Technical Hot valve covers
Discussion in 'Traditional Hot Rods' started by Spike788, Aug 8, 2023.
  1. 05snopro440
    05snopro440
    Ever grab a chrome breather to take it off after driving your hot rod for an hour? Next time you'll grab a rag first.
    Jibs, dmar836 and porkshop like this.
  2. hotroddon
    hotroddon
    I'd be more concerned with why you are running 20w50 oil. Unless your motor is about worn out, or you live in Death Valley, you are actually creating more heat with that heavy of oil. Both through increased friction (heavier oils have a higher coefficient of friction) and heavier loads on the oil pump. Ford recommended 10w30 in most 289/302's until the roller cams came in and then lowered it to 5w30. If it has high compression and a big cam, you MIGHT want to consider 10w40, but for a Hot Rod like yours, anything heavier than that really isn't doing you any favors. Just something to ponder ....
    Vic Walter, Blues4U, alanp561 and 4 others like this.
  3. George
    George
    According to stats published by Summit you cyl wall wear will be 3 X higher than with a 180-195....
  4. Illustrious Hector
    Illustrious Hector
    Wow, I had to see for myself. Last week we had an 80 degree afternoon, so I took the Olds engine for a buzz. When I shut down, I parked in the shade. The temp gauge was at 195, which is where it runs on hot days I have Offy valve covers, fairly thick. 2 1/2 hours later they were still hot enough that you couldn't keep your hand on them. Don't run heavy oil, doesn't reduce friction. 20w50 is for air cooled motorcycles.
    alanp561 and '28phonebooth like this.
  5. I think next oil change I'll go with a high zinc 10W40. Does anyone know if the Lucas Oil Hot Rod & Cl***ic is good? Screenshot_20230810_113633_Chrome.jpg
  6. Deuces
    Deuces
    Unless you use chrome molly (sp) rings on the pistons....
  7. squirrel
    never heard of chrome moly rings. I've heard of chrome rings, and moly rings, but they're two quite different things.
    I've also heard of chrome moly steel, which is yet another quite different thing.
  8. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Does anyone know if the Lucas Oil Hot Rod & Cl***ic is good? >>>
    Not for fixing hot valve cover worries. Only your PCP can prescribe meds for reducing hot valve cover anxieties.
    alanp561 and loudbang like this.
  9. Haha. Just want to go to a lighter oil that still is zincified! Not sure if anyone has used Lucas.
  10. You hear anything about Lucas Oil Hot Rod & Cl***ic? Might use that next time in 10W40 or 10W30. Not sure if it's any good though. Just want something with added zinc but lighter weight as you suggested.
  11. 05snopro440
    05snopro440
    Just had my engine apart. over 100,000 km's and there's still a nice cross hatch in the cylinders. I run a 160 thermostat and 20-50. That shouldn't work, though, right? o_O
  12. 05snopro440
    05snopro440
    Yes, it is good stuff.
  13. George
    George
    Don't shoot the messenger...
  14. rockable
    rockable
    We used to have really technical discussions on the HAMB. Now it's why is my engine hot to the touch after 4 hours. Jesus, an engine is at best 30% efficient, the rest of the fuel burned converts to heat. Cast iron holds heat, that is why chefs love cast iron pans.
    Squirrel gave an accurate ***essment of the situation on page 1 and we now have 3 pages on this subject. WTF?
    Next subject.
    Tman, 46international, MCjim and 7 others like this.
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Next subject>>>
    Do you think the folks trying to sell LucasElectrics felt they could do a better job at peddling LucasOils?
  16. twenty8
    twenty8
    Some of the wasted energy is lost to sound, so does that mean that a quieter car will also be quicker....???o_O:D
    rockable and XXL__ like this.
  17. Alternatively, you could just not participate.
  18. 1946caddy
    1946caddy
    from washington
    I'm going to let the secret out of the bag, "Global Warming";)
    Atwater Mike and alanp561 like this.
  19. Tighter than a nun's.... um.... er.... sorry, I forgot this is a family site! Never mind.....
  20. Yes, but that's Canadien 20-50. What is that in Amurrikan oil weight?
    impala4speed and scotty t like this.
  21. X38
    X38
    It's time...
    Chief 64, alanp561, Tman and 10 others like this.
  22. RMR&C
    RMR&C
    from NW Montana
    Swap in a flathead....no more hot valve covers to worry about!
  23. 05snopro440
    05snopro440
    Le 20-50 = 20-50 :D
    Budget36 and '28phonebooth like this.
  24. 05snopro440
    05snopro440
    Yep, hot everything else to worry about!
  25. Joe Blow
    Joe Blow
    Bandit Billy likes this.
  26. As requested by several of you I conducted a little experiment using a laser thermometer on various parts of the engine to track the temperature as it dropped over a period of five hours. If anyone is interested I will post the results.
    Thank you especially to (damn near) everyone for your responses, suggestions, and help. The condescending types can bite it. Admittedly there were only a couple of those which is par for the course on the internet. It's a forum partially designed to seek help and that's what I did. Thank you again everyone!
  27. Please post your results. It might be an eye-opener for us!
    Deuces likes this.
  28. Budget36
    Budget36
    Good deal, post the results. I’m leaving for work in a bit, OT Chevy PU with a “gasp” engine. I’ve a 45 minute commute, although I can’t check hourly, I can snag a laser thermometer and check sometimes 4/5 hours after I get there. Will post that for you to compare to.
    Edit: Got busy and it slipped my mind.
  29. 05snopro440
    05snopro440
    You mentioned it on two different posts in the same day. My personal experience has not showed that to be true, but I'm willing to be proved wrong. Do you have a link to this published data you speak of that you can share?
  30. George
    George
    it was all in the timing! As said, it was published in one of Summit's monthly catalogs years ago. It sowed wear at various thermostat setting. No idea how this was determined, same as the "NASCAR research shows black engine paint sheds more internal heat than any other" info.
