Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
    Well, I don’t think I’m gonna go to the car show on Friday! BUMMER!
    It wouldn’t be any fun anyway with it being that hot!
    Man! It was in the 70s all this last two weeks!!!
    Stogy likes this.
  2. 33Doll
    33Doll
    A628026C-E4B8-479F-BB3F-B319153889FB.jpeg B2F2BEB8-B075-4918-9E23-0EDED63CC58C.jpeg 42F8EA1F-11DA-4E8D-9863-A25C28E37863.jpeg 7F8FCB81-9362-4E96-92EC-63E0402B7472.jpeg 33 Update:
    Well, I’ve been driving it for a couple weeks on and off to work in and
    around town, in 90 to 104 degree weather.
    Couple of things:
    It runs about 190 on hot days 160 to 170 on cooler days but the higher the RPMs quicker gets warm on the highway.
    190 is the highest so far
    It cruises about 65-70 no problem straight down the road no pulling or vibration. However, the ****** has a few issues.
    The 2nd to 3rd shift Syncro catches once in a while, if the RPMs are too high, or trying to climb a hill or what not.
    And the output shaft has some play up and down it kind of clunks a little bit when I put it in reverse.
    Also, it makes a weird clunk once in a while when I go up driveway, at weird angle in reverse.
    So I bought a full kit a new clutch fork and shaft just in case it’s catching on the pressure plate or something because there’s a lot of side play.
    Also found a new old reproduction stock Syncro full ***embly. And heavy duty detent springs and balls to get that proper “clicking” between gears
    I think I can pull it through the floor board and tilt the engine, forward enough to pull it out to clear to crossmember. I really don’t want to pull the front-end and engine back out.
    I sure do get a lot of thumbs up, and it cruises great around town as long as I shift it real easy…
    Stogy, Outback, milwscruffy and 8 others like this.
  3. 33Doll
    33Doll
    I think I will drive it to work tomorrow
    Before I start Ripping her apart!!
    Should not be to bad. Glad I made the metal floor removable like the old wood one!
  4. 33Doll
    33Doll
    Made it back-and-forth again today! So, as soon as I get this ****** rebuilt.
    it should be good to go!!
    And reliable
  5. DaveyJonez
    DaveyJonez
    from Houston
    Looks really nice!
    Stogy and 33Doll like this.
  6. 33Doll
    33Doll
    69B9309E-4436-4003-A456-B26E3043033E.jpeg BFE8AF3A-0197-41B7-8FFB-4063718425BE.jpeg 4028337F-31A5-4F41-AEF2-7A5A2BEE2F9D.jpeg 6E55817F-7CD7-4649-9256-F3366862CEE3.jpeg D12EC1E2-D9BC-4D94-8C3B-6B4921481180.jpeg 2E671872-832E-45CC-9152-5E2E4E70FA0A.jpeg ACDE57FD-D359-4FAF-B150-1D2685A7F2B5.jpeg Gonna be a while!
    I need to save some money for a new
    2nd gear, and new main gear.
    Could probably still use them, but since it’s apart, might as well, do it right
    I found the problem, there was 1/8 of end play that can’t be explained, so I made a Spacer to go between the snap ring and the speedometer gear.
    Boy! Van pelts online info sure helps alot!!!
    Stogy, brEad, guthriesmith and 4 others like this.
  7. dumprat
    dumprat
    from b.c.
    That looks like it's had. A lot of metal debris fed through it.
  8. 33Doll
    33Doll
    847E9F68-5273-4069-8152-F155AEAB07E9.jpeg While waiting for $
    I fixed the side play on the clutch fork shaft
  9. 33Doll
    33Doll
    Well… I ordered my transmission parts from Mr. Van Pelt himself!
    What a cool knowledgeable guy!
    I ordered an input shaft/3rd gear and and a new second gear!
    He says that they’re made in Argentina and he’s been using them for 10 years now and they’re great or I could get a good used stuff but I just went ahead and bought new!
    Stogy, Tim, Algoma56 and 5 others like this.
  10. 33Doll
    33Doll
    Got my VP gears!
    Big difference! Way more meaty teef!
    I think this ****** is going to shift like gravy now!!!
    A2C5E9F1-1A2C-4A82-9546-61A4BBFDD73D.jpeg 8E6F11B4-B9E0-448B-8058-C5BCE8E60099.jpeg C850FAAA-BCC0-4C94-9F85-00BFAD294A81.jpeg 93B28359-5D48-4D00-95BE-F2E60C7BD6A2.jpeg 445A6387-920E-4E96-9321-0A5C23FAACC3.jpeg
    Stogy, Jim Bouchard, Tim and 7 others like this.
