Hot Rods Comp coupe dragster build!
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Jun 4, 2023.
  1. drumyn29
    drumyn29
    I dropped off the front axle today for a new leaf spring and removed half the car just to remove the rear end. Dropping it off at Cook's tomorrow to add 2 inches on each axle housing end.
    Deuces, Stogy, Dean Lowe and 2 others like this.
  2. saltflats
    saltflats
    from Missouri
    Be interested in knowing how they will add 2 inches on the axle tube.
  3. patsurf
    patsurf
    the same cook's machine shop from the 50's and before,in old hrm articles??wow if so!!
    AHotRod likes this.
  4. drumyn29
    drumyn29
    Thats the one! Love those guys!
    AHotRod, 427 sleeper and patsurf like this.
  5. Stan Back
    Stan Back
    Try rotating the body an inch or two for a little rake and see if you like it.
  6. drumyn29
    drumyn29
    I tried it but a buddy owns this white dragster and I don't want to have it look alike so I think I might head towards earlier style dragsters.
    comp mel or fe.jpeg 359841822_100714353107324_2264519016154141461_n.jpg IMG_1732.jpeg
  7. drumyn29
    drumyn29
    Borrowed Chema's parts washer. Uncle Sal at Atlas spring built a new spring for my dragster and Paul at Cook's is widening my rear end 2" each side with Torino ends!
  8. AHotRod
    AHotRod
    This is exciting to see come together, I love it !
    Deuces, Just Gary and 427 sleeper like this.
  9. elgringo71
    elgringo71
    Fantastic job and with some good friends to help keep things moving along.
    Deuces likes this.
  10. drumyn29
    drumyn29
    New suspension with black powder coat. o_O
    Deuces, rod1, Dean Lowe and 5 others like this.
  11. drumyn29
    drumyn29
    Waiting for my shocks to arrive
    Deuces, slayer, elgringo71 and 3 others like this.
  12. drumyn29
    drumyn29
    where to mount or maybe DON'T mount!
    Deuces, Dean Lowe and slayer like this.
  13. patsurf
    patsurf
  14. Marty Strode
    Marty Strode
    With the shackles nearly vertical, aren't you going to need a center locating device, such as a panhard rod ?
    verde742 and Just Gary like this.
  15. drumyn29
    drumyn29
    It has 12 degrees of caster, i have heard many opinions on caster, not sure which is best.
  16. drumyn29
    drumyn29
    I'll probably have to do something like this. But the spring doesn't seem like it will move and down much.
    Deuces, Just Gary and Dean Lowe like this.
  17. Marty Strode
    Marty Strode
    Have you ever seen those Elvis legs, that wiggle back and forth. Shackle angle takes care of that . IMG_0456.JPG
    Deuces and Dean Lowe like this.
  18. drumyn29
    drumyn29
    Now I understand. I can easily have Atlas shorten the spring to give it more arch.
    verde742 likes this.
  19. drumyn29
    drumyn29
    I would love to get a few opinions on these tires, I want to run as tall as I can get to make it look somewhat of the era. Luck was on my side, I bought new Anglia bearings today and it tuns out that the wheels were machined for Anglia.
    Deuces, slayer, Just Gary and 2 others like this.
  20. drumyn29
    drumyn29
    Shout out to Mike for making it easy to buy bearings locally with his precise measurements.
    Deuces, loudbang and 427 sleeper like this.
  21. Shave the shoulders and you will be Primo!
    drumyn29 likes this.
  22. drumyn29
    drumyn29
    Do tire shops shave them? I don't trust myself to do it.
  23. I have seen someone post in the past about a tire shaver in Socal. Maybe @axle or someone else knows?
  24. Nate Jones in Signal Hill if he’s still there shaves tires.
  25. drumyn29
    drumyn29
    saweeeet, thank you
  26. drumyn29
    drumyn29
    Body is mounted, now it's time for the real work, blocking the body
    Deuces, akoutlaw, bchctybob and 8 others like this.
  27. slayer
    slayer
    Looking good!
    Are you going to trim the body around the tires to alow for tire growth at speed?
    Deuces and 427 sleeper like this.
  28. drumyn29
    drumyn29
    I’m only using these tires for mock up and they’re much larger than the ones I’ll be running
    rod1 and 427 sleeper like this.
  29. Roadsir
    Roadsir
    What a fun build!
  30. Stan Back
    Stan Back
    Boy! Sure looks better since you filled the original back tire cutout!
    Just Gary likes this.
