Lowry
    Bob Lowry
    Did it myself....young and ambitious...kept the front end bolted together, then found some old wheel
    bearings from rear axles off a '57 Chevy, made some "L" shaped brackets that I welded to the inner
    race of the bearing at the little end of the "L", and then bolted the large end of the "L" to each side
    of the radiator brace. This allowed me to remove the entire front end just by undoing 2 bolts on each
    side of the support. When lowering it, you did have to be careful as the bottom of the fenders bend
    slightly inward. Used Jeep hood latches down by the fenders to hold it down.
    I found a much more creative way to do one on the Hamb, that a fellow did on his coupe.. It slides
    the front end out about 4", then you can tilt it forward without it hitting the frame. Pretty sweet.
    48fordnut, Tim and Dyce like this.
  24. Bob Lowry
    Bob Lowry
    Dyce likes this.
  25. Dyce
    Dyce
    It's a master 85 frame. They had a straight axle.
    I plan on t******* the rear fenders to fit the rear tires. I had a nova rear end with 15x7 rally wheels on it. I tried255/70r15 under it back when it was still on the road and they rubbed inside and out.
    This is the 40 I drive now. My dad built the car in the early 90s and it was p***ed to me about 20 years ago.
    It's a nice cruiser! This one is going to have a little more al***ude.
    Outback, Paul B, juan motime and 9 others like this.
  26. Dan Hay
    Dan Hay
    My 38 currently has a 39-48 Chevy independent front suspension. They bolt in to the 37-38s so it was a common swap when my car was built in the 70s. It has corvette disc brakes adapted to it. Pretty trick for back then. I’m going to install a more modern independent suspension and that is frowned upon. If I get the suspension done I’ll do***ent the rest because I’ll also be going through the 327.
    Tman, Tim and Dyce like this.
  27. Dyce
    Dyce
    Thank you for the answers. I worked on over the road trucks for about 25 years and opened a good variety of hoods. Nothing as pretty as the one on your coupe! Very cool!! I've done some searching here on the HAMB and found a few threads on the topic. I have 3 front clips in a variety of conditions. I thought about splitting the front fenders and bolting the rear sections to the body. I'll see how much time I get. I already have work piling up.
    Bob Lowry likes this.
  28. Dyce
    Dyce
    Nothing wrong with that! All of the cars mydad and I built got nova or camaro front clips. The 37-39 would need a nova narrowed 4 inches or a Mustang 2. The 2nd is a much easier process.
    Dan Hay likes this.
  29. Dyce
    Dyce
    Cali4niaCruiser, Tim, RMR&C and 2 others like this.
  30. Dyce
    Dyce
    Long day! I got it dug out and on the hoist. Maybe I'll get the body swapped tomorrow.
    This is a shot of the crude traction bar I added to the lowering block. It kept the driveshaft from hitting the floor but did not help much with traction.
    Surfcityrocker, Tman, Tim and 2 others like this.