  11. 33Doll
    33Doll
    23BEA965-9317-47B6-BC1A-4A51132BC223.jpeg A082121B-ADC3-4DE9-87E8-FEE70D15612A.jpeg 0F20F652-9993-435D-8ECF-83628FFAA34C.jpeg 80E3A58A-11C4-47BB-A271-3024BE965CC2.jpeg B5D2DB1B-4DA4-4598-8593-A2ECC62B4EA0.jpeg 4A2FF3A3-A0C3-4236-864C-0D24956F71D0.jpeg B3438C1D-B4F5-4998-8B60-34EFCFCB648D.jpeg 6E08B431-D85C-45BF-AFFA-D4C67B5EDC61.jpeg 74DC49C9-AFE4-4E1E-A7D2-3AE62B74159A.jpeg 8C890F81-D34E-4BB9-89B8-72C14037E4AA.jpeg E7470798-8A57-4B8A-8E5D-4510F736C209.jpeg C1740C73-82F8-4800-8628-E6370A6F2D37.jpeg 0263ED38-0198-4C09-AAD1-4B9C6613D980.jpeg 8E355A1F-9F7F-42B8-AE7C-E42CFDA3D27A.jpeg 54B63A79-5132-40B9-87DB-60E83228ABF1.jpeg 8BC08043-A098-49CA-8F57-80BD467C108C.jpeg 1A57436A-61B3-45E9-99BB-3957F053F3D6.jpeg BE689612-FF1B-4D19-A3DD-EC50E6583ED5.jpeg 5C122F57-3B61-4DFC-9CD2-6935485865BC.jpeg F702467A-40C7-40ED-9264-4B128DACAE3E.jpeg 81056560-060E-48C5-9DD9-642EDEFCFD48.jpeg 733AB679-F3FF-4BD8-9F9A-B5B3A426CAFB.jpeg 6357CC8C-B0D2-446C-9647-59E699162543.jpeg 6BD55F0F-5983-4FC4-9B81-D19A92765F0E.jpeg E75B8E32-14B0-4223-A96C-4F17F32DEA62.jpeg CDC49D48-74CF-4B92-83A9-00641385DCC6.jpeg 0BDFC00D-CDF3-4EAE-8C6F-1CA2D6D04544.jpeg My pops found a bunch more pictures of the 33 and some of our other cars!
    Me and my brother in a couple!
    (Can you tell that my family and friends like 33s and 34s?)
    Jeff34, roadwarrior84, rod1 and 9 others like this.
  12. 33Doll
    33Doll
    69A35A99-8469-4C7B-B682-BBF96B3ADFDA.jpeg 1D5AA519-F305-4B0B-AA5C-B2A635204E29.jpeg ….and Today!
    Jeff34, CC-Mo, Stogy and 6 others like this.
  13. -Brent-
    -Brent-
    I nabbed a couple pics for the "Hangin' Those Rear Tires" thread. I'll tag you.
    It's so fortunate that you have those pics and you've brought the car back.
    Stogy, Woogeroo, 33Doll and 1 other person like this.
  14. 33Doll
    33Doll
    Got a little progress done today. Will be finishing this until I get back from Europe though at the end of September too much stuff going on.
    But at least the gears and everything are in it, and it seems to be fine.
    CC-Mo, guthriesmith, Stogy and 8 others like this.
  15. 33Doll
    33Doll
    8028B68D-7CBE-4E9D-AB84-C211DCDE8D9E.jpeg C9F38F79-BCB2-402C-B1CD-E880063018CE.jpeg 3FD387FE-2391-4CA9-9944-59BF6D9BB091.jpeg 94E4BEF1-3BC1-44D7-A45C-6968288333EA.jpeg B9177487-075A-4D54-B9F0-F48734A8BF61.jpeg 9BB682E2-3E93-4E01-A5F0-7820C30B41DD.jpeg
    Welp!
    I think it is all good to go!
    Took it apart 3 times, to
    Make sure everything is correct!
    lubed all the gears, and bushings
    Rotated by hand several time's hand, shifted it, broke in the rings as best I can in Hand.
    Sealed everything, and painted!
    Just need to
    Put it back in when we get home from Europe!
  16. Stogy
    Stogy
    Congratulations 33...fantastic journey you've taken us on...looks really sharp...great job on the turnaround times on the shakedown...your motivation is beyond admirable...best thing is you still have things to share with us...have a great trip and I'll bet you'll be a bit giddy to get back and do some cruisin...looking at the family photos it's no surprise that you got the old car bug way early...
  17. 33Doll
    33Doll
    Thanks! I love sharing with you guys because you guys of course, are the only people that get it!!!
    I miss the old days when my dad had a bunch of friends that came over and uncles and stuff. It’s just not like that anymore. I’m sad about that, but at least I got this forum to share with.
    Algoma56, Jim Bouchard, Stogy and 2 others like this.
  18. 33Doll
    33Doll
    3F15EEAF-875F-44D1-8D90-CACA71A39AB2.jpeg 6BE7AE84-3E34-4516-B0CB-9B074F738080.jpeg EB0DAB8E-38E9-4936-8E6D-B8EA9F60B03C.jpeg F3203DBE-7108-4FA8-B37A-31CB0CA6E572.jpeg 37DF4D5E-A575-480B-8B8F-2B2FD9E0CDF8.jpeg 629F2383-2BD1-429D-A004-6418E1C55DDF.jpeg SHHHHHShush…..
