Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
  2. Zax
    Zax
    Out with the old flathead
  3. lumpy 63
    lumpy 63
    6995.jpeg Jeremy and I managed to finish removing the exhaust etc from the Falcon. We fitted up the subframe connectors and tacked em in. This thing is super clean and cancer free.
  4. Sundays (yesterday) project here in 102° So. Cal heat
    (I think I drank 5 bottles of water).
    More rust repair on the A cab. So far it is just spot welded in. I think today I'm going to take a break from it and actually do work I make money from and tomorrow-ish I will get it fully welded in...
    Also for anyone reading this in the future looking to do patch panels on a 1930 or 31 Ford Model A pickup. Normally I am pretty happy with everything I have bought from parts supplier CW Moss (in the city of Orange in California) but whoever makes their patch panels for the cab corners they are absolute garbage (This isn't CW Moss's fault obviously They just sell the product but I know they pride themselves in using quality stuff wherever possible and these must not have any better ones available). I think I can make them work without any special metal working tools but I pretty much had to cut off the entire behind the cab portion of the radius because it dove off and the body lines did not match up what so ever and Even if the rear of your cab was in pretty good shape and you literally just needed the corner I don't think you could do this without having the rear cab patch panel that runs the length of the back of the cab. About the only thing I will give the corner panels is they had weld through primer.
    And yes to the 3 haters that Just like to criticize. I am using a flux core welder and I am doing this on the side of my house. 0806231720.jpg
  5. I was thinking about making a daily driver in the near future That functioned like a mini truck by either using a Ford 2.3 or 2.5 (same difference) or the Chev iron duke with a 5spd. I figured they would be a dime a dozen considering everybody drops v8s into s10s and rangers and oddly enough the square body trucks are now considered cl***ic minis... (That is so weird to me I still view them as late model junk).
    Anyways a 1935 to 41 Ford pickup probably doesn't weigh 3000 lb stock and a single cab first generation S10 weighs 2800ish lb so the weight is almost identical but you get a way cooler truck with a robust solid axle front suspension and being a Ford all the restoration parts are available plus I could do a cheapo disc brake conversion from speedway AC, heater fairly decent radio and stop when it needs to And it would make a really nice daily driver that I wouldn't have to smog (i live in California, we smog 76 and newer vehicles). Anyways just thinking out loud.
    Your S10 engine and 5 speed is it really good combo and it can take some abuse and in your model A it'll give you pretty darn good gas mileage making it a really fun car to drive.
  6. Little Truckdoctor and I started to re-deck the floor of our 12’ motorcycle/UTV trailer. The trailer is 20 years old this year and has never had a new floor. When I ordered this trailer in 2003, I spent an extra $100 or so and had them install a treated wood floor. This trailer has been parked outside its entire life. I’d say that’s pretty good service from a trailer floor. This will be an excellent time for Little Truckdoctor to get some time with the Lincoln Tombstone welder.
  7. saltflats
    saltflats
    from Missouri
    Spent a little time cleaning my new to me wheels.
    Lone Star Mopar, enloe, rod1 and 11 others like this.
  8. atch
    atch
    Just finished up a job I really don't like to do. Sandblaster was clogging up. Emptied it, sifted the sand, put it back in. Works like a new one again. It's a pita to do though.
  9. simplestone
    simplestone
    Thanks for the positive comments on the Iron Duke/T5 combo. I did some quick preliminary research when I saw the ad pop up and jumped on it for $150. I figured the S10 tail shaft alone on the ****** was worth that much!
    From what I know so far, it is most likely an 87 or 88 - I'm hoping for the 88 because that is the year they started using a balance shaft to control some of the vibration.
    I'll probably try to find a carburetor for it since it is currently TPI. I don't have a problem with TPI, but I don't have the ECM, and it sounds like it would be more complicated for me to go in that direction.
    Lots to learn on this for sure, but I'm excited to move forward with this! Once I get going, I plan to start a build thread on the 29, which I've had sitting in the barn for over 35 years now! Good gracious, how time flies.
  10. squirrel
    Checking wheel alignment on the Corvette. I'm learning a lot, and haven't made any adjustments yet....
    looks like the caster is about 1 degree positive on both sides. Spec is 2 +/- 0.5
  11. lumpy 63
    lumpy 63
    7331.jpeg Finished welding in the subframe connectors and jigged up the 9 inch to weld the ends on. Wil be 57" wide with the big brakes.
  12. Sky Six
    Sky Six
    from Arizona
    I recently purchased a slightly not HAMB friendly car. I knew that it needed some work, but I thought you may want to see the prior owners fabulous work with a welder. The head had some issues apparently but his trusty welder came in handy.
    The brake drum had some issues and once again, the welder came into play to save the day. By the way... the picture of the brake drum shows the "good" side. All studs were welded all the way around on the other side.
    And then he said that he had installed a "new" exhaust system. You got it... the welder came into play
    to save the day.
    I'm going to be busy for a while.
    20230613_130421[16543].jpg 20230804_132557_resized[16902].jpg 20230706_125607_resized[16904].jpg
  13. lumpy 63
    lumpy 63
  14. Roothawg
    Roothawg
    For what?
  15. lumpy 63
    lumpy 63
    My coworkers 62 Falcon:cool:
    chryslerfan55 and Roothawg like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Finally installed an M6900 Carter fuel pump in the red 56. While at it I relocated fuel line away from inner frame rails within the engine compartment. 734A9D25-1C87-462D-A7DE-A285E5901BD2.jpeg
  17. Bandit Billy
    Bandit Billy
  18. saltflats
    saltflats
    from Missouri
    Yes 5x5 bolt pattern. They fit fine on my 1937 Pontiac.
    I keep getting in trouble with off topic wheels, wanted to make sure I didn't get the boot for off topic cleaner. :D
    enloe, rod1, bchctybob and 5 others like this.
  19. 57 Fargo
    57 Fargo
    Spent a couple days touching up sanding on the Barracuda, set up my paint shanty and putting some red on it!
  20. jeepster
    jeepster
    from wisconsin
  21. 57 Fargo
    57 Fargo
    Put down a couple coats of red and a couple coats of clear so they aren’t pink stripes in a couple years…
  22. squirrel
    convertible top and seat stuff....oh, fun fun fun!
  23. 57 Fargo
    57 Fargo
  24. 57 Fargo
    57 Fargo
    Following my wife and youngest down the highway!
  25. 57 Fargo
    57 Fargo
    I’ve officially lost the car to my five year old….her name on the window sheet.:)
    enloe, 61Cruiser, bchctybob and 9 others like this.
  26. saltflats
    saltflats
    from Missouri
    I'd say she look pretty proud of it.
  27. lumpy 63
    lumpy 63
    20230812_153906.jpg 20230812_153906.jpg 20230812_153902.jpg 20230812_145446.jpg Dropped front suspension out of the Falcon. I know you east coast guys will be pissed when you see how rust free it is...
  28. Bandit Billy
    Bandit Billy
    No worries here mate. I just thought it was funny to polish ford wheels with GM polish. :cool: If they were 5x4 3/4 I'd have offered to buy them by now! Long live the Cragar SS!
    enloe, saltflats and Truckdoctor Andy like this.
  29. Lloyd's paint & glass
    enloe, 61Cruiser and lumpy 63 like this.
  30. lumpy 63
    lumpy 63
    Think I paid $5.19 for premium.....Almost makes up for grinding disc's, sheetmetal and welding wire:p
    427 sleeper likes this.