    I was supposed to be cleaning the bathrooms while Grace is out with her friend eating dinner.
    I got the transmission in and the bathrooms cleaned, and the dogs walked and she still out eating with her friend !!!
    Lol!
    I did all of this in these pictures, AND the bathrooms, in an hour and a half!!!
    (I can be motivated when I want to!!!)
    I didn’t like the aftermarket sleeve, and bearing so I use the other one in the old sleeve that bearing only has 200 miles on it anyway but it’s way beefier, so is the sleeve!!! maybe it’s for a truck?
    Jeff34, brEad, Outback and 5 others like this.
  19. Stogy
    Stogy
  20. 33Doll
    33Doll
    84EF9564-23C7-43E0-8712-762C39D5DABD.jpeg 3FF9116E-997A-4823-8215-C6CC2133776B.jpeg E185BED0-4F0A-410F-BEE7-30C296022BF4.jpeg 0CD89A83-80A4-437C-BA4B-B44DAD9E6C94.jpeg E0F4F1EE-1F66-40B6-B5DB-EA844F10CD86.jpeg 9EDA2FBC-392E-454E-A97F-58ABA82FBB9D.jpeg Few Fun Pics From Ireland!
    We have a virgin G***er in the making!
  21. dumprat
    dumprat
    from b.c.
    Guinness bears an uncanny resemblance to used flathead engine oil....
  22. 33Doll
    33Doll
    Kind of tastes like it too!
    (Not that I have Drunk it!!)
    dumprat, Stogy and loudbang like this.
  23. guthriesmith
    guthriesmith
    Always seems strange to me to be on the HAMB while in another country. Not sure why, but just does. That is especially the case when I have been on here in a third world country that barely even has electricity (at least reliable electricity). I have been on it in probably 10 countries or so and strangely enough, it kinda seems like a little piece of home no matter where I am in the world. :D
    Have fun in Ireland. That is one place I have never been but would like to go. My grandmother was a Riley and her folks came over from Ireland around the turn of the twentieth century. So, I am as much Irish as anything at least that I know.
    -Brent-, brEad, Stogy and 2 others like this.
  24. 33Doll
    33Doll
    Calling is off, but have Wi fi in several locations for the Net!
    Stogy, Outback and guthriesmith like this.
  25. Outback
    Outback
    from NE Vic, Oz
    Have fun, I know some locals over there who will only drink Guinness on tap over there, "doesn't taste the same elsewhere!"
    Enjoy your time
    guthriesmith, Stogy and 33Doll like this.
  26. 33Doll
    33Doll
    One more Day in Ireland… Then hop the Ferry over to Scotland!
    guthriesmith and Stogy like this.
  27. Stogy
    Stogy
    Black and Tan, that worked for me...cheers mate...;)
    brEad and guthriesmith like this.
  28. 33Doll
    33Doll
    D1C6AAE0-D191-4637-8539-4A355BA999A9.jpeg 9AF446F0-7881-4DAF-9FA9-BC7CF6A21424.jpeg 9F0AA79E-8EB0-4804-B30E-ACFC60FCFC81.jpeg C2A66A51-AEA6-4667-A73F-3E0E131824EB.jpeg EB4CF4AA-7BB6-488E-BA44-5979DD0D0A52.jpeg 245202CD-8FC4-4C06-8A45-9B3EDED58F49.jpeg Few from Scotland…
    London Tomorrow
    All this cool… but I am Homesick
    And miss The 33 and the Bronco.
    At least I can Spy on them when I have Wi-Fi!
  29. 33Doll
    33Doll
    EE4F9D99-21FA-45AA-9347-6CD1CC26CE02.jpeg 16DDEC01-DC57-4542-AA25-083294767E1E.jpeg 1448B4FC-5CAC-4259-8AF3-7B5C82845B80.jpeg 8D0D87BC-4C88-4A73-9191-27F4DBFD71D8.jpeg 00681454-9AAA-4140-9B4B-FED210C6C405.jpeg D1591CAD-14B1-4488-8936-E82D4C43E169.jpeg AA9B1E27-3C15-4BB7-851D-A974EBA9A6A5.jpeg F3A7E2BD-7CB8-491D-AB88-5D037545B779.jpeg 1559EC82-9190-4A49-BD17-E3FCF045C55B.jpeg 6096386D-EEC9-466A-9A87-5BFF72F8B69A.jpeg 4F97A793-0BC7-4B52-A390-30F9E0656113.jpeg Last Night in London!
    Fun…. But Homesick!!!
    Just when we figured out the “tube”
    Here’s a few pics to wrap it up! And a car that I came across that I can’t figure out what it is but it’s cool!
  30. Outback
    Outback
    from NE Vic, Oz
    Jeff34, Stogy and 33Doll like this.
